Diff drop
Discussion in 'Suspension' started by That_4.6_Tundra, Feb 21, 2022.
  1. Feb 21, 2022 at 6:00 PM
    That_4.6_Tundra
    That_4.6_Tundra [OP] New Member
    2012 Metallic Silver 4.6 V8 Tundra
    Underglow kit and interior lighting kit from ledglow, leveling kit and cherry bomb being added soon
    I'm looking at installing a 3" front 1" Rear leveling kit on my 2012 tundra. Should I look at also installing a differential drop kit?
  2. Feb 21, 2022 at 6:06 PM
    I would and did twice with a 2.5" lift. Anytime you alter the the front end geometry above 3", it can't hurt to do the diff drop. Another $30 or so.
  3. Feb 21, 2022 at 6:17 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I used two 3/4" spacers I found in my nuts-n-bolts drawer.
  4. Feb 21, 2022 at 6:22 PM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    I think it’s a good idea as well. My 3/1 kit came with them and I personally think it best to keep those parts aligned as much as possible to put less strain on them.
  5. Feb 21, 2022 at 6:25 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Did you actually check your cv angle change? There's some reputable guys on this forum that say it's not only unnecessary, but damaging to your diff pinion.
  6. Feb 21, 2022 at 6:31 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If you buy a 2" lift shackle from Coachbuilder he'll throw in a carrier bearing spacer. It is 1.25" lift and the spacer is .75" I believe...
  7. Feb 21, 2022 at 6:52 PM
    ...plus the longer bolts required too I'm assuming.
  8. Feb 27, 2022 at 7:20 AM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    From eyeballing it when I added the front shock spacer from the leveling kit it went to about a 45 degree angle down. Then adding the one inch diff drop spacer didn’t bring it back to where it was but definitely seemed to give it some lift closer to where it was at stock. I’m definitely open to doing more research though. Last thing I would want is to do more harm than good.
    MadMaxCanon[QUOTED] likes this.
