Disappointed with handling on wet / icy roads with 18' Tundra TRD Off Road
Discussion in '2.5 Gen Tundras (2014-2021)' started by breyton490, Feb 14, 2019.
  1. Feb 14, 2019 at 7:57 AM
    breyton490
    breyton490 [OP] New Member
    One of the things that is increasing becoming a nagging want on my 2018 TRD Off Road is the lack of a 4-Auto or full time full wheel drive setting for the transmission.
    On my way to work today, the roads were a bit wet and icy. No big deal, general driving was fine, but on a few spots where I had to come to a stop, then go again, my Tundra just couldn't get moving easily. The wheels closet to the curb were slipping, then the traction control kicked in and the Tundra slowly started to begin moving. I felt like i was in my son's front wheel drive beater with all-seasons tires, not a big pickup.
    I understand snow tires would have helped, but this is where the Tundra is waaaay behind. A 4-auto setting would have easily got me moving with out having to wait for the traction control to slowly find its grip. Going to 4Hi was not an option as the roads were not overly wet.... and would have bound up during the turn I was making.
    If Toyota does not offer a 4-Auto or Full time 4 wheel drive transmission, I doubt I will be a repeat customer. This is my first truck and overall I really like the Tundra, but the more i drive it, the more i am discovering some of its limitations in design compared to the other guys...
    MaxMB and kparrow like this.
  2. Feb 14, 2019 at 8:14 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Temporarily disable the limited slip by pushing the button down for a second. This will allow the wheels to spin.
    Or sell your Tundra and move on...
  3. Feb 14, 2019 at 8:24 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Mine did great in Utah at ski resorts while it was dumping. At hotel parking lot it was like a sheet of ice, truck did great. I slipped and fell on my ass as soon as my foot hit the ground. I do have cooper at3 4s tires though. Got rid of stock tires.
    Chevy has auto 4wd but it’ll leave you stranded.
  4. Feb 14, 2019 at 8:27 AM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    Mine has been great it's just an understanding that theres safety features in place that we know have a job to be.
    Krezz likes this.
  5. Feb 14, 2019 at 8:27 AM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    Options: Hit the button once for Auto LSD, that's a help. Get new tires. Get a new truck. Get a Sequoia
    theraven, Black Wolf and DalTee like this.
  6. Feb 14, 2019 at 8:30 AM
    r1-superstar
    DB
    UTAH
    YES!! We have LOT's of snow here!! :thumbsup:
    I'm loving my new Tundra in the snow!!! And I'm on OEM Bridgestone Dueler Alenza H/Ls which are fantastic in the wet, ice, and snow. I had three sets on my Sequoia too.
    DalTee and 040Tundra like this.
  7. Feb 14, 2019 at 8:31 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    If appropriate tires and a bit of weight in the bed of the truck isn’t enough traction in 2wd, then it’s perfectly fine to run in 4Hi. And if conditions vary that much, I find it’s pretty easy to turn the knob in and out of 4wd as I see fit.
    One guy here has swapped an AWD transfer case from a Sequoia into his Tundra though. I think @Rex Kramer ??
  8. Feb 14, 2019 at 8:32 AM
    Cement
    Cement ...
    2019 Cement Trundra TRD
    I compiled this cheat sheet for myself from reading here for a while. It describes how to turn off the nannies all the way into "haul ass" mode. You might find it helpful.
    Tundras have three nannies: Auto Limited Slip Differential (LSD) off by default, Vehicle Stability Control (VSC) on by default, and Traction Control (TC) on by default.
    The TC and VSC features stack, meaning to turn off TC, you must have first turned off VSC. Here's how.
    Turning on LSD: press the traction control button (car with squiggly lines button) once. Auto LSD will light on dash. This can be done at any speed under 62mph.
    Turning off VSC: press the same button and hold for 3 seconds. The Auto LSD and VSC (car with squiggly lines) lights both comes on. The truck must be fully stopped. This can be done after having turned LSD on, or not.
    Turning off TC: with VSC already disabled (Auto LSD and VSC lights on), press the same button again and hold for 3 seconds. Traction control off will flash and you should end up with three lights on (Auto LSD, VSC and TC). The truck must be fully stopped.
    Now all nannies are off and Haul Ass Mode is available.
    "Haul ass" mode: press the Tow/Haul button. This can be done at any speed.
  9. Feb 14, 2019 at 9:37 AM
    Joe Dirt
    Joe Dirt New Member
    Don
    Sunriver, Oregun
    Silver 2018 SR5 4X4 DC
    You should go to the dealership and ask for your money back! Let us all know how that turns out. Then go buy a Ford and suffer the same results with rubber tires on ice. My point is , trying to be nice here is you have no experience with a 4x4, and ice. Positraction front and rear is no advantage when you're in a 6,000 lb truck on ice. A Prius with 4 studded tires will stop and start faster than any rubber tire truck. It's why I have 2 sets of wheels and tires on my Tundra. One for summer one for winter.
  10. Feb 14, 2019 at 9:42 AM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Mine is a beast in the snow. General ATX tires and I am solid as a rock. Think you need to change out your tires. Last winter I did run Michelin stock tires and they did great.
    I ralley the shit out my Tundra in the snow! No limitations here.
