Disappointed in Bedrug for Gen 3 Crewmax
Discussion in 'General Tundra Discussion' started by rebmo, Apr 26, 2020.
  1. Apr 26, 2020 at 3:35 PM
    rebmo
    rebmo [OP] 2020 Crewmax Limited 4wd Silver/Black
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    I went to install my bedrug today for my 2020 Crewmax. The Bedrug I ordered from Autoanything is for 07+ Shortbed. So I unpacked, unrolled the main bed section (also have the tailgate section) and put it in to see how it fits. At first I didn't think it looked right from the bed profile and it kind of fits. Now that I look at it I either was shipped the wrong one in the correctly labeled box, or I'm very disappointed in the cutout which does not even match the Crewmax bed.
    If anyone else has a bedrug in a 2020 Gen3 I'd appreciate your thoughts. This does not look like the right "bedrug" If it is I'm very disappointed in the short fit and odd trimming. I'd expect it to fit snuggly all the way around. If this is correct for a Tundra it's going back. IMG_0976.jpg IMG_0971.jpg IMG_0972.jpg IMG_0974.jpg IMG_0975.jpg
  2. Apr 26, 2020 at 3:54 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Send it back or call manufacturer Monday ...
  3. Apr 26, 2020 at 3:57 PM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Mine is tight all the way around.
  4. Apr 26, 2020 at 4:01 PM
    rebmo
    Rural SE Wisconsin
    Here's pics of the bed sections not covered. If this is intended it's a really cheapoInkedBedrug Pass rear 2 detail draw.jpg InkedBedrug Pass Front_rev1 draw.jpg InkedBedrug Driver Front_rev1 draw.jpg InkedBedrug pass rear_Rev draw.jpg InkedBedrug driver rear_rev1draw.jpg InkedBedrug Pass rear 2 detail draw.jpg InkedBedrug Driver Front_rev1 draw.jpg InkedBedrug pass rear_Rev draw.jpg InkedBedrug driver rear_rev1draw.jpg poor fitting (slides all over) bedmat. I'm hoping it's the wrong mat since it's such a poor fit. Just the look of it says poor quality IMO.
    BravoDeltaRomeo likes this.
  5. Apr 26, 2020 at 4:28 PM
    rebmo
    Rural SE Wisconsin
    Thanks all for the input. Appreciate knowing this is not the way Bedrug fits for others. I'll work with Autoanything and get it returned and possibly a replacement Monday when they open. I do like the "mat" material so hopefully they can send me one the is cut to match my outside bed floor perimeter. I'll have to check the fit on the tailgate piece (I have the separate tailgate section and bed section only). The tailgate section came in a different box. I just checked the fit on the tailgate section and it looks like a good fit. Maybe I got a Tacoma or Ford Bedrug or something?
  6. Apr 26, 2020 at 4:37 PM
    Did you reach out to Mike? @eccracer104 he works for www.autoanything.com and provides discounts to members.
    Ely010606 and Marty McFly like this.
  7. Apr 26, 2020 at 4:37 PM
    xJuice
    xJuice This guy...
    Josh
    DFW, TX
    '19 MGM DC SR5 4.6 TSS
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill, Remote Start, One-touch Auto Windows
    It says it's for a truck with drop in bed liner. You don't have a drop in. This is the discrepancy.
  8. Apr 26, 2020 at 4:39 PM
    Yohan11
    Yohan11 New Member
    2012 MGM
    The BY07SBD shows for 2nd gen with drop in liner on bedrugs website. Your model # should be BMY07SBS.
    rebmo[OP] likes this.
  9. Apr 26, 2020 at 4:42 PM
    rebmo
    Rural SE Wisconsin
    Autoanything advised this was the correct P/N for the spray-in bedliner for my 2020 crewmax. I specifically asked if it would fit with a spray-in bedliner not drop-in. I don't recall their specific reply but I thought they said this is the P/N for spray in and drop in bedliner. I agree this could be a discrepancy. I'll ask when I call tomorrow. Thanks for that P/N, hopefully I can get one cut to fit right. I do like the mat.
    PS I did my order over the phone for a special discount from Autoanything and they placed the order for my 2020 crewmax with spray in bedliner. I do see on Bedrug.com the P/N shipped is wrong and as advised is for the "drop in bedliner". That gives me hope then for a proper fitting Bedliner replacement.
    Just curious, is there a different mat for the tailgate also for my Crewmax, the P/N Autoanything provided was BMY07TG. This looks correct, but they also should have advised to order the BRZSPRAYON supplemental kit to attach this tailgate bedrug to a spray on bedliner tailgate. I'll be asking about that also.
