Disappearing oil
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mgid, Apr 14, 2023.
  1. Apr 14, 2023 at 10:28 PM
    Mgid
    Mgid [OP] New Member
    2017 tundra
    Bought my 2017 TRD pro new. No engine mods. Added airbags for pulling power. Saw a thread on here from 2020 about a guy losing oil and toyota doing an oil consumption test. Signed up for forum and lost the thread. I'm at 67k miles. Oil gets changed every 5k. Just checked the oil before a 700mile trip and we're 2 qts low. No evidence of leak. Not the first time. The other time, we attributed it oil cap and bought new. Anyone else have this problem??
    94537 likes this.
  2. Apr 14, 2023 at 10:53 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    2 quarts low in how long? If its not leaking then it's burning. Could be piston rings. You get any exhaust smoke? How's your spark plugs look? How often do you change oil, time wise? Do you do alot of short trips?
    94537 likes this.
  3. Apr 25, 2023 at 9:59 PM
    Mgid
    2017 tundra
    2 quartz low in less than a few thousand miles. Oil gets changed every 5k. Truck doesnt smoke. Truck goes long and short trips. I drove it 2000k miles in 36 hrs and no change in oil level. It's sporadic. I checked it because I was going far and it was low. Truck only has about 60k on it. Have never changed the plugs.
  4. Apr 26, 2023 at 4:30 AM
    MadMaxCanon
    How long does it take you to go 5k miles? How are you checking for leaks? If it's oil stains on the ground, then check your cam towers for leaks against the block
  5. Apr 30, 2023 at 8:42 PM
    WalnutWest
    WalnutWest New Member
    2019 LIMITED CREWMAX MGM
    Wipe your finger around the inside of your tail pipe after you’ve gotten the truck to operating temp for at least 20 minutes… depending on how much oil is burning you might just pull out a wet finger…
    Mr Badwrench likes this.
  6. Apr 30, 2023 at 9:02 PM
    Hambone1
    Hambone1 New Member
    Blaine
    2015 tundr limited
    Not much yet
    Change your pcv valve
    Blueknights75 likes this.
  7. May 1, 2023 at 2:56 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    In my previous vehicle (subaru) it burned a quart every 1000 miles by the time I traded it in with 60,000 miles. Ever since that vehicle I vowed to never use 0w20 in anything ever again. Been using 5w30 or higher in my Tundra since new. 0w20 has caused oil consumption in many engines and once it starts it will only get worse.
    2mchfun likes this.
  8. May 1, 2023 at 6:02 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Did you go to a thicker oil or stay with 0w20 on the Subaru?
    Reason I’m asking is my truck just burned/consumed 1.5 qts over 5000 miles on 0w20. I just switched to 5w30 and am hopeful the consumption stops.
  9. May 1, 2023 at 6:26 PM
    Joe333x
    Joe333x Member
    Boston
    I never actually did switch with the Subaru.
    ZPhilip[QUOTED] likes this.
  10. May 1, 2023 at 7:41 PM
    2WD
    2WD New Member
    21 Army Green CM SR5 TRD Off Road
    Using 0w20 in two vehicles including the Tundra - combined 80K miles. Zero consumption and I check oil in both vehicles once a week.
    Metro14536 likes this.
  11. May 1, 2023 at 7:49 PM
    Mr Badwrench
    Mr Badwrench New Member
    :rimshot:
    This could do it. I assume newer vehicles use the same concept for crank case ventilation?
    el_conquistador likes this.
  12. May 1, 2023 at 9:05 PM
    Blueknights75
    Ron
    Clayton, NC
    X3 on changing out that PCV valve. It definitely can’t hurt but that is quite a bit of oil consumption.
    Y0TA PR0 likes this.
  13. May 2, 2023 at 3:01 AM
    2mchfun
    Are you sure it was filled and checked under identical conditions, such as maybe the slope of the parking area, the new filter was filled both times, the stick was properly seated, etc. I use a pcv catch can on mine and I can tell you it's surprising to see how much ends up going out the tailpipe on a truck not equipped. If you install a JLT catch can it will help you narrow down the issue and improve combustion, etc. Sort of depends on how long you intend to keep the truck to determine the value of the system. Good luck! When you get it figured out, post up for the next person.
