Diff drop and carrier bearing drop.
Discussion in 'Suspension' started by Joeshaker, Oct 24, 2016.
  1. Oct 24, 2016 at 8:25 PM
    Joeshaker
    Joeshaker [OP] New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    I'm in the process of putting a better lift on my truck. Currently have two inch spacers on top of the factory trd coilovers. Got the bilstein 6112 set up today on the top setting. I'll be installing them in the next couple days. I've got two diff drop kits. One has smaller billet spacers and slightly thinner bolts. The other has factory diameter bolts and larger spacers, but they are cheap plastic. Should I use either or find a better kit? On the rear I've got the 5160, put them on Sat and they are awesome. I've got Toytec shackles set at 1.5" lift. How much do I need to drop the carrier bearing? Amado
    Chuckm likes this.
  2. Oct 24, 2016 at 10:39 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Why not use the billet spacers with the beefier bolts? (some drilling may be required). That said most of the "plastic" spacers I've seen are more than sufficient. For 1 ½ rear lift, you probably wan't about ¾ inch bearing drop spacers.
  3. Oct 24, 2016 at 10:46 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    I'm thinking about drilling out the hole in the billet spacers. Seems like it would be a pain in the ass to hold them, even in a vice. They're not very big around either, they look small. I think I'll try running the plastic ones for a while and see how they hold up. I was thinking 3/4 would be about right for the carrier bearing. Thanks
  4. Nov 20, 2016 at 5:51 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I ordered a supreme suspension diff drop kit it's beefy and a coach builder carrier bearing drop believe it's 3/4 of a In thick
  5. Jan 17, 2017 at 2:27 PM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Is carrier bearing and differential drop the same thing?
  6. Jan 17, 2017 at 2:30 PM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    No, diff drop is front, carrier bearing drop is for the center driveshaft support to the rear end.
    texasrho83 likes this.
  7. Jan 17, 2017 at 2:38 PM
    joem1cha3l
    Albany, NY
    Eric
    Coachbuilder made me aware of this product so I'll be purchasing from him. I have some vibration when I'm coming to a stop. Think this will help with that or will it likely only help for acceleration vibration?
  8. Jan 17, 2017 at 4:14 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    The carrier bearing drop is just a spacer. I bought a 3/4" spacer from the hardware store for $2 and re-used the same bolt. IMG_1657.jpg
    myt1, pvn.beluga, Rica25 and 6 others like this.
  9. Jan 17, 2017 at 4:34 PM
    My Tundra already had a diff drop. I could have purchased the same parts at ACE for maybe $10 instead of $30. (Don't pay more than $30 by the way) I have zero vibs with almost 3" OME lift in front and AAL + ToyTec shackles in rear FYI.
    BlackSheep likes this.
  10. Mar 2, 2017 at 6:13 AM
    Zackmo47
    Zackmo47 New Member
    Zack
    What are the dimensions. I was going to pay $25 for coach builders shipped but 5-10 sound smuch. Better local orange place has spacers for $.97 if under 3/4" are the stock bolts long enough ?
    LaaMahTundra likes this.
  11. Mar 2, 2017 at 6:14 AM
    joem1cha3l
    Albany, NY
    Stock bolts can be reused
    Rica25 and LaaMahTundra like this.
  12. Mar 2, 2017 at 6:17 AM
    Zackmo47
    Zackmo47 New Member
    Zack
    Any idea bolt diameter?
    Rica25 likes this.
  13. Mar 2, 2017 at 6:23 AM
    joem1cha3l
    Albany, NY
    That I don't recall, sorry
    Rica25 likes this.
  14. Mar 2, 2017 at 6:24 AM
    Zackmo47
    Zackmo47 New Member
    Zack
    No problem thank you I'll remove one and measure and reinstall so I can have the right inner diameter.
  15. Mar 2, 2017 at 6:48 AM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    I highly recommend you actual measure and determine if you need a CB drop and how long rather than just assuming. It takes 5 minutes with an angle finder. The other thing to keep in mind with a CB drop, is while you might be getting the second two u-joints properly phased, but the lower you drop the CB, the more out of spec you put the u-joint on the xfer case flange.
    https://www.youtube.com/watch?v=f1m-Fh5kiRU&sns=em
    Also diff drops don't do anything on second/third gen except move the oil away from the pinion bearing. Seriously, it does nothing. Your cv angles are the same with and without the drop.
    Y0TA PR0, Drainbung, the red and 7 others like this.
  16. Mar 2, 2017 at 6:55 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    I had never heard of a Carrier Bearing before yesterday. My wife had her '16 Tacoma lifted at the dealership when she bought it and apparently they didn't adjust the carrier bearing and it started making a noise when she'd accelerate from a complete stop. They "fixed" it and so far today it hasn't done it.
  17. Mar 2, 2017 at 6:57 AM
    joem1cha3l
    Albany, NY
    Yep mine made a bad vibration and noise at start and stop. Almost felt like warped rotors. I knew it wasn't that, but that's what it felt like prior to the carrier bearing drop.
    LaaMahTundra and TTU19[QUOTED] like this.
  18. Mar 2, 2017 at 7:37 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    great info / clarification
  19. Mar 2, 2017 at 10:46 AM
    Medic
    Medic New Member
    Ontario, Canada
    2014 Limited Crew Max
    Might the smaller billet spacers be for the skid plate? Last diff drop that I installed also came with spacers to lower the skid plate. Just a thought
  20. Mar 2, 2017 at 3:25 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    No, the ones for the skid plate are way smaller. I picked up a good one from Toytec. Installed it several months ago, no issues.
  21. Oct 11, 2018 at 6:00 AM
    Yota18
    Yota18 Inferno Club
    Upstate New York (the real NY)
    18’ 5.7 TRD Off-Road
    Stock
    Do you know what size drop you have. I see 3/4 or 1 1/4 seem to be the average. I have the oem lift with 34’s so about 4” I’d lift I’m thinking going with the 3/4
  22. Oct 11, 2018 at 6:39 AM
    Most diff drops kits are the same as far as drop. Maybe 1".
  23. Oct 11, 2018 at 7:49 AM
    Yota18
    Yota18 Inferno Club
    Stock
    I was referring to the carrier beam drop. I think hought that’s what you had. I have a dif drop. Thanks though for the reply though lol
  24. Oct 11, 2018 at 8:45 AM
    Haha...No I have no need for the carrier bearing drop with my current setup.
  25. Oct 11, 2018 at 8:51 AM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Interesting point! I always thought the diff drop moved the entire thing down an inch or so. Is that not how they work?
    Got some pics anyone?
  26. Jun 18, 2019 at 8:52 AM
    Biff_Elwood
    Biff_Elwood New Member
    Denver
    2014 Platinum
    Im working on it!
    I'm going back over all my previous research and wanted see if there has been any consensus on this topic.
    Im going with the top setting on the 6112s and 1.5" Toytec shackles and want to be sure if I need these or not.
    Thanks in advance!
    Big J likes this.
  27. Jun 29, 2019 at 5:45 PM
    ZekeFreak
    ZekeFreak New Member
    I don't recommend any cb drop, it will damage something at the trans case, you also will never get rid of any vibration completely.....you might find a happy medium but it will never disappear.
  28. Jun 29, 2019 at 6:59 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Fake news.
    Atomic City Tundra likes this.
  29. Jun 29, 2019 at 9:11 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    I have been watching too and no firm conclusion yet to this idea of fluid starvation or if it even helps.
  30. Jul 1, 2019 at 3:56 PM
    jberry813
    Lake Tahoe
    LOL. Please go on. What is the “something” at the transfer case?
