Did this fall off my MY23 Tundra?
Discussion in '3rd Gen Tundras (2022+)' started by Stegosaurus437, Nov 1, 2023.
  1. Nov 1, 2023 at 5:24 PM
    Stegosaurus437
    Stegosaurus437 [OP] New Member
    BC
    Black ‘23 Tundra Platinum Hybrid
    Did this little plastic hole-plug fall off my truck? Doesn’t look too important… just something to close off a hole in a piece of sheet metal, if anything. It’s about the size of a US/Canada $.25 coin.
    Thanks for your time!
  2. Nov 1, 2023 at 7:22 PM
    Adam B
    Adam B New Member
    2022 Tundra TRD OFF-RD LIMITED- Green & 2024 Tundra TRD OFF-RD LIMITED- Silver
    I know that these are found on the control arms, you could check that.
  3. Nov 2, 2023 at 6:18 AM
    Tom976
    Tom976 New Member
    Tom
    Go under the truck and look at the frame.
    You may see other plugs like that around the underside of the truck.
  4. Nov 2, 2023 at 7:38 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Pull back your carpets and see if it is a floor plug. There have been reports of water in the cab soaking everything.
    1lowlife likes this.
  5. Nov 2, 2023 at 7:44 AM
    TexasCabledawg
    TexasCabledawg New Member
    2024 Land Cruiser (had a ‘22 Tundra)
    Look on the ends of your doors near the handles
    1bad2k and 1lowlife like this.
  6. Nov 3, 2023 at 3:02 PM
    hinkle
    hinkle New Member
    aaron
    portersville, pa
    '23 Blueprint
    I found one of those too. I saved it thinking it fell off the truck too.
  7. Nov 3, 2023 at 5:06 PM
    minium
    minium New Member
    That's def it OP...
  8. Nov 4, 2023 at 7:04 AM
    hinkle
    hinkle New Member
    aaron
    portersville, pa
    '23 Blueprint
    checked both doors on mine and those plugs are there. If I ever find where it fell from I'll share.
    pwpblue likes this.
  9. Nov 4, 2023 at 7:13 AM
    minium
    minium New Member
    Anybody in here PDI these things? I wonder if they deliver to the dealership without them and maybe they just dropped one in your truck when they were putting them in?
    weird
  10. Nov 5, 2023 at 6:18 AM
    hinkle
    hinkle New Member
    aaron
    portersville, pa
    '23 Blueprint
    Mine looks like the OPs. Close but not a match.
    minium[QUOTED] and Leo's first like this.
  11. Nov 5, 2023 at 6:19 AM
    hinkle
    hinkle New Member
    aaron
    portersville, pa
    '23 Blueprint
    If these are the ones you are referring too, they're flat without the impression.
  12. Nov 5, 2023 at 6:21 AM
    hinkle
    hinkle New Member
    aaron
    portersville, pa
    '23 Blueprint
    They don't match the ones on the tailgate either. The plugs on the frame, that I found, were also flat like the control arms.
  13. Nov 5, 2023 at 7:31 AM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Just backed up to wash and look what I found lmao
  14. Nov 5, 2023 at 1:27 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    The mystery continues ...
    Subbed for answer.
    Gray Hawk and pwpblue like this.
  15. Nov 5, 2023 at 1:44 PM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Was the front or rear of the truck parked where you found this part?
    Gray Hawk and pwpblue[QUOTED] like this.
  16. Nov 5, 2023 at 1:49 PM
    pwpblue
    Greensburg,PA
    Front, look at this pic.
    How I park everyday.
    Gray Hawk likes this.
  17. Nov 5, 2023 at 2:08 PM
    Matt2015Tundra
    2023 1794 CrewMax
    So, can we assume it came from the engine compartment, perhaps?
  18. Nov 5, 2023 at 3:07 PM
    pwpblue
    Greensburg,PA
    Possible, it was not dirty btw.
  19. Nov 11, 2023 at 11:49 AM
    hinkle
    hinkle New Member
    aaron
    portersville, pa
    '23 Blueprint
    Crawled around under the engine bay, had the hood open, and checked the front wheel wells again. No dice.
  20. Feb 6, 2024 at 3:06 PM
    Gray Hawk
    Gray Hawk New Member
    Cincinnati, Ohio
    2023 toyota tundra 4x4 1794 edition smoked mesquite
    Tonneau cover; dash cam
    Did you ever find where this plug goes? I found a plug near my front right wheel well but cannot locate where it came off.
  21. Feb 8, 2024 at 2:38 PM
    southerntread
    southerntread New Member
    2022 Army Green Tundra Limited
    I found one in my drive way the other day on the wife's side. I thought it came off her car but I did park over there recently to unload lumber. Exact same one as OP. I assume it landed flat with the exposed side on the ground because its a little scuffed on that side. Its plastic. The tailgate, drivers door and the floor penetrations are all rubber. The plug for the LCA is plastic. I wonder if it came from the firewall?
  22. Feb 8, 2024 at 4:05 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    They are all over underneath. In the 3rd Gen Taco, our first year editions in 2016 were playing tunes like a flute on the fwy because they didn't plug any of the holes.
  23. Feb 8, 2024 at 5:11 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    There are floor pan plugs all over these trucks. My money is it is one of them. You’d likely have to pull the carpet back to see most of them.
  24. Feb 10, 2024 at 6:14 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The plug is from the rocker panel under the doors. Lay down and look up to see the hole where it belongs. When you washed it you knocked them out.
  25. Feb 11, 2024 at 12:26 PM
    hinkle
    hinkle New Member
    aaron
    portersville, pa
    '23 Blueprint
    I only see these kind on the rockers.
    pwpblue and Ruggybuggy like this.
  26. Feb 11, 2024 at 12:31 PM
    Gray Hawk
    Cincinnati, Ohio
    Ditto
  27. Feb 11, 2024 at 3:28 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I tried. They look like the ones on the 2.5 gen and was thinking they would be the same.
  28. Feb 12, 2024 at 7:13 AM
    Gray Hawk
    Cincinnati, Ohio
    Appreciate the help, sincerely as I do the other members. One day, before I reach the end of life's runway, I will know the mystery behind this stupid plug.
  29. Feb 14, 2024 at 3:32 PM
    hinkle
    hinkle New Member
    aaron
    portersville, pa
    '23 Blueprint
    Appreciate it either way!
