Diode Dynamics SS3 SAE MAX / SS42 Stealth Combo Lightbar Review
Discussion in 'Lighting' started by burnurass, Jan 28, 2021.
  1. Jan 28, 2021 at 6:27 AM
    burnurass
    burnurass [OP] New Member
    Jeff
    2022 Lunar Rock Tundra Limited with TRD Off-Road
    New to Tundras, but had a 4runner for 5 years and 168,000 miles previously that was just traded in for an insane resale. I LOVE TOYOTA TRUCKS!
    On my 4runner, I had the Diode Dynamics SS3 SAE PRO fog lights in both white and yellow and prefer the yellow. Near the end of ownership, I did the Morimoto XB GEN2 Headlights on it too.
    I chose a Tundra SR5 CrewMax with the TRD Off road package, Convenience Package, and the SR5 Upgrade package. I wanted the OEM LED Headlights/Foglights, parking sensors/blind spot monitor, and the Auto Climate Control as well as the Bilstein Shocks.
    Stock Headlights are actually pretty good and pretty happy with them. LED fogs left something to be desired as I was used to the Diode Dynamics SS3 Fog lights performance.
    Stock Headlight
    Stock LED Highbeams
    With the Fogs on
    You can see the SAE fogs do have a cutoff:
    Spread of the fogs:
    Photo's at Lightwerkz
    Everything on!
    Lowbeams/Fogs on
    Highbeams
    Lightbar ON/highbeams were actually on (look at instrument panel)
    Video of them in action and how it translate into real life
    https://www.youtube.com/watch?v=RLx2Rhx5bmI
    Diode Dynamics SS3 SAE MAX in Yellow for Toyota
    https://lightwerkz.net/products/sta...-light-kit-toyota?_pos=1&_sid=2b6382610&_ss=r
    Diode Dynamics SS42 with Tundra Brackets
    https://lightwerkz.net/products/tun...es-diode-dynamics?_pos=7&_sid=1276cdaac&_ss=r
    Let me know if you have any questions on the install or the lights as I've played around with them a lot with the 4runner and now the Tundra!
    Looking forward to sharing some more and learning with my fellow Tundra members
  2. Jan 28, 2021 at 6:50 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Lookin good! Too bad you didn't get them from me, but you can't beat getting them installed at a reputable place :thumbsup:
    I'll have the same setup in my new Tundy shortly as well!
    HulkSmurf14 likes this.
  3. Jan 28, 2021 at 6:56 AM
    burnurass
    Jeff
    Thanks! Lightwerkz is a little closer to me than you :) I like supporting a local small business especially when they do a Excellent Job!
    Are you going to do the Diode Dynamics driving lights in the grille too? I'm thinking it may be too much but maybe there is no such thing... :)
  4. Jan 28, 2021 at 9:14 AM
    memario1214
    Colton
    Missoula, MT
    NO SUCH THING.
    I likely won't be building anything into my primary grille as I will end up with ditch lights (likely SS3 Maxes), and likely an aftermarket bumper as well. I'm also going to shove a light bar in the upper part of the grille as well so I'll be pretty well set I think :rofl:
    burnurass[QUOTED][OP] likes this.
  5. Jan 29, 2021 at 8:09 AM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    Well that verifies it. I had my Max’s in and what I thought was low so I adjusted them up. Must have went to far. So now I have to take everything back apart. Just for a quick reference...are yours adjusted almost all the way down?
  6. Jan 29, 2021 at 8:20 AM
    burnurass
    Jeff
    Mine are adjusted all the way down.
    It's a bit deceiving in the Tundra because the Hood is blocking a lot of your view.
    The trick is to tighten it and while it's installed you can push it up and down. there is enough tension to hold it in place but also able to make the fine adjustments. Try just pushing it down first.
    One other thing to keep in mind is to have it positioned as far out as it can on the slot/bracket so you have more range of adjustment up/down. Mine is all the way out and down if that makes sense.
    bulldog93 likes this.
  7. Jan 29, 2021 at 10:29 AM
    memario1214
    Colton
    Missoula, MT
    Here's what proper aiming of those bad boys should look like :)
    That's weird that you say that. My recommendation to folks is always to start them somewhere midway on the sliding part of the bezel, and don't even bother tightening them down initially, just barely making contact. If you bring them all the way to the front your Up/Down modularity is limited due to impacting the bumper. I always start them midway, and then once I have found my ideal level point I'll slide them as far forward as I can to close up the gap.
