Differential Oil Change, Metal on Plug(s). How Concerning?
Discussion in '1st Gen Tundras (2000-2006)' started by ATBAV8, Apr 19, 2024.
  1. Apr 19, 2024 at 5:21 PM
    ATBAV8
    ATBAV8 [OP] Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    Doing a 90,000 mile service on my '03 AC 4WD V8 today, and because it's still fairly new to me I decided to do front and rear diffs and transfer case oils. I have no idea when they were last done, so I want to be sure they're done under my ownership. I did the front diff first, and there was about 1/8" of metallic sludge attached to the drain plug (see photos). The oil was black and stinky. Definitely needed to be changed. What concerns me more is the actual metal on the plug from the rear diff. Again, the oil was black and stinky, but the plug had actual chunks of metal in the metallic sludge (again see photos).
    IMG_0239.jpgFront diff plug.IMG_0242.jpgRear diff plug.IMG_0243.jpgMetal from rear diff plug. Key for size reference.
    My question is, how concerned should I be? Especially about the rear diff. I'm not hearing any abnormal noises. No grinding, chattering or slipping, even at WOT from a dead stop. 4WH engages just as it should, and 4WL engages and works fine as well. Is this something I should monitor and do another fluid swap in say, 10,000 miles? Leave it alone? Let me hear your thoughts. Thanks.
  2. Apr 19, 2024 at 6:02 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    So I can tell you that I see this all of the time in cars at work when we do the diff fluid for the first time. It’s not abnormal. However, IF your fluid has previously been changed (which you don’t know) then I would say yes, that’s a problem. The fact that your diff fluid was as dark as you say, I bet it’s original. I do mine every 30m and I can tell you that it looks new even after 30k.
    FrenchToasty likes this.
  3. Apr 19, 2024 at 6:05 PM
    I wouldn't be overly concerned about that, unless you see it again. I'd assume your fluids have never been changed. That amount of sludge is effectively what I saw. I honestly don't think my fluids had ever been changed either.
  4. Apr 19, 2024 at 6:09 PM
    ATBAV8
    Tempe, AZ
    @shifty` and @The Black Mamba, do you guys think it's worth dropping the front and rear diff fluids at the next oil change (5000 miles) just to be sure? Or just roll with it?
  5. Apr 19, 2024 at 6:10 PM
    If you don't mind spending the money, and it will give you peace of mind, go for it.
  6. Apr 19, 2024 at 6:11 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    No. I don’t believe that would be necessary. Don’t loose sleep over it
    ATBAV8[QUOTED][OP] likes this.
  7. Apr 19, 2024 at 6:16 PM
    ATBAV8
    Tempe, AZ
    Thanks. And @shifty` thanks for your input as well. I do think it could have been original oil.
  8. Apr 19, 2024 at 6:16 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    I bet when you do decide to check it, it will look brand damn new and have no metal whatsoever
    shifty` and ATBAV8[QUOTED][OP] like this.
  9. Apr 19, 2024 at 6:23 PM
    ATBAV8
    Tempe, AZ
  10. Apr 19, 2024 at 6:30 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    If you have LSD use Lucas Dino LSD oil. If not use Valvoline synthetic. See posts by Shifty for details.
  11. Apr 19, 2024 at 8:18 PM
    I bought Lucas 80w90 from Advance Auto online using coupon RMN15 for 15% off and had it shipped for free to my front door, if I recall. Easy peasy. And didn’t cost too darn much.
  12. Apr 19, 2024 at 8:37 PM
    Squeakyduck4
    Squeakyduck4 New Member
    Santa Barbara
    06 DC 4x4 V8 TRD
    Just did mine recently. Looked exactly the same. Guessing original oil.
    ATBAV8[OP] and FrenchToasty like this.
  13. Apr 19, 2024 at 11:56 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Can probably use speed perks $5 off eventually too!
    ATBAV8[OP] likes this.
