Dim Head lights
Discussion in '2nd Gen Tundras (2007-2013)' started by taparilo, Jan 5, 2023.
  1. Jan 5, 2023 at 8:17 AM
    taparilo
    taparilo [OP] New Member
    Tom
    Nevada City, CA
    2013 White Tundra TRD,Limited, Rock Warrior
    I have a 2013 Tundra and have had the headlights buffed about two times. The beam eventually weakens as the lens crystallizes. I also notice that the bean seems li.ited on low beams. I am running stock bulbs. Is there a better upgrade?
  2. Jan 5, 2023 at 8:21 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Replace your bulb. They wear out as they age.
    Taco-Spike likes this.
  3. Jan 5, 2023 at 8:22 AM
    Taco-Spike
    Two Trucks
    What's your process on the buffing?
  4. Jan 12, 2023 at 12:02 AM
    azimuth
    azimuth New Member
    2010 double cab SR5
  5. Jan 12, 2023 at 6:34 AM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
    Over time road debris eats through the hard coating on your headlight lenses, leaving a rough surface on the softer plastic beneath the hard coating. Buffing will smooth the soft plastic so it's a clear lens again, but because you haven't restores the hard coating, it will become foggy again very quickly.
    Some better headlight restoration kits include a separate clear coat process which extends their life. But the best long-term solution, if you have the budget, is to replace the headlight completely.
    As an added bonus, you can choose non-OEM headlight upgrades that fix one of our trucks biggest problems: weak headlights and terrible night visibility.
