Disable AC in Defrost Mode
Discussion in '1st Gen Tundras (2000-2006)' started by tvpierce, Dec 12, 2019.
  1. Dec 12, 2019 at 12:50 PM
    tvpierce
    tvpierce [OP] Formerly New Member
    Maine
    At times I'd like to have air blowing on the windshield, but not have the AC compressor kick on.
    I was able to mod my 2002 4Runner to do this, and I see online tutorials for doing it on a Tacoma. Anyone done it on Tundra?
    Aerindel, Bubbles and rock climber like this.
  2. Dec 12, 2019 at 2:08 PM
    Aerindel
    Aerindel New Member
    Montana
    No, but I'm interested in this as well. If i have a little time today I will hit the wiring diagrams and see if i can find out.
  3. Dec 12, 2019 at 2:18 PM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    Me too
  4. Dec 12, 2019 at 5:01 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    Unplug the connector at the compressor.
  5. Dec 12, 2019 at 5:06 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm lost. Pretty sure I can blow air on my windshield without the compressor being on.
  6. Dec 12, 2019 at 5:19 PM
    Blue Thunder
    Washington
    I'm curious...what will this gain you?
  7. Dec 12, 2019 at 5:20 PM
    Aerindel
    Aerindel New Member
    Montana
    You can't. The ac automatically comes on any time you are on defrost or defrost mix. It does help a lot with defrosting, turning the AC used to be a 'trick' with cars to clear the windshield faster...but the tundra does it without asking.
    PCJ likes this.
  8. Dec 12, 2019 at 5:22 PM
    Aerindel
    Aerindel New Member
    Montana
    That would kill all AC, we just want to kill it automatically coming on with the defrost setting.
    A lower idle speed in winter. Less wear and tear on the compressor. Probably a little gasoline.
    wheelerc likes this.
  9. Dec 12, 2019 at 5:30 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    But the compressor has its own stand alone button. If it's off I didn't think the compressor would kick on.
    Maybe I'm not understanding what you guys are calling defrost.
  10. Dec 12, 2019 at 5:51 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Nope. In defrost it'll run regardless of the independent A/C switch. I don't think any vehicle made in the last 20 years doesn't do the same.
    CmdrDaniels and rockmup like this.
  11. Dec 12, 2019 at 6:00 PM
    Blue Thunder
    Washington
    Yeah, defrost is tied into the compressor to dehumidify the air. It greatly improves the defrost capability.
    CmdrDaniels likes this.
  12. Dec 12, 2019 at 6:02 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    So by turning the vents to blow on the windshield my compressor automatically kicks on? I never noticed. Typically hear the change in RPM.
    In other vehicles I've owned the light for the AC would kick on automatically and wouldn't allow you to turn it off. The tundra doesn't do that. I learn something new here everyday.
  13. Dec 12, 2019 at 6:28 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Are you guys talking about the defrost button on some consoles (sorta bottom right button)?
    I don’t have that button, but if I just turn the selector knob to either defrost position and have the fan on my a/c doesn’t come on, unless recirculate is on, then a/c comes on.
    Most vehicles I’ve had run the a/c if recirculate is on.
    At least that’s what I’ve observed, haven’t double checked since seeing this thread, will check tomorrow... maybe I just didn’t notice?
  14. Dec 12, 2019 at 6:33 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    That's what I thought too. But they are claiming the compressor comes on when you move the vent flow to windshield, even though the AC button isn't pushed.
    Aerindel likes this.
  15. Dec 12, 2019 at 6:43 PM
    Aerindel
    Aerindel New Member
    Montana
    Nope, we are talking about the vent position. Set to defrost or defrost/floor mix, the AC compressor will cycle on and off automatically with no way to turn it off. I bought my truck in the winter and I first thought it had an engine problem because at idle every 30 seconds or so the the engine RPM would surge slightly, but then I watched it with the hood up and figured out what was happening.
    KarmaKannon likes this.
  16. Dec 12, 2019 at 6:43 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I can't help but notice my ac comes on when I use defrost because it plays with my idle from time to time sitting at stop lights. It will idle down slowly and then jump up a bit and if my foot isn't firmly planted on the brake it will do a slight lunge forward. Very annoying.
  17. Dec 12, 2019 at 6:47 PM
    Aerindel
    Aerindel New Member
    Montana
    Yes. That exactly.
    Its annoying too because during the winter I basically set the vent on def/floor mix and never change it, but I really don't feel that I need AC all the time. My old truck didn't even have AC and vent was always enough once the engine was warm.