  14. Apr 20, 2024 at 7:12 AM
    Rsmallw2
    Rsmallw2 New Member
    Ryan
    2005 Toyota Tundra DLCB 4WD
    N/A
    This is what I used to do my rear differential fluid change. No noise or chatter I’m thinking about doing the front in the next few months. What fluid do you suggest for the front diff?
  15. Apr 20, 2024 at 7:12 AM
    I definitely did with my fluids, using old SpeedPerks, and I think I got another $15-25 off from that.
    I've refined a small system for saving on gas and parts. Basically, I signed up for SpeedPerks at Advance Auto, and do most of my purchasing with them online (for store pickup), using these coupons on every order, which I almost always get 15-20% off retail with that online order which usually matches or beats scAmazon/RockAuto/Summit pricing. Sometimes Advance Auto will throw the popup in your face for 20% off when you go to the site, and I'll use that.
    I then setup an account with FuelRewards using the same phone# I put on my AA Speed Perks account, then linked the two (FuelRewards didn't ask for an absurd amount of personal info, I just gave them my Google Voice number, first initial, last name). Any purchases I make at Advance Auto now give me 5¢/gal at Shell stations AND my SpeedPerks for future AA purchases.
    Then, under Fuel Rewards, I linked my debit and credit card, so any qualifying purchases at local restaurants or stores or other stuff automatically add 5¢/gal off. Everytime I fill up at a Shell station, I get discounts. Likewise, I was able to link my anonymously-sourced Kroger Plus grocery card to Fuel Rewards, so every time I buy groceries, I get my in-store discount from the card, and I get fuel discounts.
    I typically get ~15-25¢/gal off up to 20 gals every fill-up. One time I got 50¢/gal off. I've only been using the program for a year or two, but basically walk away with 1 in every 10-12 fill-ups being "free" if you factor in cumulative savings. I'm sure someone out there is mapping my preferences and such, to the BS name I gave them, but ... Facebook/IG is probably 100x worse in what they're collecting, and let's not even get into what your internet and mobile services providers are allowed to collect and sell on you after TPTB intentionally killed Net Neutrality for their corporate overlords.
  16. Apr 20, 2024 at 7:14 AM
    I went with Mobil1 full syn 75w110, I believe. Possibly 75w140. In both the front and the transfer case. My front fluid looked ROUGH. But the Lucas is comparable price, I'd consider just running it all-around, honestly.
    My xfer case oil looked virtually new. Gold like honey. Be careful not to over-tighten the fill plug on the xfer case.
  17. Apr 20, 2024 at 7:46 AM
    Oh, and FYI it looks like Advance is doing a 20% off right now online, code: SUNSHINE
    Rsmallw2 likes this.
  18. Apr 22, 2024 at 10:22 AM
    KSteng
    KSteng New Member
    Kyle
    2006 Tundra SR5 DC V8 4x4
    Bilstein 5100s
    Do you know about how much your front dif took? And also rear dif? Planning on doing those today but I need to know how much oil to get!
  19. Apr 22, 2024 at 10:45 AM
    It's in your Owner's Manual, in the specifications section or whatever at the end. It can vary from truck to truck. You should start there, but if you insist on relying on the internet...
    You can go to https://www.motul.com/en-US/lubricants
    Click on "Cars" icon.
    Choose "Toyota (USA/CAN)".
    Choose "Tundra (2000 - 2006)".
    Pick your exact truck from the Submodel list.
    Scroll down in the list to find which item you need to know the capacity of and it'll give you the ballpark so you can add up how many quarts you need of any given product.
  20. Apr 22, 2024 at 11:00 AM
    ATBAV8
    Tempe, AZ
    ^^THIS^^ But, IIRC front diff 1.1 Liters, T-case 1 Liter, Rear diff 3.2 Liters. Basically until it runs out of the fill hole. The reason I'm using metric is because I used Motul fluids, and that is how they are labeled. The owner's manual does the conversions for you.
    FrenchToasty and shifty`[QUOTED] like this.
