diff drop for procomp 6" lift
Discussion in 'Suspension' started by andy9743, Jan 4, 2017.
  1. Jan 4, 2017 at 10:31 AM
    andy9743
    andy9743 [OP] New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    hey guys. truck is new to me. has a 6" pro comp lift. i have a slight vibration upon acceleration. from what i read i should have a diff drop...what is recommended for a 6" lift?
    thanks guys!
  2. Jan 4, 2017 at 12:23 PM
    andy9743
    andrew
    nw ohio
    exactly what i am talking about. what drop did you use? thanks for the reply!!
  3. Jan 4, 2017 at 12:26 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    drop the carrier bearing
  4. Jan 4, 2017 at 12:34 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    That stock bolt is pretty long, all you need is a spacer like the pic above.
  5. Jan 4, 2017 at 2:21 PM
    Believe toytec.com has carrier bearing spacers 12$
  6. Jan 5, 2017 at 3:56 PM
    andy9743
    andrew
    nw ohio
    Are spacers specific for amount of lift?
  7. Jan 6, 2017 at 9:25 PM
    joeguam
    joeguam New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
    With your ProComp 6" lift the bearing drop spacers from the manufacture measured about an inch. When I added the +3 CoachBuilder shakles it had some vibration so I purchased the 1.25 carrier bearing drop kit and the vibration was very very minimum.
  8. Feb 24, 2017 at 1:06 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Did you had to change out your OEM front struts? AM having a wobble and bounce at 45-45 mph... Rough country I need to change the OEM front struts...
  9. Feb 24, 2017 at 5:28 PM
    joeguam
    joeguam New Member
    JOE
    My vibrations were because of the drive line and not the front struts. My lift kit came with the Pro Comp coilovers so yes it was changed out.
  10. Feb 24, 2017 at 5:37 PM
    Les7311
    So what is your recommendations to my bounce and wobble? Change OEM front shocks?
  11. Feb 24, 2017 at 6:34 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    The front diff should be dropped as a part of the new crossmember that is installed Witt a 6" lift kit. A 6" lift without a drop in the front diff would lead to a huge cv angle that would destroy the joints.
    As others said you most likely need the carrier bearing drop for your rear 2 piece drive shaft.
  12. Feb 24, 2017 at 7:21 PM
    Les7311
    Am new to the truck world and lift kits. I do recall seeing the shop dropped the front diff and also cutting.
    Don't know much about carrier bearing, but will surely google it. Is that also another solution to this wobble and bounce?
  13. Feb 24, 2017 at 8:12 PM
    csuviper
    Broomfield, CO
    The wobble and bounce seems to be something different. Wobble in the steering wheel is typically tire related. Bad wear or not balanced properly. Bounce could be bad shocks or worn springs. If you have a 2008 with stock Coilovers then you should def replace. Full length Coilovers are ideal.
    Les7311[QUOTED] likes this.
