Disabling Miscellaneous Safety 'Nannies'
Discussion in '2nd Gen Tundras (2007-2013)' started by kenomouth64, Apr 8, 2017.
  1. Apr 8, 2017 at 7:37 PM
    kenomouth64
    kenomouth64 [OP] New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    So there are several safety nannies that drive me "up the wall". The Safety Belt alarm and the "doors not opening while moving". I am hoping that someone can offer some solutions to these problems (Yes, I consider them to be problems).
    I have looked into the safety belt alarm and how to disable it, it seems that you cannot "officially" disable it. However from what I have found the best method for this is just to track down the speaker and cut the wires to it. Does anyone have a simpler solution, which includes the following capabilities:
    Ability to "buckle up" without any additional hassle
    No warning Chime
    Does not disable any additional features (lights, stereo speakers, seats, etc)
    As to the "door not opening while moving" issue, I feel as though this is a Safety issue and not a safety feature. I would like to have the capability to abandon ship for safety reasons. I am hoping that this is just a child lock protection nanny that can be disabled, if it is not, perhaps someone has some insight as to how it can be disabled.
    Any help is appreciated, as these issues are becoming bothersome.
  2. Apr 8, 2017 at 8:19 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    i asked the dealer to get rid of the obnoxious seat belt reminder when i was there last week.
    I was told "we aren't allowed to.....but i'll do it anyway." Now i don't have to listen to it anymore, and that includes passenger seat too. That's the one that REALLY annoys me. I hate to tell people to buckle up if they don't want to!
    FirstGenTundra likes this.
  3. Apr 8, 2017 at 8:38 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Ask your dealer like Almaboy. Usually telling them something like you work on a ranch works pretty well. If they don't do it for you, get techstream and do it yourself.
    NewImprovedRon likes this.
  4. Apr 8, 2017 at 8:40 PM
    Eclipsed & Floating
    Voluptuous Whitey
    yeah, i had to wear my suspenders and roll around in cow patties before i went in. Without these additions to my wardrobe i might not have played the ranch hand very well and been turned down.
    Really though, all i had to do was ask when i was in for my 5000 service
  5. Apr 8, 2017 at 8:41 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  6. Apr 9, 2017 at 2:38 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    When I bought my 2010, I made a "Customized Feature List" for the dealer. Found out while reading through the Owner's Manual about all the changes that can be made. Seatbelt chimes were first to go. A couple other things I had 'em do to interior lights, dash light intensity-timing and such. Doors lock/unlock with one push on the remote. I unhooked the White connector under the steering wheel surround/cover so the "key in switch" nanny is gone. Truck came through with just a 'chime' when locking-unlocking. If it blasted the horn like many do, that would've went too!
  7. Apr 9, 2017 at 4:52 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I keep a pair of these in the center console for when I wheel. Cheap and easy solution. I also have the BD tuner which allows you to turn off all that crap
    http://www.ebay.com/itm/281994178367
    GNTundra, sawzalot and TNTundra08 like this.
  8. Apr 9, 2017 at 5:26 AM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    I used my autel maxisys scanner to turn off my seat belt reminder, also adjusted some other settings. I think you can use techstream to do this also
  9. Apr 9, 2017 at 5:34 AM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    On the second gen
    - remove spring
    On the third gen tundra
    - remove attachment bolt
    - split case
    - remove the small spring in the white guide
    - secure the white plastic guide down/away from the buckle insertion. (Foam shooting plugs work nicely)
    - cut as much of the white plastic flat nipple as you can with dikes (in can get in the way)
    - I added small pieces of Gorilla tape to ensure white plastic spring carrier remained in the down position.
    az1441 likes this.
  10. Apr 9, 2017 at 5:35 AM
    R0CKETMAN
    NGAMTNS
    Now how can I silence the beep when I use remote to lock/unlock doors?
  11. Apr 9, 2017 at 5:48 AM
    CMB
    CMB New Member
    Cecil County MD.
    Yep, Techstream is what the Dealer used on mine. I included everything I needed done for the initial free first time "Feature Customization".
  12. Apr 9, 2017 at 5:55 AM
    CMB
    CMB New Member
    Cecil County MD.
