Diode Dynamics light bar install
Discussion in 'Lighting' started by Scary-dogg, Mar 30, 2020.
  1. Mar 30, 2020 at 9:13 AM
    Scary-dogg
    Scary-dogg [OP] New Member
    I am in the process of installing the 42 in Stealth Diode Dynamics light bar and I have a couple questions if anyone is able to answer. I have the NSV bar installed with no issues. I am wanting to do the Stealth bar as clean as possible without having to drill a hole for the toggle switch. I am only wanting to use the Stealth bar with my high beams, and I am also wanting to try and utilize the NSV power switch to power the Stealth bar on and off. I have seen the extra lightbar button, but it wouldn't work in my application. Im in a 19 Platinum and the extra spot on the NSV switch panel is taken for security. And no open positions on the driver side panel.
  2. Apr 14, 2020 at 4:14 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    Hey bud, like you I'm not into aftermarket buttons on my dash or console. I was able to sneak a button down by my right knee that isn't visable without crawling under. I used an illuminated switch so there's a soft red glow to remind me it's on. Just an idea I wanted to share with you. I'm a little confused about your switching question. Is your existing light bar powered through a relay?
    tonynw318, the ER kid and Ely010606 like this.
  3. Jul 17, 2020 at 3:10 PM
    GREENwithENVY
    GREENwithENVY New Member
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    I got one of those for my 2020...did you use the round head allen bolts to secure the light to the brackets? I've struggled to get it positioned evenly in the bumper cutout and aimed...think it sucks that one cannot adjust fixture without removing the entire bracket set from the truck. I'm thinking about using ultra low profile head bolts to be able to adjust once mounted.
    Beesta likes this.
  4. Jul 17, 2020 at 3:23 PM
    Scary-dogg
    I did use the round allens. I had the same problem setting mine, but was finally able to get it set right. I just flushed the ends with the bumper face.
    Beesta likes this.
  5. Jul 17, 2020 at 3:26 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    Do you not have any switch blanks anywhere in the truck?
    Get a button from Air On Board or CH4x4 that fits perfectly. Keep the factory blank in case you ever remove the light bar.
  6. Jul 17, 2020 at 3:31 PM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
  7. Jul 17, 2020 at 3:32 PM
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    I used a Blazer International Wireless Remote System. I love it.
    Something simliar to THIS
  8. Jul 17, 2020 at 3:36 PM
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    ElNopal[QUOTED] likes this.
  9. Jul 17, 2020 at 3:36 PM
    Scary-dogg
    I did not have any switch blanks. And I didn’t want to cut another switch in. I only wanted the light to cone on with my high beams so I just tapped into the high beams and everything works like I want it to.
  10. Jul 17, 2020 at 3:49 PM
    Major
    Major TTC #0181
    Josh
    NC
    Stock.
    Pics of the lightbar?
  11. Jul 18, 2020 at 6:48 AM
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    Where did you all mount relay (with the DD42 harness) under the hood? It looks like to do so, a new hole has to be drilled? Or use self-tapping? Pictures would be nice...
  12. Jul 18, 2020 at 6:51 AM
    Backslider
    Tooele, UT
    I mounted the relay on my compressor mounting bracket.
  13. Jul 18, 2020 at 7:17 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    I placed mine and another near the ground cable at the battery. However, had I known at the time I would have gone with the Rago Fabrication Universal Relay Holder. DFF7F416-B681-43A0-B430-3AED37DCB222.jpg 13E45B98-A8B4-4043-AEF6-112815952191.jpg B1CCC5BF-75E5-4EF5-AA9E-6EC7697495EE.jpg
  14. Aug 28, 2020 at 3:58 PM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    Hey guys ... did you all have any issue on the lightbar not being so firm .? Im trying to get center of the cut ... thanks
  15. Aug 28, 2020 at 4:17 PM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    Got it .. thanks