    TundraDude18 likes this.
  11. Feb 14, 2019 at 9:43 AM
    TheBeast The Beach
    are you still using stock tires ? they suck
    B737 likes this.
  12. Feb 14, 2019 at 9:45 AM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    Enough said
    NjPro and GNTundra like this.
  13. Feb 14, 2019 at 9:47 AM
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    When in doubt, put it in 4Hi. I'm not sure what turn you were trying to make, but I doubt it would have been a reason not to be in 4wd.
    rodm1 and TundraDude18 like this.
  14. Feb 14, 2019 at 9:48 AM
    15whtrd
    15whtrd Mr. Blonde
    If I was in your situation I would probably have two sets of rims and tires. One for winter and one for every other month. If an auto transfer case is the only solution that you see to your problem, feel free to get something else. Sorry if this sounds harsh but I don’t really sympathize with you. If you’d like to go Chevy, Ford or whatever has 4 auto ...
    I’m sorry you weren’t happy.
  15. Feb 14, 2019 at 9:49 AM
    DalTee
    DalTee New Member
    Dal
    I'm having no challenges in the snow. I run MasterCraft Courser HSX tires right now. If need be I just switch to 4Hi and rock on.
  16. Feb 14, 2019 at 9:52 AM
    breyton490
    Well... thanks for all the feedback.. lots of good info, a lot of which I was unaware of, but now I know.... so thanks... like i said, I am new to trucks and really like my Tundra... There is a reason I bought it over the others options... Wasn't looking to troll anyone. My post worked in that I now know more than I did before I posted it.. so thanks everyone..
    Drootz, Tincup, Krezz and 13 others like this.
  17. Feb 14, 2019 at 9:53 AM
    fundra_goes_west
    fundra_goes_west I’m just a guy with a girl
    Evan
    2022 SQ8
    Mines a beast in the snow. Running Duratracs and run up in the mountains all the time .
  18. Feb 14, 2019 at 9:56 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    [QUOTE="Cement, post: 1019805, member: 22667]
    Tundras have three nannies: Auto Limited Slip Differential (LSD), Vehicle Stability Control (VSC) and Traction Control (TC).
    These can be turned off. They stack, meaning to turn off TC, you must have first turned off VSC and to turn off VSC you must have first turned off LSD. Here's how.
    Turning off LSD: press the traction control button (car with squiggly lines button) once. Auto LSD will light on dash. This can be done at any speed[/QUOTE]
    I think this turns the auto lsd ON. You wouldnt turn it off if you were lacking traction
  19. Feb 14, 2019 at 9:57 AM
    sbxx312
    sbxx312 New Member
    Nice. Easy fix is use 4Hi. Better fix is get rid of the stock tires and use 4Hi.
  20. Feb 14, 2019 at 10:04 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    OP, if you wanted an “auto” 4WD then why did you buy a Tundra?
    Black Wolf and Grumpy Uncle like this.
  21. Feb 14, 2019 at 10:08 AM
    Cement
    Cement ...
    Ah that makes sense. So it will modulate the brakes to send power to the wheel not spinning, yes? If so then yeah you'd want it ON. Pressing the button once does so? Not on by default (can't go check myself for a while)?
  22. Feb 14, 2019 at 10:08 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Isn't ice slippery? :notsure:
  23. Feb 14, 2019 at 10:13 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    So are you going to buy a Ridgeline? I think it is the only vehicle with a bed that has AWD.
    15whtrd and Rica25 like this.
  24. Feb 14, 2019 at 10:20 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    If my bed is empty i turn the lsd on in the rain. It makes a huge difference.
    CMB likes this.
  25. Feb 14, 2019 at 10:23 AM
    Cement
    Cement ...
    Just checked the manual. You're correct. Button press turns it ON. Thanks. Will edit my post.
  26. Feb 14, 2019 at 10:24 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The auto lsd works very very well on slick pavement. Offroad not so much
  27. Feb 14, 2019 at 10:25 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    I agree that auto 4wd would be a nice option...but generally those TC's aren't built as heavy duty as a 2-4H-4L case is because the auto requires a clutch pack. I just turn mine int 4HI and don't worry about it. Unless you're making a full lock or almost full lock turn it really isn't going to be an issue being in 4HI when needed. I also have Cooper AT3 4S tires and they help a lot however, my wife's FWD car with studded winter tires does 110% better than my truck on icy spots from a stop vs my truck in 2WD. With the open rear diff it's a pain in the ass to get going, so I just recognize that situation and then click into 4HI, no prob.
    MaxMB, 15whtrd and Joe Dirt like this.
  28. Feb 14, 2019 at 10:28 AM
    r1-superstar
    DB
    UTAH
    :thumbsup: The Tundra is a truck and a lot different from an Audi. Enjoy your new ride!
  29. Feb 14, 2019 at 10:51 AM
    justfortun
    justfortun New Member
    James
    Boston
    2016 SR5
    Nothing beats better tires.
    but here's my $17 ass down winter helper
    Black Wolf and Joe Dirt like this.
  30. Feb 14, 2019 at 10:52 AM
    justfortun
    James
    Boston
    2016 SR5
    this also drives great in the snow
    TundraDude18, Black Wolf and Sas like this.
