Diff/Transfer Fluid Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by unfazed, Apr 26, 2024.
  1. Apr 26, 2024 at 12:35 PM
    unfazed
    unfazed [OP] New Member
    Dakota
  2. Apr 26, 2024 at 2:11 PM
    Mr Badwrench
    Mr Badwrench New Member
    I just googled Toyota gear oil prices and I threw up all over the wall. Where can you get Ravenol?
  3. Apr 26, 2024 at 3:18 PM
    skylinekin
    skylinekin New Member
    Michigan
    2021 Tundra DC TRD PRO (Current), 2014 Tundra SR5 DC TRD OR (Sold)
    Redline also makes a compatible fluid for transfer case, MTLV I think? For the diffs I’d recommend 75w90 if you do any heavy towing or off-road.
  4. Apr 26, 2024 at 3:48 PM
    d33pt
    d33pt New Member
    Mr Badwrench[QUOTED] likes this.
  5. Apr 26, 2024 at 6:21 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    The Redline is sold on Ebay. I have it in my cart for when I get ready to do the tcase fluid change.
  6. Apr 28, 2024 at 1:40 PM
    fallen0
    fallen0 New Member
    Minnesota
    2017 Tundra TSS OFF-ROAD, 2020 Mazda CX-5, 1997 Mazda Miata
    For the diffs I just went with Valvoline 75-90 Gear oil.
    Transfer case I plan to use Redline MTLV.
    CaptRussia253 likes this.
  7. Apr 28, 2024 at 2:56 PM
    TexasGuyTX
    TexasGuyTX New Member
    Ryan
    2007 SR5 Super White
    PRO BOX w/ RF Mono Amp Limited 20" Wheels HID's on Low Beams Tip Delete Before Axle
    just put valvoine 75-90 syn in my 07 5.7 2WD sounds great or lack there of... no noises or whining.. was doing some bilstien 4600's so i figured id do it while im under there
  8. Apr 28, 2024 at 6:25 PM
    mfelton18
    mfelton18 New Member
    South Central Texas
    2014 Magnetic Grey SR5 4x4 crewmax
  9. Apr 28, 2024 at 6:40 PM
    TexasGuyTX
    Ryan
    ya I like the squeeze packs, fixing todo it on my sedan with them aswell
  10. Apr 29, 2024 at 10:54 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    If your rear differential is stock, you do not have a LSD. Toyota’s “Auto LSD” in Tundras is nothing more than traction control via ABS. The differential is WFO.
    The oil you’ve selected is fine. When I had stock diffs, I just ordered the whole Ravenol kit from Blauparts.com. I think it was 7 quarts of 75/85(or 90?) gear lube and 2 quarts of 75 weight MTF for the t-case. Easy peasy.
    Now I run basic ass Valvoline 75/95 conventional GL-5 gear oil in the rear because Powertrax says so for the Grip Pro. I still use the Ravenol in the front and transfer case, but will start using the same Valvoline in the front as I do in the rear.
  11. Apr 30, 2024 at 3:17 AM
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    I read about every thread I could find and watched countless videos. I put the valvoline referenced above in all 3. If I didn’t live south of Houston I would not have put the slightly more viscous oil in the transfer case.
  12. Apr 30, 2024 at 5:08 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    First change I used redline 75w85. This time I used Valvoline 75w90 (without LSD additive). No appreciable difference.
  13. May 6, 2024 at 9:24 PM
    Tsm503
    Tsm503 Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    Valvoline 75w90. The squeeze pouches make it a lot easier as well.
  14. May 7, 2024 at 9:08 AM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
  15. May 8, 2024 at 11:50 AM
    Tsm503
    2021 DC SR5
  16. May 8, 2024 at 5:54 PM
    Giskk
    Giskk New Member
    Mississippi
    2021 Cement Tundra TSS Off-road
    I used Redline MTLV GL-4 for the transfer case at my 30k fluids change. Transfer case now shifts better than with the factory fill in it.
  17. Jun 2, 2024 at 6:24 AM
    Alby
    Alby New Member
    2019 Toyota Tundra 5.7L
    Gday everyone. Just chiming in to this Forum.
    First post as a matter of fact.
    What are your thoughts on Amsoil 75W90 Severe Gear for the diffs?
    Mine have not been done.
    2019 , stock everything.
    I pull a bass boat.
    Transmission oil just done at the stealer ship.
    Appreciate your help fellas.