    Thanks!
  10. Apr 26, 2020 at 4:45 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    If they let you keep it and wanna unload it. Ill take it! Let me know and we can work it out.
    Tundyfundy likes this.
  11. Apr 26, 2020 at 4:46 PM
    biebs96
    PA
    If they tell you to keep it, let me know. I have a drop in and would gladly take it off your hands ;)l
  12. Apr 26, 2020 at 4:51 PM
    Pudge
    CT
    Hey I was first :fingerscrossed:
  13. Apr 26, 2020 at 5:26 PM
    rebmo
    Rural SE Wisconsin
    Turns out autoanything doesn't offer the tailgate bedrug section supplemental kit P/N BRZSPRAYON for spray on bedliners as advised by bedrug.com. So Autoanything may not be aligned with the P/Ns needed? We'll see Monday.
    Tundyfundy and Pudge like this.
  14. Apr 26, 2020 at 5:27 PM
    Pudge
    CT
    Good luck man, I hope it works out.
    Tundyfundy and rebmo[QUOTED][OP] like this.
  15. Apr 26, 2020 at 5:36 PM
    biebs96
    PA
    damn missed by a minute!
    BravoDeltaRomeo and Tundyfundy like this.
  16. Apr 26, 2020 at 5:39 PM
    Jbehredt
    Westminster, CO
    Check out the XLT version if available. It’s got the material bridging the gap between the bed and gate. One piece. The only difference for spray on liner applications is the adhesion promoter wipes afaik.
  17. Apr 26, 2020 at 5:46 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    on it! haha calling third just to be safe
  18. Apr 27, 2020 at 7:37 AM
    rebmo
    Rural SE Wisconsin
    I worked it out with Autoanything today. They gave credit and covered FedEx return for the sent bedrug. Strangely on their website it only showed the drop in bedliner, bedrug, but I gave them the P/N for the Spray in Bedliner bedrug and they had to special order it. I also requested the kit for extra Velcro and cleaner for the tailgate mat install that Bedrug shows on their website. So I was able to get the correct parts but not the same discount since this was "special order". The spray in Bedliner mat is 3/4" versus 1/2" for drop in so that will better and the correct fit.
    My takeaway is if you order from Autoanything get the correct P/Ns from bedrug.com for your vehicle just to make sure you are getting the right thing. In this case the AA website did not show the spray in bedliner P/N or the tailgate mat kit that shows up on the bedrug website. A bit confusing but should get straightened out.
  19. Apr 27, 2020 at 7:43 AM
    Did you miss my post? Post #7
  20. Apr 27, 2020 at 8:06 AM
    rebmo
    Rural SE Wisconsin
    I did see it and tried to find a way to PM him. I was not able to PM him on my phone yesterday and placed a call to Autoanything this AM. It took a long time to get in touch service. They are buried right now with COVID19 activity. I did mention Mike and Tundras.com when working the discount and the guy I was working with said he'd have to go to the supervisor that he went to. They took care of me and the return but did find the website to be missing some things (2 P/Ns I needed).
    Thanks for all the help. Greatly appreciated.
  21. Apr 27, 2020 at 8:23 AM
    :hattip: @eccracer104
  22. Apr 27, 2020 at 8:36 AM
    rebmo
    Rural SE Wisconsin
    Thank you I did click that but the option to "start a conversation was grayed out yesterday" so wasn't sure if he had no PM capability. It shows you can PM now so??
    Again really appreciate all the help here.
  23. Apr 27, 2020 at 9:07 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Mine fits perfect in a 17 CM. That is not the right rug.
  24. Apr 27, 2020 at 9:49 AM
    :hattip:
    rebmo[QUOTED][OP] likes this.
  25. May 1, 2020 at 3:21 PM
    rebmo
    Rural SE Wisconsin
    The new bedrug came today from Autoanything and it's great even compared to the last material. It's 3/4" thick (for the spray in BL version) versus 1/2" for the previously sent "drop in BL version". For some reason AA only lists the drop in BL version on the website and I explained that to the rep who took care of me. I did not use the website to order but did it on the phone to take care of a special discount offered. The spray in bedliner version was a "special order" per the rep at AA so I was not able to get nearly as good of discount as on the original order. AA took care of me but just disappointed in not having the same discount applied to the new order. The Bedmat is excellent and fits perfectly. Again, the thicker mat is even nicer for the spray in BL. Have it in the bed no "flattening out" and will install the Velcro when it warms up over 65F possibly this weekend.
    Thanks for references and help on this.
    xJuice likes this.
