Difference between aftermarket and adding a Line out converter to OEM
Discussion in 'Audio & Video' started by Tundra234, Dec 8, 2020.
  1. Dec 8, 2020 at 12:31 PM
    Tundra234 [OP] New Member
    We were talking about this at work. What are the differences between an OEM head unit with a line out converter such as an Audio Control LC7i and amps versus an aftermarket head unit and amps?
  2. Dec 8, 2020 at 1:46 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    The latter is Better. That's the Only way I've ever replaced/added in a stereo to a vehicle.
    Using a high level speaker input converter to low level RCA is not really High Fidelity, noise is introduced which may be heard depending on other variables. Do it the right way, aftermarket HU/amps. You won't regret it.
  3. Dec 8, 2020 at 1:50 PM
    ezdog
    ezdog New Member
    Gateway To The West
    A High Level Converter really just takes the already amplified signal,distortion and all and knocks it down so another amp can do the same thing again.
    Like said above you really want to start off with a Line Level Signal if you can and just amplify it once.
  4. Dec 8, 2020 at 1:52 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    OEM radios usually do not have RCA outputs for amps, that is why you would to need something like the audio control LC7. Most aftermarket head units have RCA outputs so you can add aftermarket amps. But not all enough outputs , some only have one. If you plan to run a multi channel amp, I would recommend getting one that has front, rear, and sub output. If using aftermarket radio, generally you will get better sound using the RCA outputs built in, therefore no need to use LC7
