Dim blinker recall
Discussion in '2.5 Gen Tundras (2014-2021)' started by Walkem, Jul 24, 2020.
  1. Jul 24, 2020 at 7:48 AM
    Walkem
    Walkem [OP] New Member
    Canada
    2020 TRD Sport Premium CMax
  2. Jul 24, 2020 at 9:26 AM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    2020 PRO headlights and grill
    What is the problem? I have 2020 headlights on my 2015...does this affect me or just those with the newer trucks?
  3. Jul 24, 2020 at 9:31 AM
    timsp8
    NY
  4. Jul 24, 2020 at 9:39 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Read the thread
  5. Jul 24, 2020 at 10:53 AM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    Sorry, I thought this was the thread.
  6. Jul 24, 2020 at 11:16 AM
    Walkem
    Canada
    You should be fine having a 2015 I believe anyways. The issue is the wiring harness not the headlights
  7. Jul 24, 2020 at 12:51 PM
    timsp8
    NY
  8. Jul 24, 2020 at 3:00 PM
    jordoncloutier
    jordoncloutier New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
    Performed the wiring swap recall on my own ...took 15minutes. Results were the opposite . Lights got dimmer .... Had to put the wiring back to the way it was originally .
  9. Jul 24, 2020 at 4:05 PM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    Really? You are the first one to say that I think.
  10. Jul 24, 2020 at 5:15 PM
    Anthony605
    Anthony605 New Member
    Anthony
    2020 Limited Double Cab
    Anyone already fix the issue themself and bring your Tundra to the dealership to have the VIN removed from the recall list? I did it myself and just want to have my VIN "cleared" from the recall.
  11. Jul 24, 2020 at 5:34 PM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    I had a Dodge CTD 4x4 that had a recall for the fuel tank sucking in water from a recess on the fuel tank that had a vent in it, the Dodge group came up with a fix of adding some tubing (something like the rear axle vent mod on Tundra). Dodge eventually recalled the trucks after eating some injector pumps. On my truck, they had a tech come out and verify my fix, the recall was marked done, and I went on my way with a receipt showing the recall was preformed.
  12. Jul 24, 2020 at 5:37 PM
    Anthony605
    Anthony
    Sounds good! I will make an appointment with my local dealer and let them know it is done.
  13. Jul 24, 2020 at 6:58 PM
    timdske
    timdske Another Old Guy
    Fort Worth Texas.
    2019 MGM SR5 4x4 Tundra TSS Offroad
    I checked my VIN and I'm not part of the recall. Mine are very bright.
  14. Jul 24, 2020 at 7:18 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Does anyone know if all 2019's come with LED headlights, or is it just in certain packages?
  15. Jul 25, 2020 at 5:20 AM
    Anthony605
    Anthony
    Not all Tundras come with LED lights. What package do you have?
  16. Jul 25, 2020 at 6:46 AM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Just top them off with this and you guys will be all set for up to 6k blinks. ;)
  17. Jul 25, 2020 at 7:02 AM
    cmdrken1
    cmdrken1 New Member
    2020 Voodoo SR5 TRD
    I already did my own recall thanks to the other thread on my 2020 this forum is on the leading edge of Tundra know how!
  18. Jul 25, 2020 at 7:03 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    If it was an SR5 without the OEM LED, that would be because they’re set up correctly from the factory. This issue is ONLY on the OEM LED headlights.
  19. Jul 25, 2020 at 7:11 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Yeah, @jordoncloutier it looks like you have the non-LED headlights from your avatar. You shouldn't swap wires on those, if that's the case.
  20. Jul 25, 2020 at 7:13 AM
    jordoncloutier
    Jordon
    Alberta , Canada
    Makes sense ... I wasn't aware this recall was only for higher trim level trucks .
  21. Sep 4, 2020 at 8:08 AM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
    I just took my truck in to get the oil changed. And the female employee at the desk next to my service guy heard me and him talking about the blinker. I told him I already fix the problem my self by swapping the wires. She butts in saying thats not a recall fix you need a special tool to fix. I told her again that I check and they are brighter. She continued to argue with me that it's not a fix you need a special tool...She was all kinds of special.
    jewsNbrews and Hoff like this.
  22. Sep 4, 2020 at 10:02 AM
    Anthony605
    Anthony
    I may have you beat on that one. I did the repair myself. About six weeks ago I took the truck to my local dealership to have the VIN cleared from the recall. The SERVICE WRITER told me that the recall involves installing a whole new harness!! After about an hour of going back and forth, a technician looked at the truck and the VIN has been cleared from the recall list. I have no idea who is training the employees! You would think that a service writer would be aware of what the recall entails.....
    dkahs05 likes this.
  23. Sep 4, 2020 at 10:16 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Should have printed out their tech doc to show them how to do their job...
    dkahs05 likes this.
  24. Sep 4, 2020 at 10:25 AM
    Anthony605
    Anthony
    Yes, I should have had it with me. I was thinking the same thing while I was there speaking with the knucklehead. However, you would think that a service writer would be aware of the recall procedure. If he wasn't, all he has to do is obtain the document himself.
  25. Sep 29, 2020 at 7:09 PM
    TaquitoBandito
    Joel (AKA Bif)
    Took mine in for the free oil change and the recall. I figured they replaced the harness because it took them 4 1/2 hours... To be fair, they didn't tell me the recall would take so long when they scheduled the oil change. Thank God I brought my iPad.
  26. Sep 30, 2020 at 8:33 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    How many different threads do we need on this?
    TaquitoBandito likes this.
  27. Sep 30, 2020 at 9:12 AM
    Kung
    KG, VA
    I don't know but I think maybe we need another one.
  28. Sep 30, 2020 at 10:05 AM
    TaquitoBandito
    Joel (AKA Bif)
    I replied to the first one that I found. I have this Millennial-like need to share all of my experiences online. Off to the "Bowel-movement" thread!
  29. Sep 30, 2020 at 10:17 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Are you done yet. Others need the shitter to ya know
  30. Sep 30, 2020 at 11:16 AM
    TaquitoBandito
    Joel (AKA Bif)
    Almost there...
