Differential gear oil recommendation after 5.29 gears
Discussion in '2.5 Gen Tundras (2014-2021)' started by pvmike, Sep 17, 2019.
  1. Sep 17, 2019 at 9:59 AM
    pvmike
    pvmike [OP] Home Depot flexing
    Los Angeles
    2014 Platinum Super White
    TRD Pro suspension, supercharger, 5.29 gears, Auburn LSD
    Hello friends,
    I recently installed 5.29 gears and an Auburn LSD to my TRD supercharged Tundra (thank you @dirtydeeds for setting it all up). I've surpassed 500 miles since the install, so I believe a gear oil change is recommended. FYI, I never tow, and but I often haul. Mostly ass...
    What would be a suitable gear oil, and how much will I need to change oil for both front and rear diffs? From what I've read, some recommend a thicker oil that would add more protection, such as Nitro's 80w-140 Para-Synthetic Plus gear oil. Would I also need to add a friction additive such as Auburn's friction modifier as per the recommendation on Auburn's website? I'm not sure what would be best.
    Thanks in advance for your input!
