Digital Rearview Mirror
Discussion in '3rd Gen Tundras (2022+)' started by romanlegion, Jul 23, 2022.
  1. Jul 23, 2022 at 9:04 PM
    romanlegion
    romanlegion [OP] New Member
    Roman
    Katy, TX
    2022 Tundra SR5 TRD Off-Road Lunar Rock
    Not sure if this is possible. Can I upgrade the standard regular rearview mirror on my SR5 TRD Off-Road with a Digital Rearview Mirror? Has anyone on here done it to theirs? Thanks for any info or leads.
    Here's a link to a video on YouTube for reference.
    https://youtu.be/s_PHOBRdETI
    KA22TRD likes this.
  2. Jul 24, 2022 at 5:00 AM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    Don't know if wiring is there to make it possible. Probably take some digging to find out.
    romanlegion[OP] likes this.
  3. Jul 24, 2022 at 9:10 AM
    romanlegion
    Roman
    Katy, TX
    I'll have to crack open the dome light overhead panel and look if there's a 10-pin or a 5-pin harness. There should be a 10-pin up there because of the wiring needed for the Toyota OEM dash cam. I'm assuming the digital rearview mirror will likely use a 5-pin harness.
  4. Jul 24, 2022 at 3:54 PM
    KClav
    KClav MGM Limited
    2022 Tundra Limited CM MGM TRD OR
    Does the digital rear view mirror use the camera mounted in the tailgate or another?
  5. Jul 24, 2022 at 3:57 PM
    romanlegion
    Roman
    Katy, TX
    It’s the one on the tailgate.
  6. Jul 24, 2022 at 4:05 PM
    KClav
    KClav MGM Limited
    It’s got to be a relatively simple link to get that image from the center display on up to that mirror location. I don’t have a digital rearview mirror either, just not sure what I’d be looking for up in near my existing mirror.
  7. Jul 24, 2022 at 4:07 PM
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    It’s actually one of the two cameras on the roof at the rear, integrated with the 3rd brake light. Not sure if Tundras without the digital rearview mirror even have the camera. The other of the two cameras looks down into the bed. The camera in the tailgate is the backup/PVM cam.
    If the Tundra didn’t come with the digital rearview, I don’t think it can be added.
    ryanwgregg, JoeInMinn and X42069 like this.
  8. Jul 24, 2022 at 4:13 PM
    KClav
    KClav MGM Limited
    Mine is a Limited TRD OR, has the cameras above the bed but no digital rearview mirror.
  9. Jul 24, 2022 at 5:32 PM
    romanlegion
    Roman
    Katy, TX
    That would suck if it cannot be added.
    I saw a video somewhere where the truck bed was full of boxes and you cannot see through he rear view window. The driver turned on the digital rearview mirror and it looked the view came from the tailgate without the boxes obstructing the view. So, I'm inclined to believe the video feed maybe coming from a camera mounted on the tailgate. I could be wring though. Can you do some testing if you have the digital RVM on your Tundra? Thanks.
  10. Jul 24, 2022 at 5:50 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    It’s one of camera on the third brake light. I have digital rear view on my SR5 TRD sport premium.
    I’ve driven with my motorcycle on back with tailgate down and you can still see the top of the motorcycle.
  11. Jul 24, 2022 at 6:13 PM
    romanlegion
    Roman
    Katy, TX
    Thanks for the info.
  12. Jul 24, 2022 at 6:25 PM
    4genRunner
    Southwestern MO
    You might be able to add it assuming you have 2 cameras up there and all the required wiring harnesses. Unsure if there’s and ECU or anything else required.
  13. Jul 25, 2022 at 9:26 AM
    Tumbler
    Tumbler New Member
    2023 CrewMax Limited HV in MGM
    Mirror won't be cheap either.
