Dirty Deeds 10" exhaust review
Discussion in '2.5 Gen Tundras (2014-2021)' started by DublR, Nov 14, 2020.
  1. Nov 14, 2020 at 6:25 PM
    DublR
    DublR [OP] New Member
    2016 TSS
    Just finished my first cruise after installing the 10" Dirty Deeds Exhaust.
    1st thing, the video I will post tomorrow absolutely does NOT do justice to the exhaust note. I went with the 10 vs the 8 because I pull horses sometimes.
    2nd. It wasn't hard to install, toughest part was getting the hangers loose on the original exhaust. I hit the bolts with PB blaster the night before and they came off pretty easily. But the rubber grommets holding the hangers are complete assholes!!! The new system went in in about 15 minutes once I got the old one out. You will need someone to hold the exhaust tip in place while you tighten the exhaust pipe to the system, so you get the correct angle at the rear exit. Again Keith could not have been nicer, and I would definitely recommend one of these systems to anyone wanting to upgrade their exhaust. The deep growl will absolutely put a grin on your face, and there is almost no noticeable drone at cruising speed inside the truck, and I did NOT install the resonater, it doesn't need it IMO.
    Should have gone with the 8" and bought ear muffs for the horses!!!
    Trusty Rusty, MTRock, Rica25 and 5 others like this.
  2. Nov 15, 2020 at 4:09 AM
    Huckwheat
    Huckwheat New Member
    Scott
    Adirondacks
    2025 MGM Platinum Hybrid TRD
    Keith is a good guy, I bought a few things from him back in '15. Went out of his way for me with customer service.
    Psyched for you on your exhaust!
  3. Nov 15, 2020 at 4:25 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    I was probably an "early" 10" exhaust customer of Keith's. Several years and 84,000 miles later; no regrets!
  4. Nov 15, 2020 at 6:27 AM
    DublR
    2016 TSS
    Yep....got up this morning, went to the back door, hit the remote sequence, and Holy smokes. man this thing sounds knarly, like you just poked a 700lb Cat.. I think we are headed out for a little run thru the back roads of TN / KY line.....Right after I wake up Momma!!!
    MTRock, Rica25 and Hightide like this.
  5. Nov 15, 2020 at 6:55 AM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    Love my BA muffler. 8” . Two years, no regrets. Love yours. D
    DublR[OP], MTRock and Rica25 like this.