    15whtrd likes this.
  18. Dec 12, 2019 at 6:55 PM
    KarmaKannon
    Utah
    Some junk
    Yeah I do the same. If I put it all on the floor for some reason my face gets hot and my feet get cold. If I'm using def/ floor mix it's about right. Don't get me started on our crazy Toyota vents. Freaking rear vents blow cold in the winter and warm in the summer. What's the point of that? Save money and throw it out the back of the console. I might have to do that mod one day.
  19. Dec 12, 2019 at 7:02 PM
    Aerindel
    Aerindel New Member
    Montana
    For what its worth....
    You will see that there are two different wires for the AC clutch, I wonder if one of them happens to be the defrost override....
    bmf4069 likes this.
  20. Dec 13, 2019 at 3:15 AM
    foxtrapper
    foxtrapper New Member
    2003 SR5
    Unplug the electrical connector on the vent position control. I think that's all you need to do.
    CassND and Aerindel like this.
  21. Dec 13, 2019 at 4:13 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Chungdra95, chrisb, SouthPaw and 8 others like this.
  22. Dec 13, 2019 at 4:58 AM
    tvpierce
    Maine
    That's what I'm talking about!
    Your Google-fu is strong Bubba! I searched before I started this thread, but came up dry.
    Thanks!
    BubbaW[QUOTED] and GODZILLA like this.
  23. Dec 13, 2019 at 5:11 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Thanks but that is one of many links I have saved from tundrasoultions from before I found the Truck Gang site :)
    Now that I have the cluster still off from yesterday in working on cig light, may look at trying that suggestion even tho this issue does not bother me giving our environment and lack of not using the F/DEF position very often.
  24. Dec 13, 2019 at 5:50 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I tested this morning and you guys were right. I had never noticed the compressor kicking on before when moving the vent to windshield. That's a bummer.
    KarmaKannon and FrenchToasty like this.
  25. Dec 13, 2019 at 6:07 AM
    Professional Hand Model
    Hand Protectors
    I can see the argument for a disable mod for some, but once its disabled then its not there when you need it. Its nice having the defrost mode direct blast right on the shield vs using reg A/C mode to clear the glass which takes much longer.
    Also, I like the defrost option during those St Bart summer months. Keeps the frontal air action moving instead of direct out of main vents blow.
    Before fixing all my interior cab water leaks I would use defrost mode more often due to introduced humidity. Now its almost like Arizona inside.
    One last tip: Its good to run your A/C in the winter on an occasional basis. Reason is that the freon has oils that need circulating to lubricate and condition the inner seals. Same thing with your home A/C system.
    bmf4069 likes this.
  26. Dec 13, 2019 at 6:22 AM
    foxtrapper
    2003 SR5
    Press the A/C button and it will re-engage the air conditioning, blowing it once again onto the windshield.
    All disconnecting the switch does is prevent the a/c compressor from always being engaged when defrost is on. It doesn't prevent it from ever being engaged when the defroster is selected.
  27. Dec 13, 2019 at 6:41 AM
    Hand Protectors
    I gotcha.
  28. Dec 13, 2019 at 3:56 PM
    Hand Protectors
    But will the ‘A/C button on light’ illuminate when the dial is switched to ‘defrost’? Post mod?
    Today was the perfect day for me for the defrost option in our trucks. Rainy with wet shoes and clothes along with 2 passengers fogging things up, the dial was turned to defrost all day with the temp dial on medium heat. Very comfy.
    Right now the A/C button does not light up when in defrost (dialed). You can make the A/C light up if you push the button though.
    Just a little nuance.
  29. Dec 13, 2019 at 6:15 PM
    Aerindel
    Aerindel New Member
    Montana
    Indeed. It works well. We just want control over it, especially in places where that is the climate control setting for nine months of the year.
    I will disconnect the dial switch wires tonight and should know right away if it has any effect on normal AC operation.
  30. Dec 13, 2019 at 9:32 PM
    PenderBen
    2003 Tundra AC 4x4
    I too ‘tested’ this today, just tried switching it on and off while parked at idle, and it did change my idle, which is presumably the compressor kicking on (I couldn’t hear the compressor or feel cold air, since the air was already cold).
    I guess if it didn’t bother me before it won’t now.
    Other than maybe dragging milage down a little (maybe?), it does seem to function well for clearing the windshield in my wet truck, and should help maintain the a/c.
    Funny thing is, I would never use my a/c otherwise, I never need it in summer.
    This post is of no help to the op, but thanks for teaching me something new about my truck :)
