Did I kill my tundra?
Discussion in 'General Tundra Discussion' started by Tundrakiller, Sep 19, 2022.
  1. Sep 19, 2022 at 1:45 PM
    Tundrakiller
    Tundrakiller [OP] New Member
    2017 Tundra
    So i had the dealership perform the last oil change because they sent me a coupon, well they tightened the oil filter so tight that a 2 ft breaker bar wouldn't work. I reluctantly used an impact wrench which worked but must have cracked it without realizing it. I went on and changed the oil and started driving it when i noticed it was losing oil pressure. I pulled over to inspect and discovered the leak. I replaced the cap and refilled the oil and drove back to my shop where i flushed the engine and discovered the carnage.
    There were quite a lot of aluminum flakes with the initial flush. I didn't have any warning lights until awhile after flushing i got a check engine light with camshaft code below. I also have a slight tapping sound from the engine.
    Really not sure if I just killed my Tundra or not. Is it time for a new truck?
    20220915_183109.jpg 20220914_181736.jpg 20220915_203003.jpg 20220915_194018.jpg
  2. Sep 19, 2022 at 1:56 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    This does not sound good. Might be time for a new built motor from prospeed and supercharger.
  3. Sep 19, 2022 at 2:04 PM
  4. Sep 19, 2022 at 2:08 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    When you re-filled the oil, how much oil did it take to top it off?
  5. Sep 19, 2022 at 2:09 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  6. Sep 19, 2022 at 2:14 PM
    Tundrakiller
    2017 Tundra
    About 4 qts.
  7. Sep 19, 2022 at 3:01 PM
    Yep. Say goodbye to that motor.
  8. Sep 19, 2022 at 3:52 PM
    OV-1794
    OV-1794 New Member
    And this is why I don’t trust the dealer to do shit. Sry for your troubles and I hope everything works out for you. How many miles do you have on it? Still under the power train warranty?
    RitcheyRch and Terndrerrr like this.
  9. Sep 19, 2022 at 4:36 PM
    Tundrakiller
    2017 Tundra
    Thanks. It just hit 95k. No warranty. I should have checked for leaks after changing oil but was in a hurry and just drove it...
  10. Sep 19, 2022 at 5:08 PM
    Giskk
    Giskk New Member
    Mississippi
    2021 Cement Tundra TSS Off-road
    I hate that plastic oil filter cap. First thing I replaced.
    Wahayes likes this.
  11. Sep 19, 2022 at 5:12 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I would pull the head that the code references and hopefully it's just a fucked up valvetrain part that you can replace and bolt the head down and be good to go. Majorly sucks but I think there's a lot more hope than most in this scenario since you have a pointer to the issue.
  12. Sep 19, 2022 at 5:17 PM
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    100%. No. Nope. Not never.
    Unless you personally know the guy doing the actual work, you have to assume that your oil change has fallen to the mechanic equivalent of a fry cook.
  13. Sep 19, 2022 at 5:51 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    I don't even like taking it to get inspected. :monocle:
  14. Sep 19, 2022 at 5:58 PM
    biebs96
    PA
    This is not looking good. Please let us know what you find.
    Might not be the right time and place, but thank you for letting me know how lucky I am to have a mechanic I would trust with life.
    Hopefully this isn’t the end of the motor, the amount of metal shavings is troublesome.
  15. Sep 19, 2022 at 5:59 PM
    PermaFrostTRD
    Northern NY
  16. Sep 19, 2022 at 6:01 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Shouldn't have to; that's fkin ridiculous!!!!!
    ColoradoTJ likes this.
  17. Sep 19, 2022 at 6:21 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Fry cook equivalent or not…the dealer should be held accountable
  18. Sep 19, 2022 at 6:28 PM
    Terndrerrr
    Music City
    6UR-FE
    I agree, but at the first sign that the filter housing would not give, I would have taken it straight back to them and made them assume the risk of breaking it while attempting to remove it. I doubt the OP has any recourse now.
  19. Sep 19, 2022 at 8:37 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    If you still have filter, cut it open and scrape all the metal out, then weigh it, just for curiosity sake.
    If I were in your shoes, I'd probably run a thicker oil, clear the code, and roll with it till she blows. You could get 10 miles down the road, or 100k, who knows. It's a toyota, so the odds are in your favor.
    You could always get a salvage engine for around 5-6k.
    Your OCV (Oil Control Valve) filter could be clogged as well and could *possibly* make it throw the 0012 code (not certain though) might wanna take a look at that
    Tundrakiller[OP] and ColoradoTJ like this.
