Distance Till Empty Shows Incredibly High After Battery Disconnect
Discussion in '2.5 Gen Tundras (2014-2021)' started by TheBigTimpin, Jan 12, 2022.
  1. Jan 12, 2022 at 6:11 PM
    TheBigTimpin
    TheBigTimpin [OP] New Member
    I disconnected my battery, then reconnected it and my DTE is showing 500+ miles till empty and doesn't correct itself. Is there an easy fix for this?
  2. Jan 12, 2022 at 6:12 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    Just drive it, it’ll correct itself.
    1lowlife likes this.
  3. Jan 12, 2022 at 6:37 PM
    TheBigTimpin
    OK. I had put about 35 miles on it and even filled the tank up thinking that would help. Ill just keep driving. Thanks
  4. Jan 12, 2022 at 8:11 PM
    so the extended range mod is disconnect the battery and then reconnect it? This is awesome!!
    Baja Mike, EDDO and 1lowlife like this.
  5. Jan 12, 2022 at 9:07 PM
    Totally normal. It will reset as you drive it.
  6. Jan 12, 2022 at 9:25 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    You'll need to run 2 or 3 tanks of fuel thru it before the DTE catches up.
    Keep in mind when you hit 0 on the DTE, you still have 2 or 3 gallons of fuel in the tank..
    In the 26.4 gallon tank of my 2014, the most I've ever put in it is 22 gallons.
    Baja Mike likes this.
  7. Jan 13, 2022 at 7:05 PM
    handyman
    handyman New Member
    2016 Crewmax Limited in Sunset Bronze Mica
    BFG All-Terrain TA KO2 Tires, Pillar Grab Handle, Curt Front Hitch & Winch Mount, Smittybilt XRC-8 Winch, Escort Solo S3 Radar Detector, Tekonsha P3 Brake Controller, Galaxy DX 2547 CB Radio, Center Console Organizer & Tray, ESP Rear Seat Storage, SumoSprings, Pop & Lock Tailgate Lock, AMP Bed Step, AMP Side Steps, BacFlip G2 Tonneau Cover, and more pending.
    Lol. That's one way to increase the gas mileage. If only it was that easy. I've heard pushing the truck around town works pretty good too.
  8. Jan 14, 2022 at 6:54 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    The fuel calculations are stored in the memory of the cluster. When you unplug the cluster or disconnect the battery that memory and data is lost.
    As others have said drive it for a while and it will return back to normal. Could take a little time for everything to "balance" back out.
