Diff Drop with ADS 2.5????
Discussion in '2.5 Gen Tundras (2014-2021)' started by TLang72, Nov 24, 2019.
  1. Nov 24, 2019 at 1:45 PM
    TLang72
    TLang72 [OP] New Member
    Tyler
    Just installed ADS 2.5 coilovers with remote res on the front and 2.5 piggys on the back. I think it is about a 4in lift.
    Do I need to add a diff drop or change anything else. I think I will be adding 1in shackles to the rear. Thanks.
  2. Nov 24, 2019 at 1:48 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    4"s??
    Uh, crank it down a couple for sure.
    Also, wait until the suspension settles a touch and see where you stand lift wise and check the angles then. At 3" I did not and continue not to run diff drop spacers after about 70k miles.
    zcarpenter92 likes this.
