Ditch Sport Mode
Discussion in '3rd Gen Tundras (2022+)' started by TerraOnMyTundra, Jun 4, 2025.
  1. Jun 4, 2025 at 11:05 AM
    TerraOnMyTundra
    TerraOnMyTundra [OP] New Member
    Use Tow+ instead of you want real sport mode.
    It is a fairly significant driving experience upgrade.
    -RPMS kept higher/in power band
    -Feels like torque converter is locked after shifts, instead of being partially locked
    -Feels significantly sportier
    Likely not new info to most, however I'll be using Normal or Tow+ for daily use, depending on mood haha.
    Eco is nice for long freeway cruises as it removes quite a bit of sensitivity at the pedal.
    Blufin likes this.
  2. Jun 6, 2025 at 5:12 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    Sport is my daily driver mode. No loss of fuel economy vs. Normal but reduced throttle lag. (I get 18mpg calculated commuting with a level lift and skinny 35's.)
    Tow or Tow+ if I'm towing or want to be a hooligan. :burnrubber:
    ECO is road trip (non-towing) with the Cruise Control on mode.
  3. Jun 6, 2025 at 7:46 AM
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    You ought a try Tow+ with JB4 on Map3:D
  4. Jun 6, 2025 at 10:22 AM
    sandiegosteve
    sandiegosteve New Member
    San Diego
    24 Limited TDR Lunar Rock
    Tow+ also seems to do downhill engine braking. I like to go sport/Tow for a lot of the short steep hills around here. Normal seems to struggle on anything but flat.
  5. Jun 6, 2025 at 10:22 AM
    Daedalus
    Daedalus New Member
    Exactly where i'm at.
    Tow+ is just stupid.
    BlackNBlu[QUOTED] likes this.
  6. Jun 6, 2025 at 1:27 PM
    TerraOnMyTundra
    I am Newer to Tundras, I'll have to check that out.
  7. Jun 6, 2025 at 1:37 PM
    GREENPUS
    GREENPUS New Member
    Scott
    2024 Black Tundra Limited TRD Off-Road
    I normally run in Sport and I think I get better mpg than Normal mode
  8. Jun 7, 2025 at 9:03 AM
    Duckinatruck
    Duckinatruck New Member
    I also seem to get slightly better mileage in sport mode. I assume it’s because I live in the PNW, where nothing is flat. So, there’s a lot of on/off of the accelerator. I think sport keeps it from bogging down when you accelerate when moving uphill and this translates to less time with my foot on the gas.
  9. Jun 8, 2025 at 12:40 AM
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    https://shiftpowerusa.com/search/sp09/?make=7&model=71&year_search=30
    It is awesome with several settings that will beat the TOW+ plus eco mode, valet mode (to keep the valets from gassing it) and if you are in a bad neighborhood you can "lock" your gas pedal electronically so it can't be used.
    Just unplug the connection on the back of the gas pedal and plug this inline. It has a physical controller that you can mount or you can use an app on your phone.
  10. Jun 8, 2025 at 6:18 AM
    Frank_TRD23
    Frank_TRD23 New Member
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    We have a ditch sport mode?????
    Kidding!!
    Blufin likes this.
  11. Jun 8, 2025 at 11:01 AM
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    Tow haul does more engine breaking, tow+ expects you to Be using trailer breaks so less engine breaking.
  12. Jun 8, 2025 at 2:23 PM
    az 3rdGen
    az 3rdGen New Member
    Arizona
    2022 Black Tundra SR5
    Does every Tundra have the tow and tow+ options or is it trim/package thing?
  13. Jun 8, 2025 at 2:53 PM
    Blufin
    Bob
    23 Capstone
    I dunno about the engine breaking, but I do notice the down shifting while slowing down in Tow+.
  14. Jun 8, 2025 at 3:00 PM
    Blufin
    Bob
    23 Capstone
    SR5 does not offer Tow+ on other trims it is an additional option,but 1794,TRD PRO and Capstone it is standard.
  15. Jun 8, 2025 at 3:05 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Map 5 is where its at
    Blufin[QUOTED] likes this.
