Ditch light Brackets for Best Gen?
Discussion in '1st Gen Tundras (2000-2006)' started by Jerry311SD, Jun 1, 2020.
  1. Jun 1, 2020 at 5:41 AM
    Jerry311SD
    Jerry311SD [OP] New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Anyone know where to get some ditch light brackets for the first Gen? I mounted my Square Rigid's Behind my grill but I am not happy with them in there.
    I wanted to mount them up higher.
    tunyota likes this.
  2. Jun 1, 2020 at 5:59 AM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
  3. Jun 1, 2020 at 6:01 AM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
  4. Jun 1, 2020 at 6:04 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Rago also has them but the link above is much better priced.
  5. Jun 1, 2020 at 6:04 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @Jerry311SD oh, and welcome back! Haven't seen you post in a while.
  6. Jun 1, 2020 at 6:14 AM
    Brown Bear
    Nor cal
    03 TRD offroad
    When installing these ditch light mounts just remember the only undo one Bolt at a time on the hood. Otherwise the hood can move on the hinge bracket making it very hard to line up again. It helps to trace out they hinge on the hood so if it does move you have a reference point to go back to.
  7. Jun 1, 2020 at 9:01 AM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    lol Thanks.
    I've been busy workin on my motorcycles. Haven't been really doing anything to the truck.
  8. Jun 4, 2020 at 6:31 PM
    LASurf
    LASurf New Member
    Los Angeles
    300k+mi 06 AC4x4
    I had ragofab on my last first gen and really liked them. Worth the extra $
    Jerry311SD[OP] likes this.
  9. Jun 5, 2020 at 5:57 AM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    I went with the Hot Metal Fab.
    A little sloppy work. And the hardware they gave me sucks I'll get better nuts and bolts and I'll add washers. I'll paint them and throw them on maybe this weekend see how they work. Once they are installed and I'm happy with them I'll weld the two pieces together so I don't have to worry about the nuts n bolts, I'll get (Tamper Proof) hardware to mount my Rigid Pods.
    Sunnier likes this.
  10. Nov 14, 2023 at 5:09 PM
    Unmbra_SCI
    Unmbra_SCI New Member
    Joe
    First gen Tundra
  11. Nov 14, 2023 at 5:29 PM
    Unmbra_SCI
    Joe
    First gen Tundra
  12. Nov 14, 2023 at 6:28 PM
    evanhmn
    evanhmn mmm chicken pot pie
    State of Taxes
    2001 TRD Off-Road AC 4x4 Limited in Black
    5100/2885s, 1.5" Add-Leaf, BFF Front Bumper, 265/70/17 KO2s
    These bad boys also work on the first gen tundies. It might have been how I placed my hood back, but the passenger side bracket required about 2 taps in a vice from a hammer to get it bent to not rub on the hood. Otherwise, prime and paint these bad boys to avoid rust, and they work!
    https://www.amazon.com/gp/product/B07NTYXB4V?ie=UTF8&th=1
  13. Nov 14, 2023 at 6:35 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    x2 on the Ragos
  14. Nov 14, 2023 at 6:39 PM
    Unmbra_SCI
    Joe
    First gen Tundra
    Dang... I want those but Im a broke bitch! My lights were only 30$ haha
    Do these ride solid or do they bounce?
  15. May 7, 2024 at 10:37 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I just upgraded to some Ragos ditch light brackets. I fell like I should run longer bolts for the hood mounts. Stock bolts don’t have much grab since the rags bracket are very thick
    Going to grab some - m8x1.25 25mm
    bulldog93 likes this.