    Just my .02 :thumbsup:
  8. Jan 29, 2021 at 12:04 PM
    AlrightAlrightAlright
    AlrightAlrightAlright New Member
    Northwest Arkansas
    2020 SSM DC 4x4 with SR5 Upgrade Package
    RetraxONE MX retractable bed cover TRD Rear sway bar Debadged FabFours Matrix front bumper Smittybilt 9,500# XRC winch Aries 30" light bar (internal bumper mount) Diode Dynamics SS3 3" SAE Fog and Driving lights ConsoleVault RhinoRack crossbars
    How did you set up switches in the cab? I have a similar light setup using Baja Designs’ stuff: SAE Ambers in shipment along with their Squadron Sport Spot beams. 30” light bar from Aries arrived yesterday. Was hoping to reuse the factory fog light light switch for the SAEs, then just get two aftermarket rockers for the Sports and Light bar. Need to do a few honey do’s before I can ask for a Switch Pro 9100.
  9. Jan 29, 2021 at 12:10 PM
    burnurass
    Jeff
    Fog lights are plugged into the stock fog light wiring so the switch works for that.
    Light bar I have run to the bottom of the center console hooked up to a switch. It comes with a switch, but I'm going to hook it up to an oem like switch. It's wired to be on anytime right now regardless of the vehicle being on or off.
  10. Jan 29, 2021 at 12:29 PM
    Juanjoolio007
    Oregon
    Oh yeah!! They are way high. Initially I had my truck parked at 20ft and had them lower then the headlights. I test drove it and thought they were low. Next day it was raining so I parked close to my garage door and adjusted them up. Went to work the next day and wasn’t impressed. It took three days for the rain and fog to clear before I realized yesterday just how high they are. Now I’ll have to take apart the fender liners and start over. At least I’m getting good at that part:rofl:.
    Thanks for the picture to @memario1214.
    memario1214[QUOTED] likes this.
  11. Jan 29, 2021 at 12:30 PM
    Northwest Arkansas
    Makes sense for the separate toggle. There’s a switch brand on here posted recently that looks really close to OEM; I was going to go that route but am trying to see what others have done. I thought I’d read in your post that you had two pairs of fog lights, sorry for the confusion! I’m trying to see if I can maybe do the light bar and the second (off-road, non-SAE) pair on one switch or if I have to do it with separate ones.
  12. Aug 16, 2021 at 5:17 PM
    tonynw318
    tonynw318 New Member
    Tony
    Oregon coast
    2020 silver sky SR5 crewmax
    I would love to hear about your 42” light bar. How’s it holding up? Do you find it bouncing on rough roads or washboard gravel roads? I saw another thread where a few people said they 42” bar sagged and bounced around. I love how it fills the whole space, but if it bounces around on logging roads, I don’t want to deal with that.
  13. Aug 16, 2021 at 5:21 PM
    memario1214
    Colton
    Missoula, MT
    @clarkritchie is the guy I am going to call in here for a review. He expressed concern about the same thing to me (and I sold him the kit), and we had to make a couple of adjustments. Wonder what his prognosis is now?
    I have installed a couple, and I did not experience bouncing with the setup, but others have.
    tonynw318[QUOTED] likes this.
  14. Aug 16, 2021 at 5:24 PM
    burnurass
    Jeff
    seems to be holding up.
    I re-did it with some lock washers and Loctite to prevent it from getting loose. so far so good!
  15. Aug 16, 2021 at 5:25 PM
    tonynw318
    Tony
    Oregon coast
    That’s good to hear. Did you do those things where the light bar attaches to the brackets? Do you drive much off road? Thanks for the response.
  16. Aug 16, 2021 at 5:26 PM
    tonynw318
    Tony
    Oregon coast
    That’s encouraging to hear. I wonder why a few people would.
  17. Aug 16, 2021 at 5:28 PM
    memario1214
    Colton
    Missoula, MT
    It's like there is some slop on some of the brackets' holes (or maybe the metal's a shade too thin) that allows it some vertical play. I'll let others with some additional first hand experience chime in, but I can tell ya if you do purchase one thru us and there's something wrong I'll make sure that you're happy before we part ways!
  18. Aug 16, 2021 at 5:31 PM
    How did you like the XB Leds in the 4R? One of the problems with the stock headlights on the 5th Gens is the sideways mounted projectors.
  19. Aug 16, 2021 at 6:35 PM
    burnurass
    Jeff
    They were a great improvement. lightwerkz did a comparo to the oem led lights too. Go check it out on their YouTube
    Tundra234[QUOTED] likes this.
  20. Aug 17, 2021 at 7:19 AM
    clarkritchie
    clarkritchie New Member
    I can confirm that the DD 42" stealth bar adds an impressive amount of light. But TBH I haven't used it extensively as it has been light to ~10 PM here lately.
