Disable LED DRL on 2016 1794
Discussion in '2.5 Gen Tundras (2014-2021)' started by CaLan87, Feb 11, 2023.
  1. Feb 11, 2023 at 5:45 PM
    CaLan87
    CaLan87 [OP] New Member
    Cody
    2016 Tundra 1794
    Ive looked all thru this site and everything ive found so far is how to disable the amber DRLs. Anyone have any idea how to disable the LED strip DRL on the bottom of the headlight?
  2. Feb 11, 2023 at 9:30 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    You cant just shut them off? My 2019 has the LED strip around the headlight but only if i put the switch in the off position they are not on. Maybe there is an option on the dash or head unit? My subaru had a DRL wire on the lights that could be unplugged.
  3. Feb 12, 2023 at 12:01 AM
    CaLan87
    Cody
    2016 Tundra 1794
    Unfortunately not. I’ve read about exploiting a bypass with pushing the e-brake pedal one click, but I guess that was corrected in 2016 and they stay on unless the pedal is actually engaging the brakes.
  4. Feb 12, 2023 at 2:21 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    On my dads 2014 1794 you could pull a fuse, then the DRL would only come on if you rotated the headlight stalk one click, the next click would then turn on the lowbeams.
    I think the fuse might’ve been labeled DRL, and it was in the engine bay fuse box, not the cabin fuse box
    HulkSmurf14 likes this.
  5. Feb 13, 2023 at 5:44 AM
    CaLan87
    Cody
    2016 Tundra 1794
    ok, thanks i will check that out later today and give an update.
    joseph_womack likes this.
  6. Feb 13, 2023 at 8:59 PM
    joseph_womack
    Joe
    Louisiana
    Any luck?
  7. Feb 14, 2023 at 3:40 AM
    CaLan87
    Cody
    2016 Tundra 1794
    Hadnt been able to check just yet. Was raining after work. Hopefully it will stop soon :crapstorm:
  8. Feb 15, 2023 at 3:57 AM
    CaLan87
    Cody
    2016 Tundra 1794
    I was able to check today. There IS a fuse specifically for the led DRL's... It's actually funny there's a fuse just for those. While headlights are off, no LED DRLs. When headlights are on, they're on. Kind of weird but thanks for the info. I thought would be much more difficult than that.
    joseph_womack and Joe333x like this.
