Differences in the 00-02 @UZFE engine built in Japan and 03+ build in Alabama, USA?
Discussion in '1st Gen Tundras (2000-2006)' started by evilrb, Sep 6, 2020.
  1. Sep 6, 2020 at 3:10 AM
    evilrb
    evilrb [OP] New Member
    Jeremy
  2. Sep 6, 2020 at 3:24 AM
    school teacher
    school teacher New Member
    Edward
    Louisville Ky
    2002 Tundra Limited
    Leer Cap RAV/4 V-6
    I have a Japan built 4.7 V-8 in my 2002 Tundra. At 268.000 miles on the clock, the little V-8 runs like a Swiss watch. Other than timing belt and water pump changes every 75,000 miles (Toyota recommends every 90,000), there have been no maintenance issues other than normal recommended maintenance. I replaced the transmission with a Toyota rebuilt unit at 255,000 miles and the little truck is a joy to drive.
  3. Sep 6, 2020 at 6:20 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    How do you confirm the engine was built in Japan?
  4. Sep 6, 2020 at 6:43 AM
    Professional Hand Model
    Hand Protectors
    Find the serial number on the engine and match it to the build location. I did this with my transmission 2 years ago and assumed the engine was built in Japan, as well. No links to help you, but you should be able to figure it out.
  5. Sep 6, 2020 at 1:18 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    My 03 runs tip top :notsure:
  6. Sep 6, 2020 at 1:52 PM
    Hand Protectors
    @Rex Kramer
    Here is a pic of the Serial Plate from the side of my Transmission.
  7. Sep 6, 2020 at 2:27 PM
    Rex Kramer
    Georgia
    Cool, I'll do some snooping around.
    Thank you.
  8. Sep 6, 2020 at 3:58 PM
    Hand Protectors
    I just went through some old pics and notes. The 03 has 5 less HP compared to the 00-02.
    So, its 240 vs 245hp. I believe the reduction was due to the newer Catalytic Converter (3 way) implemented that year on the 03. Other differences are in the electrical system. The 03 has a larger Alternator and more fuses/different shaped fuse box etc.
    If you want exact details, you can plow through the 03 FSM where the differences are documented versus the 02. The ones I stated above are the majors. A minor is the gas emissions charcoal box thingie which was moved.
    evilrb[OP] and Rex Kramer like this.
  9. Sep 6, 2020 at 6:21 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    I'm gonna have to look in the morning - :monocle: -the things I learn here... :hattip:
  10. Sep 7, 2020 at 1:46 AM
    evilrb
    Jeremy
    Thanks for the info!
    Just trying to learn more about our engines and looks like there are minor differences but in the end, very interesting!
  11. Sep 7, 2020 at 2:15 AM
    school teacher
    Edward
    Louisville Ky
    2002 Tundra Limited
    Leer Cap RAV/4 V-6
    Rex:
    I bought my 2002 Tundra Limited new in October, 2001. The dealership told me that the Tundra was assembled in Indiana and that the 4.7 V-8 was made in Japan. I don't think that Toyota was making the 4.7 in the USA at that time. In any case, it has been a wonderful engine and when I pop the hood and look at the engine bay, it is a joy to look at such a well laid out engine and other components.
    evilrb[OP] likes this.
  12. Sep 9, 2020 at 11:30 AM
    Hand Protectors
    bokch0y and Rex Kramer[QUOTED] like this.
  13. Sep 9, 2020 at 12:22 PM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Could u take a pic of your serial number for me so I know where it's at when u get a chance? I can't find it at all
  14. Sep 9, 2020 at 12:49 PM
    Hand Protectors
    Sure thing. I posted that Transmission Pic in post #6.
    Never seen the Engine Stamp before, but I will soon. Probs made in Japan, too. :yes:
    Pucks18[QUOTED] likes this.
  15. Sep 9, 2020 at 1:02 PM
    Dirt Dawg
    Dirt Dawg "It'd be a lot cooler if you did"
    Connor
    Denver, CO
    2014 Toyota Tundra Limited CrewMax 4x4
    The forged vs cast argument is a myth. All 4.7s use the same rods.
    Pucks18 likes this.
  16. Sep 9, 2020 at 1:18 PM
    Pucks18
    Thanks!
  17. Sep 9, 2020 at 1:32 PM
    It's here, some (dis)assembly required to access the full stamp on the block. I can see the "2U Z" part and some numbers under it, but can't see the whole thing.
  18. Sep 9, 2020 at 1:57 PM
    Pucks18
    Same. I was thinking there's no way its that hard to read but I guess so
  19. Sep 9, 2020 at 4:22 PM
    evilrb
    Jeremy
    Thanks for that info guys!
    I'll check my block out when I start on my supercharger install.20200321_171001.jpg 20200321_171007.jpg 20200321_171030.jpg 20200320_172912.jpg 20200320_172857.jpg
    Here is a picture that I just happen to have of my TRD block but it's not that clear.
    I'll take more pictures when I go back to my storage and get what it says.
    Just to Clarify, This is my TRD block, not the early gen that is in my truck currently.
    It does give an idea of where the stamp is located.
    bmf4069 likes this.
