Disappointment...305/70/18 are too big!
Discussion in 'Wheels & Tires' started by 16cmt, Jul 23, 2016.
  1. Jul 23, 2016 at 4:03 PM
    16cmt
    16cmt [OP] New Member
    Portland Oregon
    2016 Sr5 Crewmax
    3" leveling kit installed last night. paid and mounted these 18x10 -12 offset with 305/70/18 but the tires are too big! gotta return them for 295/70/18
    J&ATundra, Bigboitundra and Jsena like this.
  2. Jul 23, 2016 at 4:07 PM
  3. Jul 23, 2016 at 4:44 PM
    chphilo
    chphilo Tundra addict
    Western PA
    Even 295/70/18 will rub like mofo. The width and offset are the problems. I have 18x9 with +18 mm offset wheels and my tires are few mm away from the body mount. Also the tires were rubbing the fender liners. I did the fender liner mod, but fortunately I didn't have to cut the body mount. I have 3 & 1/2 inch OME lift.
  4. Jul 23, 2016 at 4:49 PM
    bandit
    bandit New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
    Swap em out for 0 offset wheels and I think you'd be fine...
    Relentless likes this.
  5. Jul 23, 2016 at 5:38 PM
    TheBeast The Beach
    yep offset..it does look bad ass right now though..
    time for a lift..lol
    Jsena and Relentless like this.
  6. Jul 23, 2016 at 5:41 PM
    bandit
    bandit New Member
    Duh Tundra
    This might help you.
  7. Jul 23, 2016 at 7:20 PM
    Your wheel offset is the issue here man
  8. Jul 23, 2016 at 7:24 PM
    frogger
    frogger just boost it
    Stephen
    Louisville Ky
    2008 S/C Tim Mica SR5 5.7L DC 4X4
    too much to list
    Looks badass like that. Hope you figure it out
    16cmt[OP] likes this.
  9. Jul 23, 2016 at 7:29 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Hmm would rub even with +25 offset?
  10. Jul 23, 2016 at 7:38 PM
    chphilo
    Western PA
    25 should work fine. With lower offset, the body mount is the problem and the lower offset will get you closer to the body mount. With 3/1 level kit, if you go with 0 offset, the largest diameter tire you could fit is around 33. Sweet spot for Tundra seems to be around 30-35 offset (all this assume 9 inch width, the most common one).
  11. Jul 23, 2016 at 7:48 PM
    +18-20 is a good sweet spot
  12. Jul 23, 2016 at 9:31 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Got you. That lines up with what I've researched so far.
  13. Jul 24, 2016 at 10:04 AM
    Nice art work by the way. Maybe you can be the unofficial forum artist............:thumbsup::thumbsup::oldglory::cheers:
  14. Jul 24, 2016 at 11:42 AM
    16cmt
    Portland Oregon
    2016 Sr5 Crewmax
    so you're saying a 18x10 -20 offset won't rub?
  15. Jul 24, 2016 at 11:47 AM
    No, what I'm saying is a +18/20 would work much better. Even more so if you get a cab mount chop done. I'm running a +18 with very little rub (skids- I need to trim it down a tad)
    16cmt[QUOTED][OP] likes this.
  16. Jul 24, 2016 at 12:30 PM
    16cmt
    Portland Oregon
    2016 Sr5 Crewmax
    I see. thanks Sean266!
    I'm looking to get the rugged look with the rims and tires bulging out without having to trim any part of the body. any suggestions help. notice I do have a 3/1 leveling kit already installed.
  17. Jul 24, 2016 at 12:31 PM
    TheBeast The Beach
    spacers maybe ? 70 sidewall is tough to squeeze without lift I think.
  18. Jul 24, 2016 at 12:53 PM
    chphilo
    Western PA
    With 3/1, go with 18x9 (not 10) and go with no lower than 18 mm offset. You may have to do some wheel liner mod but you won't have to do any serious cutting (assuming that you are going with 295/70/18). Between 18 and 35, higher the offset, less rubbing you will end up (but less offset will give you a more stuck out look). Mine is 18 mm and my tires are roughly even with bushwhacker fender flares.
  19. Jul 24, 2016 at 7:29 PM
    16cmt
    Portland Oregon
    2016 Sr5 Crewmax
    you guys think a cab mount chop alone may solve the issue? I think it also rubs the back rear fender (toward the door)
  20. Jul 24, 2016 at 7:30 PM
    Are you sure it's not hitting the cab mount? Maybe both?
  21. Jul 24, 2016 at 8:38 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Agree!
    The Juice and 16cmt[OP] like this.
  22. Jul 24, 2016 at 8:42 PM
    16cmt
    Portland Oregon
    2016 Sr5 Crewmax
    it's got a -12 offset and it looks like only the pinch weld. if it does require the cab mount to be cut and welded, I might consider it.. not sure yet exactly.. what's your guys opinion about doing those 2 cuts?
  23. Jul 24, 2016 at 8:46 PM
    csuviper
    Broomfield, CO
    I will be doing it at some point. It doesn't affect anything, just gets rid of some extra metal near the cab mount.
  24. Jul 24, 2016 at 8:48 PM
    bandit
    bandit New Member
    Duh Tundra
    I have 37x12.50's on my truck and I'm pretty positive your rear fenderwells are larger. I have absolutely zero rubbing in the rear, full droop and fully tucked. I'm thinking your offset is the issue, as everyone else has mentioned already.
    edit: the rear of my tundra is bone stock.
  25. Jul 24, 2016 at 8:49 PM
    bandit
    bandit New Member
    Duh Tundra
    Aim high right! #forumgoals
  26. Jul 24, 2016 at 9:49 PM
    16cmt
    Portland Oregon
    2016 Sr5 Crewmax
    I have zero rubbing in the rear also. the fronts are the issue.
  27. Jul 24, 2016 at 10:04 PM
    bandit
    bandit New Member
    Duh Tundra
    I was quoting this but it didn't go with my message about the rear for some reason.
  28. Jul 25, 2016 at 8:31 PM
    16cmt
    Portland Oregon
    2016 Sr5 Crewmax
    so guys, is there a link on what to cut to make the -12 offset with the 305/70/18 fit?
    maybe some links?
  29. Jul 25, 2016 at 8:33 PM
    bandit
    bandit New Member
    Duh Tundra
    I don't think theres enough material to safely cut away to make them work. Maybe someone else can chime in but your solution currently is probably going to be wheel spacers and a cab mount chop. Or get the correct wheels.
  30. Jul 25, 2016 at 11:17 PM
    16cmt
    Portland Oregon
    2016 Sr5 Crewmax
    maybe I need to stick with 18x9 +18 and my Cooper sst 295 70 18 and that should fit perfectly with no trim? but I loved the -12 offset
