Diode Dynamics SS3 instal issue
Discussion in 'General Tundra Discussion' started by Quicksand4x4, Feb 9, 2021.
  1. Feb 9, 2021 at 12:09 PM
    Quicksand4x4
    Quicksand4x4 [OP] New Member
    2017 Quicksand Tundra Limited
    Building in process
    So I just installed a set of diode dynamics ss3 fogs and they were working great as I was testing them. However, when I went to flick on my brights the fogs shut off along with the brights. I initially thought I just blew a fuse but after checking I realized that was not the case... any ideas?
  2. Feb 9, 2021 at 12:45 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Fogs are supposed to turn off when brights are selected....that is how the factory wires everything up. So, need more info. Did you have factory fogs and just swapped these in with the same wiring or did your wire everything up yourself? Your truck has LED from factory or halogens?
    For reference- https://www.youtube.com/watch?v=3LG1SxoMpb8
    14burrito and Oey12 like this.
  3. Feb 9, 2021 at 1:29 PM
    abominable_tundra
    abominable_tundra New Member
    Elkasuspension 2-3” adjustable reservoir shocks, Icon RXT Leaf Pack, Coachbuilder +1 shackles, Camburg Racing Moog tubular upper control arms, Timbren industries Front/Rear off-road bump stops, method race wheels MR309 Grid +18, 295/70/18 Ridge Grapplers, Leer 100XL Canopy, Decked Drawer system, Diode Dynamics Stage Series 3 fog lights , sdhq Battery Terminals, @tundra452 ARB Compressor mount, scangauge, gorhino RB20 steps coated with linex, AFE power Drop in air filter, Bulletproof bumpers Kickback mudflaps, husky liners X-Act contour liners, bedrug Drop in liner
    As @fricho228 mentioned, stock Tundra wiring only allows for Low/Fog or Low/High beam. If you install the fog lights in place of your factory fog lights, then this functionality remains. If you do not want this, then you would have to wire a separate circuit for the fogs. That is what I opted to do with my switch pros, so I can utilize the fogs with my high beams.
  4. Feb 9, 2021 at 1:43 PM
    BayRunner
    2017 Tundra Platinum
    another option is the “always on” fog mod which is super easy to do
  5. Feb 9, 2021 at 1:56 PM
    Quicksand4x4
    Building in process
    My truck had the standard halogens. I did not do any different wiring when I put on the ss3’s just used the harness to the original plug in. Still doesn’t explain why my high beams won’t turn on anymore.
  6. Feb 9, 2021 at 1:58 PM
    frichco228
    agreed. fuse would be my first thoughts and there may be more than one location to check. So highbeams do not work now at all, even if fogs are switched off?
  7. Feb 9, 2021 at 2:13 PM
    Quicksand4x4
    Building in process
    Correct, when I flick the switch towards the dash the blue high beams light doesn’t appear. But they still work bc I can pull the lever back and they’ll turn on but as you know it doesn’t stay when you do that.
  8. Feb 25, 2021 at 7:21 AM
    TommyTundra
    TommyTundra Oh God the anger’s changing me
    Long Island NY
    2019 PRO
    A question a little off the topic. I bought 2 twelve in stage series led bars from diode dynamics. They are supposed to come on with your high beams except if you have OEM LED headlights ( which i do). Anybody know of a way around this so they will come on with the high beams???
  9. Mar 18, 2021 at 6:43 AM
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    You ever find the solution?
  10. Mar 24, 2021 at 2:22 PM
    Quicksand4x4
    Building in process
    Yeah all I did was pulled my fuse and reconnected it and it was good to go. Fuse wasn’t blown I guess it just needed a restart, super weird.