  14. Jul 25, 2022 at 9:37 AM
    romanlegion
    Roman
    Katy, TX
    This might be too expensive to do if it's even possible. Mine truck only has the tailgate camera and none mounted on the rear-facing bed lights. I'm almost sure the 10-pin wiring harness is ready, but that's kinda pointless for me at this point. LOL :)
  15. Jul 25, 2022 at 9:38 AM
    romanlegion
    Roman
    Katy, TX
    Yup. I'm sure it's going to be $$$$
  16. Jul 25, 2022 at 10:24 AM
    Tumbler
    Tumbler New Member
    I had the same thought about the towing mirrors since my Limited will not come with them (only come on Platinum in Canada and not an available as an option on other trims). Even if the wiring was in place the price of the mirrors was astronomical. IIRC they were around $1,200 each! Then you need the switch too which I am sure would be another buck or two. So for you with no cameras and no mirror I am sure you will be in the thousands the get it going.
  17. Oct 21, 2022 at 6:07 PM
    AverageAZN
    AverageAZN New Member
    Austin
    2004 Toyota Sequoia
    OME/Dobinson long travel lift, 34s
    Has anyone Tried this yet?
  18. Oct 22, 2022 at 5:12 PM
    JoeInMinn
    JoeInMinn New Member
    2022 1794 Trd
    I'm curious would be cool if it works.
    I have it on my 1794. In 2019 I bought a brand new cadillac ct6 platinum , it was the first car to come with a digital rear view mirror. I though it would be gimmicky but it's one of the best features saftey wode added to cars in a long time in my opinion I absolutely loved it. Had to have it on this truck. Just wish they had the button to wash it like my cadi.
  19. Oct 31, 2022 at 5:07 PM
    Overcamber
    Overcamber New Member
    No it’s the camera on the top rear of the cab .I know because I bought a truck cap and now I only see the truck colour when the moirror is on digital .. unless I can change which camera it uses for it ?
  20. Nov 1, 2022 at 11:58 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Correct, it is the 3rd brake light camera... Mine is blocked by my topper and desperately trying to get a work around and relocate the camera.
  21. Nov 1, 2022 at 12:02 PM
    AverageAZN
    Austin
    2004 Toyota Sequoia
    Have you taken off the tailight/camera? I cant imagine it would be too difficult to fine the connectors theyre using and make an extension cable.
  22. Nov 1, 2022 at 12:22 PM
    DexterL
    DexterL New Member
    I have not, unfortunately it looks like a headliner drop situation and between work, travel for work, and balancing out home/ kid/ wife life I have zero time on my hands for such a project.
  23. Nov 1, 2022 at 12:59 PM
    AverageAZN
    Austin
    2004 Toyota Sequoia
    No worries, I'm determined to get to the bottom of this, but i dont get my truck till December (build 11/14).
    Once i get it ill try my best to figure it out. gotta put my electrical engineering degree to use lol
    Henry1jg and Kap1 like this.
  24. Nov 1, 2022 at 1:51 PM
    DexterL
    DexterL New Member
    Keep us posted, build a kit and prosper off the sales!
  25. Nov 1, 2022 at 2:33 PM
    Overcamber
    yes keep us posted thanks
  26. Nov 1, 2022 at 3:53 PM
    4genRunner
    Southwestern MO
    If by "bed light" you mean the 3rd brake light at the top rear of the cab, one camera is for the digital rear view mirror, the other camera looks down into the bed. If you mean the one in the tail gate handle, that's the back-up camera.
  27. Nov 1, 2022 at 4:39 PM
    TTCsparky
    TTCsparky New Member
    Scott
    2020 White Tundra Plt
    The entire system consists of the mirror, camera (CHMSL/3rd brake light mounted) and wires.
  28. Nov 24, 2022 at 7:14 PM
    binarybedlam
    binarybedlam New Member
    2022 Green Tundra TRD
    Has anyone successfully removed their bed camera \ digital rear view camera yet? I'm looking to get a topper but don't want to block them. So I am wondering if its possible to put an extension cable on their harnesses to relocate them.
  29. Nov 24, 2022 at 7:19 PM
    GG.Offroad
    GG.Offroad New Member
    Austin
    Westminster, CO
    2023 Tundra Limited Hybrid Lunar Rock
    www.ggoffroad.com
    We will have a relocation harness coming soon! Details coming
  30. Nov 25, 2022 at 3:26 AM
    Uconn411
    Uconn411 New Member
    Richard
    GaryArt1 likes this.
