Diff drop - do I need an alignment?
Discussion in 'Suspension' started by nonamelogic1, Sep 1, 2025 at 5:24 PM.
  1. Sep 1, 2025 at 5:24 PM
    nonamelogic1
    nonamelogic1 [OP] New Member
    2023 Tundra SR5 TRD Sport
    3" Westcott Lift, 35" tires
    I have a 2023 tundr SR5 trd sport. It has the air bags that self level which I really enjoy. That being said, the guy that I purchased this truck from had installed a westcott level kit, and I don’t think he installed the westcott lever arms for the air bags as I have a slight ‘squat’ at ‘level’ height.
    here’s what my current plan is, I ordered a 3.5” lift from rough country that has the air bag spacers, sway bar relocation bracket, etc. My question is if I just install the diff drop and air bag spacers, do I need an alignment? I was going to replace the westcott pucks in the current shocks at a later date with true shocks for the lift I want. But tbh I don’t want to do a double alignment.
    also if I put the airbags on “high” mode it sits about an inch too tall. But the airbags go back to normal once you pass 18mph. I dont know a way around it.
    TIA for the insight!
  2. Sep 2, 2025 at 7:57 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    The diff drop isn't the question...the 3.5" lift requires an alignment. You also will need the silver CV axles for a 3.5" lift that are typically included in the Toyota OEM 3" lift kit if you don't already have them. If you just bought the spacer and not a kit that includes UCA's you'll need aftermarket UCA's as well. If you already have a 3" lift from westcott maybe you already have UCA and different CV axles?? who knows.
  3. Sep 2, 2025 at 7:58 AM
    teab
    Ty
    Denver
    OH and the admins will move this post to the suspension section shortly I'm sure of it.
  4. Sep 2, 2025 at 8:07 AM
    nonamelogic1
    I understand it will when the shocks are out in. I was just curious if I basically did the diff drop and rear air bag spacers if I’d need an alignment.
    I chatted with RC support about the axles to. They say this kit is good to run on black axles
    Here’s the link for it: https://www.roughcountry.com/search/71300