    Can't answer your question but count your blessings. You could be asking about the obnoxious :censored: horn blasts the "big 3" use. As for me, I'm fine with the lock/unlock beep my 2010 has. Did Toyota change this in the newer ones?
  13. Apr 9, 2017 at 6:12 AM
    sawzalot
    sawzalot New Member
    14' Tundra D Cab 4x4 4.6 L
    Tonneau Cover
    I just ordered a pair of these , nice addition at a minimal cost , if only everything could be so inexpensive lol.
    boardude[QUOTED] likes this.
  14. Apr 9, 2017 at 6:15 AM
    sawzalot
    sawzalot New Member
    Tonneau Cover
    My 2014 DC just makes a clicking noise , very minimal , sometimes I don't even hear it. I guess it could be disabled from previous owner , I bought with just a few thousand miles on her.
  15. Apr 9, 2017 at 6:50 AM
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
    In my 2008 Tacoma there was a sequence to disable the seatbelt chime by plugging/unplugging belt, key in ACC, etc. Nothing like that on the Tundras??
  16. Apr 9, 2017 at 7:06 AM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Go to your dealer, Techstream can do that, and I can't see any reason the dealer would tell you that they can't do it.(no safety reason, etc.)
  17. Apr 9, 2017 at 7:11 AM
    Tundra Fan
    Toby
    As far as the door not opening while moving, mine locks the doors when I shift out of park because I set it to, I've never even tried opening after that so I didn't know it wouldn't let you.
  18. Apr 9, 2017 at 7:39 AM
    CMB
    CMB New Member
    Cecil County MD.
    Not to my knowledge. If you get time, run through the instructions for those who may give it a try.
  19. Apr 10, 2017 at 8:27 AM
    BigCountry
    BigCountry New Member
    Garrett
    Edmond, ok. (Arkadelphia, Arkansas, school)
    2009 5.7L flex fuel, 4wd, sr5.
    Leveling kit, 20" hostage fuel rims, mangmum flow dual pipe, and bull guard.
    Is there a way to disable that long beep when you try and lock the truck with your remote while one of the doors is open? When I drove my 2002 Tacoma I got used to hitting the lock button as soon as I opened my door or as soon as everyone had there door open so I don't have to worry about doing it with my clicker. Any thoughts?
    AggiePhil likes this.
  20. Apr 10, 2017 at 9:19 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    My dealer turned my seat belt alarm off without any problems, all I had to do was ask. I've heard of dealers in urban areas being less willing to do it, but it's worth a shot.
  21. Apr 10, 2017 at 9:30 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    My dealer disabled the seatbelt chime. It can be done in the software
  22. Apr 10, 2017 at 3:19 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think that I saw that in TechStream.
  23. Apr 10, 2017 at 4:59 PM
    BigCountry
    Garrett
    What exactly is TechStream?
  24. Apr 10, 2017 at 5:04 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Toyotas software
    Wynnded likes this.
  25. Apr 10, 2017 at 5:27 PM
    BigCountry
    Garrett
    So how does one get into toyotas software to change that stuff
  26. Apr 10, 2017 at 10:10 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It's Toyota's proprietary software that's used to change some of the settings in various ECUs in their vehicles. There are pirated copies around, it requires a special cable that most get via a slow boat from China. Then it usually necessitates some laptop shenanigans to get running.
  27. Apr 11, 2017 at 7:52 AM
    BigCountry
    Garrett
    I'm sure, my brother had a Poniac G5 and I'm not sure what he did but he bought something that was like $15 that plugged into his car and sent the cars information to a tablet her kept in the car. From there I showed all the gages and he could rest maintanence lights when they were tripped and would turn off even when there was nothing wrong with the car. I'd imagine there's something like that out there for Toyota.
  28. Apr 11, 2017 at 7:55 AM
    csuviper
    Broomfield, CO
    I got a set of those too. They are actually of good quality. Use them when my dog lays in the front seat or when I put my heavy laptop bag in the front seat.
  29. Apr 11, 2017 at 7:56 AM
    csuviper
    Broomfield, CO
  30. Apr 11, 2017 at 7:57 AM
    BigCountry
    Garrett
    Such a hot topic :popcorn:
