Digital USB cigarette plug reads 11.4v when driving
Discussion in '2.5 Gen Tundras (2014-2021)' started by IowaGuy, Jan 31, 2023.
  1. Jan 31, 2023 at 5:16 AM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I purchased a USB cigarette adaptor to charge my phone. It has a digital voltage reading on its face and it says 11.4 v while driving. Is this an indication of a bad battery or alternator?
    The adaptor is a cheap Chinese one off scamazon so it might not be accurate and this is in the plug underneath the HVAC controls. It could also be the resistance in the wiring or just a crappy contacts. I guess I need to put my meter on the battery to check it.
  2. Jan 31, 2023 at 5:20 AM
    Taco-Spike
    Two Trucks
    What does the cluster gauge read?
  3. Jan 31, 2023 at 5:38 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    While it is possible the circuit is cheap, voltage is not that hard to measure.
    Get a multimeter set to DC voltage and measure on the battery post with the truck running. You want 13-14v while the truck is idling.
    If you are only getting 11-12v while the truck is running, the alternator is failing.
    Has the truck had trouble starting? Signs of a dead battery? If the alternator really is failing it won’t go very long
    1lowlife and des2mtn like this.
  4. Jan 31, 2023 at 5:40 AM
    Retired...finally
    ...Cheap Chinese one off scamazon...
  5. Jan 31, 2023 at 7:46 AM
    IowaGuy
    In Process
    The voltage gauge on the dash reads right in the middle although that is hardly accurate
  6. Jan 31, 2023 at 7:52 AM
    My Pioneer reads 12.7 and my SG3 reads 13.4 to 13.6 average.
  7. Jan 31, 2023 at 7:59 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Mine is about the same. I think the ECU voltage is higher than the "usable" voltage of the truck because of inefficiencies. Just a guess.
    Tundra234[QUOTED] likes this.
  8. Jan 31, 2023 at 8:03 AM
    MadMaxCanon
    best way to check the battery i found is put a meter on it and save the minimum reading on the meter, turn on the truck and see what the minimum is. I think anything below 11V means the battery weak.
    NewImprovedRon and Sierradevil like this.
  9. Jan 31, 2023 at 8:31 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    What does it read with the engine off?
    Mine reads 13.1 to 13.5 when driving.
    Usually, 12.6 when everything is off.
    Drone app reads 13.9 at idle.
    NewImprovedRon likes this.
  10. Jan 31, 2023 at 2:52 PM
    IowaGuy
    In Process
    Measurements from the battery posts
    12.38 not running
    13.90 when idling
    1lowlife and Jeff_5_7 like this.
  11. Jan 31, 2023 at 3:05 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Exactly what you want to see. I wonder if the cig lighter ports could be regulated down as well. Seems all anybody uses them for today is phone chargers, of which most are only 5 Volt.
    NewImprovedRon and 1lowlife like this.
  12. Feb 1, 2023 at 2:45 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Best way to test a battery is to load test. In the OPs case I would suspect the cheap Chinese USB adapter is reading incorrectly.
