Differential drain plug
Discussion in '2.5 Gen Tundras (2014-2021)' started by Krohsis, Feb 15, 2017.
  1. Feb 15, 2017 at 5:32 AM
    Krohsis
    Krohsis [OP] New Member
    2016 Toyota Tundra SR5 CrewMax, 5.7L, Red
    Does anyone know the differential fill plug thread size and pitch? I'm looking to install a temp sending unit for the rear end.
  2. Feb 15, 2017 at 5:46 AM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    You need to re-think using the drain plug, it won't last long in a position for very long. I have seen people using the fill plug hole, but the probe isn't always under the fluid.
    ColoradoTJ likes this.
  3. Feb 15, 2017 at 5:52 AM
    Did you call your local Toyota parts department?
    This sounds like a really bad idea to put the thermocouple in the drain port.
  4. Feb 15, 2017 at 6:42 AM
    Krohsis
    Yeah, after some research I'm going to install in the fill port as there is sufficient oil splash to get a good reading and not lose the magnet in the drain plug. But still need the thread pitch and size.....
  5. Feb 15, 2017 at 7:20 AM
    M18x1.5
    NewImprovedRon likes this.
  6. Feb 15, 2017 at 12:10 PM
    Krohsis
    Thanks, ColoradoTJ.
  7. Feb 16, 2017 at 9:12 PM
    TTund16
    TTund16 New Member
    Krohsis,
    since you are thinking about the differential sender unit, I was curious if you also have an oil temp gauge sender for the engine oil and if so, what are your experiences with it?
  8. Feb 17, 2017 at 6:09 AM
    Krohsis
    No, not for engine oil, but I have considered it, more for entertainment value than any real need, as there is an oil cooler for the Tundra motor using engine coolant to cool the oil. How effective it is, well, that is where the entertainment comes in. Also an oil pressure gauge as well since the factory one is so heavily damped.
