Differential problems?
Discussion in '2nd Gen Tundras (2007-2013)' started by Dabutcher, Sep 25, 2022.
  1. Sep 25, 2022 at 5:55 PM
    Dabutcher
    Dabutcher [OP] New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    Doing maintenance at 150k. Rear differential oil drained and replaced. Transfer case oil drained and replaced. Front differential I got the top Allen Bolt loose. I cannot get the bottom one to drain it loose? I am using a socket wrench with a Allen wrench 10mm. And I added a 10mm wrench slid on the end to wack with a hammer. It’s not moving at all? Any and all help would be greatly appreciated. Only thing I can think of now is go to neighborhood shop and get them to loosen it for a small fee? Thanks. D
  2. Sep 25, 2022 at 6:03 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Put some serious heat to it. It should break loose.
  3. Sep 25, 2022 at 6:10 PM
    Dabutcher
    D
    Twin Cities
    I might be a noob to the heat game? Do I heat the bolt or around it or both? Thanks. D
  4. Sep 25, 2022 at 6:38 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Put a torch on that bolt and right around it. The heat will make it expand and when it cools it will shrink and you should be able to bust it loose.
    baraynavab likes this.
  5. Sep 25, 2022 at 6:39 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Aim it right at the bolt it should also heat the immediate area. You can do small circles around the OD of the bolt.
    BTBAKER likes this.
  6. Sep 25, 2022 at 6:51 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Are there any options for a more suitable replacement plug for the front diff?
    Asking for a friend :anonymous:
    TundraTRD08 likes this.
  7. Sep 25, 2022 at 6:59 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    07 Tundie likes this.
  8. Sep 25, 2022 at 7:11 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I got my one out with a chisel and a hammer
  9. Sep 25, 2022 at 7:16 PM
    Shanet421
    San Diego,CA
  10. Sep 25, 2022 at 7:25 PM
    TILLY
    Massachusetts
    Not sure what you're asking, why would you need a magnet on the fill plug?
    Edit: Sorry, it seems I misunderstood your question. That one doesn't look like it has a magnet as far as I can tell.
  11. Sep 25, 2022 at 8:18 PM
    Shanet421
    San Diego,CA
    Ya seems to be the only downside to that OEM part.
  12. Sep 29, 2022 at 4:43 PM
    Dabutcher
    D
    Twin Cities
    Just bought the two plugs from Lexus dealer to replace the Allen bolts with regular bolts. My local Lexus quote was $21.90 each and the had to special order them. I found this dealer for cheaper. Passing the savings on to you guys. Thanks for the help. D3BE773E8-BC3C-4074-880C-30B14AB2CDA9.jpg6748BA64-3A3D-4C1F-B710-6D6AD2E1B94F.jpgFB4AC89D-6474-49F5-A6F3-95F6460E7F73.jpg
    BTBAKER likes this.