  20. Sep 19, 2022 at 8:38 PM
    Kentucky Tundra
    Kentucky Tundra New Member
    2022 Tundra SR5 TRD Offroad 6.5ft Crewmax Super Sonic Red
    Wow, sorry to see that. Now I'm worried if they make them out of plastic for the 2022 Tundras or if an aluminum or magnesium cap housing is available aftermarket. I don't have my truck yet to check and didn't see one available.
  21. Sep 19, 2022 at 8:48 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    This thread hurts the depths of my soul.
    biebs96, Tundra'25, reywcms and 3 others like this.
  22. Sep 19, 2022 at 8:48 PM
    Hoff
    Hoff New Member
    2021 TRD OFF ROAD CREWMAX
    The new Tundra as far as I know they went back to spin on oil filters.
    Kentucky Tundra and TRD VO like this.
  23. Sep 19, 2022 at 9:18 PM
    TRD VO
    TRD VO Fix It Again, Tony
    Louisiana
    2015 Inferno CrewMax TRD Pro
    This thread unfortunately thoroughly explains your username to me OP. :hattip: Hoping you can find a replacement motor for it because the new truck market is still ridiculous, at least around my town it still is.
    Tundra'25 and Tripleconpanna like this.
  24. Sep 19, 2022 at 9:19 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    While I agree a metal cap would be great to begin with, the plastic cap actually works, if its not over tightened. Every story I have seen about issues with the plastic cap have been dealer serviced. Luckily mine has never been changed by anyone but myself and I've never had an issue.
  25. Sep 19, 2022 at 9:27 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    OP, sorry to hear that. I have one more freebie and I’m just debating to just do the next one myself since I have everything already.
    keep up posted, thanks
  26. Sep 20, 2022 at 3:36 AM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    What is up with the Toyota tech’s over tightening the filter cover?
    Since I’ve been on this forum, I’ve read about this time after time.
    I had plans of Toyota doing the maintenance on my truck when I bought it but after reading on this forum, it hasn’t been to a dealer since new.
    Tripleconpanna likes this.
  27. Sep 20, 2022 at 4:15 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I don’t understand how someone with any mechanical ability can look at that brand new beefy filter housing O-ring that comes with every new filter and decide they need to tighten it with all of their strength. They’re probably forgetting to lubricate the o-ring with a little oil as well which only makes it harder to remove.
  28. Sep 20, 2022 at 5:42 AM
    Terndrerrr
    Music City
    6UR-FE
    Totally agree. Just take a few seconds to look at the thing, and maybe even read the instructions that come with the new filter.
    Low-skill techs are capable of messing it up in multiple ways. I earned a free oil change by sending my old Suburban to a local shop for some big wiring harness repairs. I ended up cashing in on the free oil change later on my 4Runner, which has the same kind of cartridge filter as the Tundra. I love this shop and trust the owner, but the new oil change guy could’ve killed my engine the same way as the OP’s.
    Long story short, the guy didn’t put the large O-ring in the right place…he pushed it past the channel it’s supposed to go in so that it acted like a gasket between the filter housing and the engine block. He torqued the filter housing into the engine block so hard that it actually worked for two weeks like that. I had no idea anything was wrong until I came out to my 4Runner with a giant puddle of oil underneath the front end. The first cold snap of Fall was the night before, and the O-ring shrunk enough to let out a quart or two in the driveway. I am so glad I walked around the front of the 4runner to move one of my kids’ toys they left in the driveway. I might not have seen the puddle otherwise.
    I took my skid plate off and removed the filter, filmed the whole thing, changed the oil in the driveway, and then drove to the shop and showed the owner what I discovered. He thanked me profusely, made his new tech watch my videos of the problem, and said I saved him from having to buy me a new engine. He’s an honest guy, and I appreciated that. But I’ve refused free oil changes from anyone ever since.
    Silver17[QUOTED] likes this.
  29. Sep 20, 2022 at 5:53 AM
    prevent
    prevent New Member
    2014 5.7L Tundra SR5 DC
    TRD Catback Stillen CAI DAP Tune Tow Mirrors Light sensor Dashcam TRD Pro Grill LED Interior lights + DRL’s
    I had to use a breaker bar to get my filter off too after being dealer serviced.
    I forget what the torque spec is, but it’s not alot. But with the breaker bar, it felt similar to the mower blades on my commercial mower which are torqued to 85 ft/lbs.
  30. Sep 20, 2022 at 7:22 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