    I had the pleasure of installing it three times. After the initial install, I couldn't reason out why it was loose, and so I removed and re-installed it. I mean it's only 3 bolts and a metal bracket on each side. That is when I found out the light bar itself was defective, which DD RMA'd, so then I got to install it a third time.
    Their bracket is just poorly designed, I'm not sure why -- perhaps the it needs to be thicker. So my bar is actually resting on the plastic of the bumper, which I don't love. I had initially shimmed it with some cardboard so that was centered, and the moment I pulled that out, it settled onto the plastic. Also, you can't reach the small Allen bolt that holds the light bar itself to the bracket when fully installed, so adjusting it means removing all six of those bolts again -- which is a hassle.
    My janky solution to the loose bracket was to slip a little 3M VHB tape underneath each side and it has been stable for me so far. I've got no clue if that will melt or burn with extended use. I haven't observed a lot of heat buildup but like I said, I have not used it extensively.
    Again, the amount of light it produces is impressive but I expected the bracket to hold it firmly centered in that opening, and it simply doesn't.
    FlipMonkey21 and tonynw318 like this.
  21. Aug 17, 2021 at 7:28 AM
    Northwest Arkansas
    For what it’s worth, I was impressed with the bracketing and mounting on the Aries 30” light bar, but you had to be careful not to overtighten.
  22. Aug 17, 2021 at 7:29 AM
    tonynw318
    Tony
    Oregon coast
    Thank you for the response. This is similar to what I’ve read elsewhere.
  23. Aug 18, 2021 at 7:31 AM
    infidel
    infidel New Member
    Jesse
    SE Wisconsin
    2016 Silver SR5 Crewmax
    Procomp 3/1 Method 307 18x9 +25 Falken Wildpeak AT3W 295/70r18
    Luckily I know a guy, my old shop teacher actually, owns a metal shop. When I get this bar I'm going to take it all to him and see what we can come up with.
    tonynw318 and clarkritchie like this.
  24. Aug 18, 2021 at 7:36 AM
    memario1214
    Colton
    Missoula, MT
    Let me know, would ya? We can either look to try to encourage DD to make a change if this is a recurring issue, OR if he can come up with something trick I may be able to work with him :notsure:. I'm going to install one on my Tundra this weekend and see what I think too. Installed a couple before as I said, but never noticed issues. Wonder if something changed in the bracket design... :monocle:
    Side note - Did you already order the kit? If not, I have them in stock and ready to roll.
    tonynw318 likes this.
  25. Aug 18, 2021 at 7:45 AM
    infidel
    infidel New Member
    Jesse
    SE Wisconsin
    I haven't yet, working on paying other things down at the moment, looking to the end of the year hopefully
  26. Aug 18, 2021 at 7:57 AM
    memario1214
    Colton
    Missoula, MT
    :thumbsup:
    One thing to note (and I am going to be putting together a "PSA" of sorts later today) is that DD's pricing is going up at the end of this month for many items. These kits would be part of it. I'll break down specifics for folks, but just something to take into consideration!
  27. Aug 18, 2021 at 8:22 AM
    FlipMonkey21
    FlipMonkey21 New Member
    Mark
    SoCal Glendale
    2019 Toyota Tundra 4X4 Sport
    2019 Toyota Tundra Crewman TRD Sport Kings 2.5 Front & Rear suspension Camburg UCA Method Wheels MR312 18X9 +18 Offset 5x150 matte black w/toyo open country RT 35x12.5R18 tires Toyo Open Country RT 35X12.50 R18LT 123Q 10 P.R TRD Front Sway Bar (Removed) TRD Rear Sway Bar ( Removed) Carven Cat-Back Kit (torque 65lbs to 70lbs of torque) Windows tint Bakflip MX4 Bed Cover TRD CAI NSV air compressor AJT Design chrome delete NSV Light Bar Diode Dynamics 42" light bar Diode Dynamics SS3 Max Pod CBI Full Skid Plate CBI Lower Control Arm Shield Sibi Built regear Revolution 5.29 Harrop rear lockers Rigd mega swing Wheel lock Deaver springs U-748 King 3x16 650 Coil springs
    mine is installed the same way even when pushing the bracket up the lightbar will rest on the bumper.
  28. Aug 18, 2021 at 10:13 AM
    infidel
    infidel New Member
    Jesse
    SE Wisconsin
    Like up a lot or a little bit?
  29. Aug 18, 2021 at 10:15 AM
    memario1214
    Colton
    Missoula, MT
    Plan on 5-10%
  30. Sep 13, 2021 at 6:26 PM
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    Any more on this? Did anyone come up with a good mounting solution to keep the bar from moving around? I have a DD 42” combo bar sitting and waiting for me to mount it….
