Disable Tailgate Down Warning
Discussion in '3rd Gen Tundras (2022+)' started by Wtundra2023, Nov 25, 2024.
  1. Nov 25, 2024 at 5:38 PM
    Wtundra2023
    Wtundra2023 [OP] Bad Weld Aficionado
    2023 Limited Tundra, 2014 Limited Sequoia
    Trying to figure put how to disable the tailgate down warning when I haul something longer than the bed. Looked in the manual and couldn't find anything and carista doesn't have anything for it.
    I am hoping some here knows how to do it.
  2. Nov 25, 2024 at 6:04 PM
    Hella Krusty
    Hella Krusty New Member
    Doesn't it just mute itself after a period? I have driven with mine down and all I got is the little picture on the dash
  3. Nov 25, 2024 at 6:36 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    You can turn it off in the dash menu settings. It's in there somewhere. I forget the exact sequence, but I did turn mine off. Not the big screen, but the left side dash menu.
  4. Nov 26, 2024 at 5:32 AM
    Wtundra2023
    It does turn off after a bit but its very insistent and annoying while its on.
    I will dig a bit deeper and see if I can find it. I haven't had much luck so far.
    Thank you both for your replies.
  5. Nov 26, 2024 at 6:27 AM
    nodak67
    nodak67 New Member
    JR
    at least you cant turn off the warning buzzer when you hood is not latched :)
    driving down the road at 75mph and the hood unlatches but is still secured though.
  6. Nov 26, 2024 at 6:31 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    If I remember correctly just push the little metal latch in tailgate where it would latch to the tailgate pin and it will think its closed and no warning will be on the dash. Basically just push the little metal mechanism that latches onto the gate pin that keeps the gate closed and you've "Tricked it into thinking its closed". Pretty sure that worked last time I hauled something with the tailgate down.
