Differential Issue with warning lights on the dash.
Discussion in '2.5 Gen Tundras (2014-2021)' started by DNA, Jul 1, 2022.
  1. Jul 1, 2022 at 1:07 PM
    DNA
    DNA [OP] New Member
    Kevin
    2021 Platinum Tundra
    FINAL EDIT with FIX - This was my truck's issue and may be different for other vehicles. Right rear wheel bearing assembly and right rear wheel speed sensor were replaced. I have not pulled my trailer yet but if something comes up I will post it here
    EDIT - When the dealer said it was the differential it was just a Service Advisor and not a technician. The technician said it could be the ABS sensor and/or the wheel speed sensor. They are still checking this out and I will update when I know more. I agree the differential, if bad, would more than likely be making a horrible noise. To me it did not make sense it was the differential but what do I know.....
    I have a 2021 Tundra Platinum with just over 15K miles. I was towing a trailer (under 5K pounds) when I came to a stop my Brake, ABS, 4Hi/4Low, LDA, Collision alert and other lights all came up on my dash. The messages stated to pull over safely and check the trailer. Everything was hooked up fine. I called the dealer since I was out of town on a trip and they said if the check engine light was not on then I would be okay to drive my rig. Truck continued to pull the trailer fine. Got to the dealer and they said my differential was toast. Initially the dealer said it was my fault and after some discussion they said they would take care of it. My question to a master mechanic or anyone with information, is this normal? Has anyone else have had this issue as well? What was the remedy to fix the situation? I appreciate any response that is not snarky. Thanks.
    JfHKmZJ7Wb7vRXNEBmCQmNU9J_oBg0wSXid4ZZWx_03fe1111dce46634ce758a6cdae937cc0d6699f7.jpg
  2. Jul 1, 2022 at 1:11 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    What happened to the diff to make them call it toast?
  3. Jul 1, 2022 at 1:14 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    The only connection I can imagine between the rear differential and your symptoms would be the rear wheel bearings / axle housing (not the differential itself) and axle shafts, causing a rear wheel speed sensor malfunction.
    I’d ask for a much better explanation of what’s actually going on. And no, it’s not normal or common.
    With your trailer, were you loaded over rear GAWR?
  4. Jul 1, 2022 at 1:33 PM
    Cajun1977
    Cajun1977 New Member
    Shawn
    Northwest Arkansas
    2020 CM TSS
    Level lift Tonneau cover
    What was the explanation of them saying it was your fault?
  5. Jul 5, 2022 at 10:05 AM
    DNA
    DNA [OP] New Member
    Kevin
    Update . . . . Apparently I am not the only one with this issue. The master mechanic has run across this on other models. LED lights on the trailer are supposedly the culprit? We will see. I will keep adding to this thread once information is received.
  6. Jul 5, 2022 at 10:41 AM
    gabex35
    gabex35 2020 Limited 4x4 with mods coming...
    San Diego
    2020 Cement Limited 4x4
    Wow
  7. Jul 5, 2022 at 10:43 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    LED trailer lights causing the differential to go out?
    ZappBrannigan, excelw and Sumo91 like this.
  8. Jul 5, 2022 at 10:47 AM
    blaserdude
    blaserdude New Member
    Eugene
    2019 Tundra Limited Double Cab
    none
    A failed differential will make a lot of sound, so will axel bearing, u-joints, etc. Sounds fishy.
    bc
    equin likes this.
  9. Jul 5, 2022 at 10:49 AM
    mountainpete
    Exactly.
  10. Jul 5, 2022 at 2:38 PM
    FWC
    FWC New Member
    Upstate NY
    2019 Tundra Black Platinum
    Oddly enough all those lights happened to me this morning, called the dealer and they said it was fine to drive, i have an appointment for Friday. Drove it today and the check engine light did come on at some point so I checked with my scanner after getting home and it said wheel speed sensor, so I will see what the dealer says Friday.
    2019 Platinum with 27k
    AgileTundra likes this.
  11. Jul 6, 2022 at 10:22 AM
    DNA
    DNA [OP] New Member
    Kevin
    FWC - Please let me know what your service tech says about this situation.
    FWC likes this.
  12. Jul 7, 2022 at 12:07 PM
    DNA
    DNA [OP] New Member
    Kevin
    This was Toyota's response to my issue if anyone else has the same problem. Is it possible the output to the seven pin plug is not 12v?
