Disable bips for everything?
Discussion in 'Audio & Video' started by Jmn, Jan 12, 2021.
  1. Jan 12, 2021 at 8:26 PM
    Jmn
    Jmn [OP] New Member
    Hi there,
    I can't stand all these bips when door is open, accessory in, key in, seat belt etc.
    Do we have an easy way to tweak this?
    I tried to look for "sound disable" without success.
    Thanks!
  2. Jan 12, 2021 at 8:37 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    try Techstream. You can lower key, doors chime. Lower or silence seat belt reminder.
    Jmn[OP] likes this.
  3. Jan 21, 2021 at 8:34 PM
    Jmn
    Jmn [OP] New Member
    Hey Brandon,
    Ordered the cable (Amazon) and tried Techstream v15. I didn't find any option to lower doors chime.
    I found key and seat belt though.
    Could it be due to my cable?
    I tried on a 2021 TRD Pro
  4. Jan 21, 2021 at 9:14 PM
    BrandonL812
    Brandon
    Look like you were able to connect to the truck just fine if you can do the key and seat belt.
    Try looking under the customizing tab. I cant remember exactly which. Main Body>>>Customizing.. play around in it. If i fond it, I'll come back and post.
    Jmn[OP] likes this.
  5. Jan 21, 2021 at 9:16 PM
    Jmn
    Jmn [OP] New Member
    Which Techstream version do you use?
    I ll try again but really thought I went through every customizable stuff already.
    Will give another shot.
    Thank you!
  6. Jan 22, 2021 at 2:20 AM
    Maadcaap
    Maadcaap White Tundys
    Rancho Cucamonga, Ca.
    2019 Trd Pro
    275/70/18 KO2
    can you post a link to the cable you bought./
  7. Jan 22, 2021 at 10:24 AM
    Jmn
    Jmn [OP] New Member
  8. Jan 22, 2021 at 12:33 PM
    BrandonL812
    Brandon
    I bought mine over 5 yrs ago on ebay. I cant remember from which seller.
  9. Jan 22, 2021 at 7:14 PM
    BrandonL812
    Brandon
    The only thing i can find is under the Warning tab. These are what i have it wet at. I guess you cant turn off some of the things you wanted.
    Jmn[OP] likes this.
  10. Jan 23, 2021 at 8:43 AM
    Jmn
    Jmn [OP] New Member
    No worries!
    Thanks for checking again already!
