Differential Fluid Change.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Kbar691, Mar 5, 2022.
  1. Mar 5, 2022 at 11:33 AM
    Kbar691
    Kbar691 [OP] Hmmm
    Kenny
    2019 TRD Pro
    So, just changed the front and rear differential fluids. For those that do this themselves do you find that you put back in less that what the book says? My rear diff should take 3.8 qts. I bet I got 3.3 back in before fluid ran out the top. Anyone else have something similar? I’m thinking about pulling the fill plug again and trying to put more in it.
  2. Mar 5, 2022 at 11:38 AM
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    I bet it’s 3.8 dry, as in new or rebuilt. Even draining your not going to get 3.8 out. My opinion.
    Doxiedad and Kbar691[QUOTED][OP] like this.
  3. Mar 5, 2022 at 11:39 AM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    Yeah when I did mine it was less. I figure it was because some of it is inevitably hanging up. I just filled till it came out the fill port and called it good
    Kbar691[OP] likes this.
  4. Mar 5, 2022 at 11:39 AM
    Kbar691
    Kbar691 [OP] Hmmm
    Kenny
    2019 TRD Pro
    I bet you are right. Heck the only reason I knew was it was an easy measure!
    poheller[QUOTED] likes this.
  5. Mar 5, 2022 at 11:42 AM
    Kbar691
    Kbar691 [OP] Hmmm
    Kenny
    2019 TRD Pro
    You recall how much less for comparison? I was considering pulling the fill plug and pump some in after driving around a bit.
  6. Mar 5, 2022 at 11:51 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    If you want to put a bit more in, park on a hill with the fill hole up hill side. Not sure it's necessary, but you will get to 3.8
    Kbar691[QUOTED][OP] likes this.
  7. Mar 5, 2022 at 11:57 AM
    Kbar691
    Kbar691 [OP] Hmmm
    Kenny
    2019 TRD Pro
    I think a part of it my truck wasn’t perfectly level. It was real close though. Like a 2x4 leveled it. So I can’t believe that made a huge difference.
  8. Mar 5, 2022 at 11:59 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Level ground. Fill until it runs out of the fill hole. Reinstall plug. Wipe down and clean off. Go and have fun for 50k to 100K miles (what ever your flavor is). This procedure is not a numbers game.
    BLONGTX and Kbar691[OP] like this.
  9. Mar 5, 2022 at 12:01 PM
    Kbar691
    Kbar691 [OP] Hmmm
    Kenny
    2019 TRD Pro
    Ok. So now you can guess my degree if you want. Haha
  10. Mar 5, 2022 at 5:02 PM
    Kbar691
    Kbar691 [OP] Hmmm
    Kenny
    2019 TRD Pro
    Alright. Finished a few hours ago. Worst part was dropping and reinstalling the cat shield! Good until 60k.
    TILLY likes this.
  11. Mar 5, 2022 at 5:06 PM
    alb1k
    Left Coast
    It's good
    forensic accounting
  12. Mar 5, 2022 at 5:07 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Engineer. :)
  13. Mar 5, 2022 at 5:15 PM
    Kbar691
    Kbar691 [OP] Hmmm
    Kenny
    2019 TRD Pro
    Tilly for the win!
  14. Mar 5, 2022 at 5:16 PM
    Kbar691
    Kbar691 [OP] Hmmm
    Kenny
    2019 TRD Pro
    Took so long because I did have to go to an appointment right in the middle.
    PeeweeWc17 likes this.
