Diesel Sounding 5.7
Discussion in '2.5 Gen Tundras (2014-2021)' started by Andrew19, Apr 22, 2019.
  1. Apr 22, 2019 at 8:03 AM
    Andrew19
    Andrew19 [OP] New Member
    Andrew
    Baytown TX
    2019 TRD PRO
    Stock
    So I went to help a guy jump his truck today and when i popped the hood the first thing he said is dang they make these with a diesel now. LMAO!!! I said no still gas. Then he told me I needed to get it looked at. I just looked at him......then at his truck. 2012 ish Silverado and proceeded to shake my head. :D
    Sas likes this.
  2. Apr 22, 2019 at 8:17 AM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    I’ve been told that before, thousands of miles later, no problems.
  3. Apr 22, 2019 at 8:20 AM
    Andrew19
    Andrew
    Baytown TX
    2019 TRD PRO
    Stock
    Oh dont be mistaken, I know well enough that my truck is fine I just thought it was hilarious.
  4. Apr 22, 2019 at 8:25 AM
    Steve89gt
    Steve89gt New Member
    2018 Limited CM
    De-badged, De-chromed, TRD CAI, TRD Exhaust, Bilstein 5100s, Fuel 18 x 9 wheels, BFG KO2s 275/70/18, ESP Underseat Storage
    All this time you’ve been using the wrong fuel...; )
    stanky likes this.
  5. Apr 22, 2019 at 8:30 AM
    BlueDream
    BlueDream New Member
    2015 Tundra Dbl cab SR5 5.7
    6" procomp stage 3 lift, Method NV 18x9, Cooper STT pro 305/70R18, AFE air cleaner, LED fogs, Ranch hand Grille guard, Rhino liner, retrax bed cover, Flowmaster Duals, 15% Tint, vinyl chrome delete
    Most of you guys I would think have never owned a diesel. These trucks sound Nothing like any diesels I have or have owned in the past. Yes my 5.7 has the typical rumble sound of a well built V8, But I can tell you "Real diesel's Rattle". Maybe newer diesels conceal the true sound. You hear my 03 Cummins Turbo, built with mods and Straight pipe, even at idle, you will immediately know it aint no "gasser".
    Rex Kramer and 15Yota like this.
  6. Apr 22, 2019 at 8:36 AM
    P-Factor
    P-Factor New Member
    aluminum block + duel overhead cams + duel cam chains = 5.7
    All is good and I wouldn't have it any other way. :thumbsup:
    Roborob70, Metro14536, stanky and 2 others like this.
  7. Apr 22, 2019 at 8:39 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    Normal. Was told its something with the VVT. Also my wife’s 6cyl lexus sounds the same.
  8. Apr 22, 2019 at 8:40 AM
    Andrew19
    Andrew
    Baytown TX
    2019 TRD PRO
    Stock
    Only diesel I've ever owned was a 99 7.3 powerstroke. And I would agree the 5.7 sounds nothing like it. On the flipside I didn't say the 5.7 sounds like a fully built Cummins with a straight pipe. With the hood up listening to the motor it just has a slight rattle or clank. Not like I'm about to try and roll coal all the way down the block.
    stanky likes this.
  9. Feb 13, 2023 at 11:05 AM
    stanky
    stanky New Member
    2021 4x4 crewmax
    Platinum
    Mine is loud as hell, and I'll be the one to admit I took it to the shop at about 10k, they told me it was fine. They even had another '21 tundra in the shop that they compared mine to and said they both sounded the same.
    14309 miles and its getting louder.
    Guys I am a crane operator. I burn diesel for a living...no it doesn't sound just like a diesel but I can see the comparison. The sound kinda rolls over like a diesel...still sounds unhealthy being gas.
    Metro14536 likes this.
  10. Feb 13, 2023 at 1:20 PM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    I know what mine sounds like, so when it doesn't sound like it normally does then I'll start to worry. 2007 CM, 221k
  11. Feb 15, 2023 at 5:21 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    With 0w-20 oil it sounds like a Yanmar tractor engine, with 5w-30 it sounds like a normal v8. It's probably also from the type of aluminum in the pistons. I doubt they could just use regular old cast pistons because the stroke on the thing is longer than a 454 big block and the piston speeds are quite high for a street engine.
  12. Feb 15, 2023 at 6:59 PM
    bft305
    bft305 New Member
    2016 tundra limited
    Haha! My mother in law said that about mine as well. At idle with the TRD dual exhaust, I can see how a non toyota person can mistake the normal toyota tick sound for a diesel. ;)
  13. Feb 16, 2023 at 3:34 AM
    blanchard7684
    blanchard7684 New Member
    if you think a 5.7 is noisy, try a 4.0 in the 4runner.
  14. Feb 16, 2023 at 7:54 AM
    Fundra14
    Fundra14 New Member
    2014 Toyota Tundra Platinum
    None
    Mine gets some timing chain slap when it's cold and it sure sounds like...something. Trying some Seafoam treatment now. Unfortunately, I bought my 14 Platinum with a limited maintenance history.
