DISP button
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by dlyon667, Nov 15, 2024.
  1. Nov 15, 2024 at 5:03 AM
    dlyon667
    dlyon667 [OP] New Member
    David
    2017 White TRD
    Hello, just got my Tundra, 2017 Pro and can see from the car fax that the airbags went off in an accident in 2020.
    My horn doesn't work and I have researching that and learned it is the clock spring since I can hold the panic button on the key fob and it goes off.
    However my DISP also doesn't work and I cannot find anything online about this issue, my dash option is stuck on the engine timer and I'd like to be able to scroll through the other options, like miles to empty.
    Does anyone know if the clock spring replacement would fix both issues I'm having or is it two different things. All the other buttons on the steering wheel work to control the radio.
    Thanks
  2. Nov 15, 2024 at 5:11 AM
    If it came from a dealer I would make them fix it but of course many used vehicles are marked "As is no warranty".
  3. Nov 15, 2024 at 10:01 AM
    dlyon667
    David
    2017 White TRD
    Yeah, no warranty and out of State purchase.
  4. Nov 15, 2024 at 10:42 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Check this out and see if it helps
    His horn wasn't working either but the panic and other controls worked..
    Horn relay | Toyota Tundra Forum
    Welcome to the forum.
    Tripleconpanna likes this.