  16. Jun 8, 2025 at 3:23 PM
    Blufin
    Bob
    23 Capstone
    Map 3 is my max,not to mention getting E30 around me is like a zillion miles away so the best I can do is 93 + Octane booster.
  17. Jun 8, 2025 at 5:29 PM
    RayRay27
    RayRay27 New Member
    Mile High City
    2023 SR5
    Stock
    Not sure this is true. I have a 23 SR5 and I have tow+ as standard equipment.
  18. Jun 8, 2025 at 6:27 PM
    az 3rdGen
    Arizona
    I just checked because of this thread. I've had the truck for almost 2 years and never pressed the tow haul button.. turns out I do have TOW+ and I have an SR5. Another reason why I love this forum.
  19. Jun 9, 2025 at 5:02 AM
    Blufin
    Bob
    23 Capstone
    Sorry for the wrong information guys, I was under the impression (told) that SR's didn't get that option.
    My bad.
    I'm glad you found it and sure that you're loving it:thumbsup:
  20. Jun 9, 2025 at 5:35 AM
    chaztizer
    chaztizer New Member
    2023 Tundra TRD Pro
    I believe SR5 does have it, but SR does not. Goes for all modes on SR. Normal only to my knowledge.
    Blufin[QUOTED] and SCbuckeye like this.
  21. Jun 9, 2025 at 5:55 AM
    SCbuckeye
    SCbuckeye New Member
    Greenville, SC
    2024 Tundra SR5
    The base model SR's do not have the drive mode selector or tow/haul button.. I had a '22 SR through work before I bought my '24 SR5, which does have it.
    edit: I didn't see @chaztizer already responded before I posted mine saying the same thing.. leaving this up anyways
  22. Jun 9, 2025 at 6:00 AM
    dklehman
    dklehman New Member
    Darin
    2024 sr5 Tundra
    My SR5 has tow+ mode
  23. Jun 9, 2025 at 8:14 AM
    az 3rdGen
    Arizona
    It's like a whole new vehicle! The downshifting sounds soooo good when coming up to a light!!
  24. Jun 9, 2025 at 8:18 AM
    eddiefromcali
    Eddie
    100% Stock
    I have to blend it....California doesnt sell E30 out of the pump :(
  25. Jun 9, 2025 at 11:16 AM
    ElJefe77
    ElJefe77 New Member
    22 SR5 Premium
    Thought I didn’t have tow+ this whole time… confirmed I do. Can’t wait to try it out! Love this forum
    az 3rdGen likes this.
  26. Jun 9, 2025 at 11:34 AM
    Breathing Borla
    Northern Illinois
    tow/haul + = :burnrubber:
    to my understanding its the only mode without torque management muting things down.
    remember everyone, you have to hit tow/hau button, THEN rotate dial to get tow/haul+
  27. Jun 9, 2025 at 11:38 AM
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    What are you using to raise the octane? I know some of the boosters only raise by tenths of an octane versus by full numbers, and really are misleading. If I recall, most are xylene/toulene based and some people use that instead of marketed boosters. Just curious is all...
  28. Jun 9, 2025 at 11:52 AM
    Daedalus
    Daedalus New Member
    The only ones that are worth the money are the VP Racing madditive/octanium ones. HOWEVER, if you run those, they will coat your cats and plugs with residue. DO NOT run them with catalytic converters.
    E30 is legitimately a super fuel. My GTI made 403whp on 93oct, and 441whp on E30 blend. It was wild. I was out of injector at that point.
  29. Jun 9, 2025 at 12:49 PM
    SilveradoSwap
    Thats a crazy gain, should be able to feel that as well. Thanks for the insight!
  30. Jun 9, 2025 at 5:27 PM
    Blufin
    Bob
    23 Capstone
    Royal Purple Max boost it'll bring up 30pts/3 so 93 octane to 96,1 can for 15~25 gallons.Map 3 and under using this method.
    I have logged runs with this and all specs are well within any safeties being triggered.
    AFR,Ignition1,Trims,Boost,pedal and RPM's are all monitored.
    With this you can't use Map 4 definitely need E30 <.
