Differential actuator
Discussion in '2nd Gen Tundras (2007-2013)' started by Gregsneighbor, Oct 16, 2023.
  1. Oct 16, 2023 at 12:26 AM
    Gregsneighbor
    Gregsneighbor [OP] New Member
    2013 Tundra
    Needing to replace the front differential actuator ( not the transfer case). I've seen a video on a 4runner (this 1 is 13 tundra, i know)and the guy just unbolted actuator and slid the axle back and forth with a small pry bar to align the actuator fork. Seen another video and guy took the whole axle apart to replace this actuator. Do I just unbolt and line up actuator or does axle have to be removed?
  2. Oct 16, 2023 at 5:59 AM
    shannon
    shannon New Member
    shannon
    Asheville, NC
    2010 DC
    The latter, super easy.
  3. Oct 19, 2023 at 7:39 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Once the actuator is removed you can slide the collar with your finger to position it so that it aligns with the fork. You don't have to remove the front diff either. Just make sure you can clean off the gasket stuff off of the mating surfaces before applying the new one.
    baraynavab likes this.
