disable touch to unlock sensor
Discussion in '3rd Gen Tundras (2022+)' started by mc141, Mar 19, 2025.
  1. Mar 19, 2025 at 2:58 PM
    mc141
    mc141 [OP] New Member
    2023 tundra sr5 oiffroad
    any way to disable the touch sensor on the door handles ?? we had a car across street get stolen the other night. so i want to ramp up the security on my 23 tundra already ordered shock sensor and siren for my fortin remote start. thinking about the air pressure sensor they make for car alarms but im iffy on that one during wind storms
  2. Mar 19, 2025 at 3:58 PM
    smileytn1
    smileytn1 New Member
    Have you put key fob into battery saver mode and put it in a faraday shield case because fob is like an elt on a plane always spitting out a signal and nothing will work
  3. Mar 19, 2025 at 4:01 PM
    mc141
    Yeah was looking for a more permanent solution i know my fige and kids wont put remote ack to sleep
  4. Mar 19, 2025 at 4:15 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Disable key fob, hidden kill switch, glass break sensor, steering lock, GPS tracking device like Trak4. Clowns in the UK can now steel Rav4's by externally accessing canbus through a headlight harness
  5. Mar 19, 2025 at 4:37 PM
    mc141
    the fortin evo one has a kill switch option in it i just dont know how to wire it to the truck and i cant seem to find any thing on it. i should email 41.22 and see if it cvan be wired into there kill switch releay system
  6. Mar 19, 2025 at 4:53 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    It's getting difficult these days, seems like the easiest approach is to steal signal from key fob (turn key fob off) or break a window (glass break sensor) and get inside and reprogram everything.
    Airtags (unless you do sound cut hack) are kinda of worthless if it's going to notify the theif.
    I think best option these days is hidden kill switch, subscription based well hidden tracker, or old fashioned steering lock. However, if prepared ... they will just cut a chunk out of steering wheel to remove lock.
