Diamondback Rattle Reduction
Discussion in 'Tonneau Covers, Caps and Shells' started by DZ_, Jun 28, 2020.
  1. Jun 28, 2020 at 10:15 AM
    DZ_
    DZ_ [OP] New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    A few people have commented on the fact that their Diamondback cover rattles. I have found that to be the case with mine as well. My first assumption was that it was something with the locking mechanism, but that didn't really make sense to me, since all those parts should be pretty tight when locked down. After a little investigation, I determined it was the cover rattling against the c-channel studs:
    https://youtu.be/Zo6XsymAlEc
    My simple solution that has reduced about 80% of the rattle was to caulk along the interface between the studs and cover.
    I used GE Silicone "Metal" caulk that has a nice silver color to it. Available on Amazon. One tube was sufficient (CCSB, HD cover).
    Caulking tips: take the panels off and clean the area a few times with isopropyl alcohol before caulking and allow to dry. Lay a thin bead, then go back over with your finger to help force the caulk into the joint. Lube your finger with windex.
    Materials, including some stuff I was messing around with to quiet the front panel catch.
    The infamous gappage:
    The caulk job:
    Once I figure out the kayak rack project, I'm going to insulate the underside of the cover to keep the bed cooler, and that will likely get the cover near silent.
    That said, I love the cover. Very secure, durable and utilitarian. I do think a few more weld-inches would keep it from rattling on the first place.
  2. Jun 28, 2020 at 10:24 AM
    Jack Burton
    Jack Burton New Member
    Little China
    2013 DC 5.7L TRD/OR
    Tires, Diamondback HD Tonneau w/ ATV Carrier
    Interesting. I'm on my 2nd HD and have never had a rattle. I'll keep this in mind for the future, should I ever buy another.
  3. Jun 28, 2020 at 11:30 AM
    DZ_
    DZ_ [OP] New Member
    Frederick Co., MD
    Yep, seems like some do, some don't. The guy I spoke to at DB hadn't heard of any making noise.
    Jack Burton[QUOTED] likes this.
  4. Jul 8, 2020 at 8:46 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    My SE has a slight rattle. Thank you for tracking down the likely culprit and finding a fix!
    ...and of course, posting that fix.
    NewImprovedRon likes this.
  5. Jul 8, 2020 at 6:13 PM
    DZ_
    DZ_ [OP] New Member
    Frederick Co., MD
    good deal, hope it helps.
  6. May 23, 2021 at 10:48 AM
    TundraLuv
    TundraLuv New Member
    Kent
    IA
    2018 Midnight Black Metallic Limited Crewmax
    My Diamondback HD rattles as well. I've tried just about everything and will give this a shot. Thanks!
  7. May 25, 2021 at 9:35 PM
    panicman
    Eric
    DZ- Thanks again!! I did as described and I would say the rattle is reduced 80-90%.
    I think the safety bar is the last culprit. I drove over some purposeful lumps and bumps and still got some rattle, and I am sure it’s the safety bar rattling against the front-most shock mount.
    It’s metal to metal and a fairly loose fit.
    I will come up with a fix and post!
    excelw, JoshuaA and Explorer like this.
  8. May 26, 2021 at 4:23 AM
    DZ_
    DZ_ [OP] New Member
    Frederick Co., MD
    @panicman I messed around with a couple ideas, and due to the clearances needed, none worked. One idea that I haven't explored yet is spraying underbody coating or bed liner on the safety bar and mount area, avoiding the tight clearance areas. That ought to quiet that stuff down a good bit.
    JoshuaA and panicman like this.
  9. Jun 17, 2021 at 11:16 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Finally got around to it, should have did it way sooner because I didn’t have to remove the panels, just flipped them over yest and caulked 4 seams, 10min.
    Today went for a drive with the back window down, incredible, almost like the window was up. For sure 80-90% gone, just the very odd rattle, from the safety bar? Gonna cut some small tubing and try to line it.
  10. Jun 17, 2021 at 12:21 PM
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    what are you going to insulate it with? I don't like how hot it gets under there in the summer...
  11. Jun 17, 2021 at 1:21 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    You can use Noico insulation. Cut, peel and stick. I have it inside my doors and back wall.
  12. Jun 18, 2021 at 5:03 AM
    jpod
    London Canada
    That's awesome, thanks!
  13. Jun 19, 2021 at 9:54 AM
    DZ_
    DZ_ [OP] New Member
    Frederick Co., MD
  14. Sep 4, 2021 at 7:35 AM
    MUZZLE BLAST
    MUZZLE BLAST New Member
    did this insulation help reduce the heat?
  15. Sep 4, 2021 at 7:40 AM
    MUZZLE BLAST
    I am about to order diamondback for newly purchased 2018 TUNDRA! (I found a gem of a ride. Fully loaded limited with only 16k miles on it!)
    QUESTION: Are the Diamondback cleats metal or plastic? I cannot find the info on their website. If they are plastic has anyone has any issues with them? Has anyone installed good boat cleats instead? If they are plastic I was thinking of installing good boat cleats and asking my LineX buddy to spray them for me. Thanks in advance!
  16. Sep 4, 2021 at 9:28 AM
    DZ_
    DZ_ [OP] New Member
    Frederick Co., MD
    I have not gotten around to this, though adding insulation will reduce heat transfer. Keep in mind, with the metal channels, there will be significant thermal bridging.
    Cleats: the cleats on my DB cover are plastic.
  17. Sep 5, 2021 at 10:44 AM
    panicman
    Eric
    The cleats are very solid. I have strapped heavy stuff up there and had no issues.
    DZ_[OP] likes this.
  18. Sep 5, 2021 at 11:36 AM
    DZ_
    DZ_ [OP] New Member
    Frederick Co., MD
    Agreed. Christmas trees, cabinets, furniture, camping gear on long distance trips... never a doubt.
  19. Sep 7, 2021 at 4:52 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    The initial job only requires about 1/3 the tube, I wanted to use up more of the silver caulking and re-did the 4 full widths, but I also noticed small L brackets that could use them too. And to solve some of the safety bar rattle, I wrapped an elastic band several times around the hydraulic holder where it hits, now the bar always contacts rubber. Quietest so far!
    NewImprovedRon, DZ_[OP] and panicman like this.
  20. Sep 7, 2021 at 6:09 PM
    DZ_
    DZ_ [OP] New Member
    Frederick Co., MD
    Can you post a couple pictures when you have a chance?
    panicman likes this.
  21. Sep 8, 2021 at 6:46 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    There's several of these welded L brackets with unwelded gaps, not really sure if the extra caulk does anything but it only takes a few minutes to apply.
    The rubber band buffers the safety bracket banging up and down. The 3M tape buffers the bracket going side ways which also clangs. The fixes don't impede moving the bracket to raise the lid as normal which is the shown position:
    DZ_[QUOTED][OP] and panicman like this.
  22. Sep 8, 2021 at 7:42 AM
    DZ_
    DZ_ [OP] New Member
    Frederick Co., MD
    Ok, I'm following you now. My cover was constructed differently. I did as shown, but don't think it was effective. I played around with other ideas, but didn't have the clearances around the brackets. I think spraying the black metal latch with a rubberized coating in certain areas may help.
    JoshuaA likes this.