  13. Jul 7, 2022 at 12:24 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Interesting, especially considering any new/late model trailers have led lights....even utility trailers.
    texasrho83 likes this.
  14. Jul 7, 2022 at 12:40 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Sooooooo you went in there because of a problem that occurred while you were pulling a trailer and the dealer ends up telling you to not pull a trailer
  15. Jul 9, 2022 at 4:09 AM
    FWC
    FWC New Member
    Upstate NY
    Mice, they called me yesterday and said it was due to mice chewing some wires. Picking it up later this morning and will be $320 lighter.
    Neils1958 and bulldog93 like this.
  16. Jul 9, 2022 at 4:39 AM
    Retired...finally
    Can you provide more details on the trailer? New, old, retrofit LEDs or OEM. I pull a 2021 TT with all OEM LEDs with my 21. With about 5K towing so far so good. Just wondering if this is something I need to worry about along with my transmission catching fire and causing terrible harm to nearby kittens and puppy dogs.
  17. Jul 9, 2022 at 7:26 AM
    frichco228
    not trailer related, issue was rodent damage to wires
  18. Jul 9, 2022 at 11:37 AM
    Retired...finally
    Sorry, that was directed at the OP.
  19. Jul 23, 2022 at 11:35 AM
    DNA
    DNA [OP] New Member
    Kevin
    did they show you where the damage was? If so, let me know and I’ll look at the area. Thank you!
  20. Jul 24, 2022 at 5:15 AM
    FWC
    FWC New Member
    Upstate NY
    No, of course they were busy and when I asked they said the location was on the invoice, which it wasn't. I was in a hurry and didn't go back to service.
  21. Sep 14, 2022 at 1:17 PM
    Neils1958
    Neils1958 New Member
    Neil
    2019 gray Tundra 1794
    Since my truck is a 2019 Tundra and I am experiencing a very similar situation, rather than start a new thread I will continue this one.
    Background: we bought the truck last summer with 23k miles. We drive a lot during the summer, then park it while we sail in Mexico for non hurricane season.
    This year a friend heard a noise in the right rear. I did not hear it and he couldn’t repeat the noise. That was in Missouri. We drove to Florida, then to Northern California then south. At about 40k miles in San Fernando all the lights came on. We took it to the dealer who diagnosed a right rear wheel speed sensor. They had none in stock, so ordered it. Expected to take a week. We continued our drive south to Carlsbad, about 100 miles south across L.A.
    The problem “fixed” itself on Thursday, I canceled the repair on Friday, and it failed again on Sunday. I ordered the part on line ($305 San Fernando, $385 Carlsbad, and $215 in Massachusetts, but a week for shipping). Got the part put it in reset the codes, and that didn’t fix the problem.
    Off to another mechanic. Checked the wire from the common junction point to the computer from the back of the truck, both (left rear and right rear) read the same. Checked the wire from the junction to the sensor, with a jumper installed, continuity, with out the jumper open circuit.
    Looked in the hole and it didn’t look good. Used a magnet, and got metal shavings out of the hole. Currently at the dealer as, we are on a schedule. Plan is to pull the right axle and check it out.
    when I know more I will put more info in a post.
    HulkSmurf14 likes this.
  22. Sep 15, 2022 at 7:25 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Seems right rear axle/bearings, sensor, comes up often here on this forum. Wonder why
    Giskk, HulkSmurf14 and Neils1958 like this.
  23. Sep 22, 2022 at 6:52 PM
    Neils1958
    Neil
    So, after spending $190 for a diagnostic, $220 for a new sensor, and $100 for a non Toyota mechanic to do the actual diagnosis. I took it back to a Toyota dealer. This one in Carlsbad, CA. I told them about the metal shavings in the bearing, and left it. Two days later they let me know that the work was done, all covered under the regular warranty, but would also have been covered under our extended warranty. I don’t know how much it would have cost, but they replaced the sensor again and did a flush of the rear differential looking for fragments and metal shavings etc. as well as replacing the wheel bearing (described by the tech as “coming apart”).
    We got the truck back, hooked up our trailer and headed east. We are now in Iowa, about 3000 miles since the repair and no issues so far.
    gabex35 and HulkSmurf14 like this.
