Diamondback and Gas Can
Discussion in 'General Tundra Discussion' started by kurtwp, Jun 6, 2018.
  1. Jun 6, 2018 at 5:19 AM
    kurtwp
    kurtwp [OP] What
    Kurt
    Charlotte, NC
    2016 Tundra Limited TRD 4x4 Off Road DC
    I have a Diamondback cover and am curious to know thoughts about carrying/leaving gas locked in the bed. The gas can is a Wavian 20L Nato. I can strap to the top and lock it but hey, I am lazy. There will be other items in the bed such as stuff to go on vacation with. The majority of the items in the bed will be removed frequently. The truck will be in direct sunlight most of the time.
    Kurt
  2. Jun 6, 2018 at 5:53 AM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    No way in hell I would even consider it
  3. Jun 6, 2018 at 5:56 AM
    THIS^^^ The direct sunlight thing is a game changer.
    jewsNbrews and 4x4_Angel like this.
  4. Jun 6, 2018 at 6:19 AM
    kurtwp
    kurtwp [OP] What
    Kurt
    Charlotte, NC
    If the can was on top of the cover it would be physically in the sunlight. Wouldn't that be worst then having it protected from the sunlight by being under the cover? You have taken the direct sunlight from hitting the can which in my opinion would heat the can up greater if was not shaded from the sun by being under the cover. As for the fumes, this is a 20L metal can that is sealed and has only 5 gallons of gas in it which leaves a lot of head space for fume expansion.
    I have noticed that the DB cover itself can get extremely hot but when I open it up I don't notice the same heat in the bed itself. Matter of fact my cab seems to be hotter than the bed. Might be time for a temperature experiment.
    The safest bet would be just to leave it at home.
    Kurt
    Black Wolf likes this.
  5. Jun 6, 2018 at 6:58 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Good question, I usually carry an empty can but thinking of filling it for the long drive to the campground, under the DB, then put the gas in the tank when I got there if I didn't need it. Would wedge it on the left:
  6. Jun 6, 2018 at 7:23 AM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    i keep one under my cover when i go out far, i say go for it :taco::kona::jellydance::dancingbacon::broccoli::bananadance:
  7. Jun 6, 2018 at 7:31 AM
    Achuop
    Achuop Stormtrooper 5.7
    Anthony
    Orange County, CA
    2015 Tundra Crew Max TRD 4x4
    TRD Pro grill, Magna Flow Exhaust, 3/2 leveling kit, TRD sway bar, black out emblems, Bakflip G2 cover, 20” ProComp wheels and Tires and lots of love and affection.
    Let’s be realistic. Some people have an external gas tank in the bed. I think you should be fine as long as it’s in a nice solid container. Get a heavy duty gas can and make sure it is strapped up securely. The cover is a plus and will help keep the fuel cool.
    jewsNbrews likes this.
  8. Jun 6, 2018 at 7:36 AM
    I carry gas for my chain saw and generator in the back. I have a topper and leave the side windows open a bit. The DB cover should be OK the more I think about it. Go for it!
  9. Jun 6, 2018 at 7:58 AM
    speckmon
    Thornton, CO
    believe what you want, but i think some of ya'll are being a bit narrow minded to think that our fuel systems are air tight. I mean you're basically sitting on a 30 gallon tank of gas, what's the difference in having a tank in the bed?
    Cars and trucks spew fumes everywhere, especially older models with corroding seals and the likes. Hell my '72 beetle smelled like gas 24/7, gas tank pretty much on my lap and i smoked doobs like a damned chiefton in that thing. do you see vehicles all over exploding in the hot sun? or lawn care trailers? stupid jeepers with jerry cans hanging of the back to look cool? I don't.
    hot air isn't going to spontaneously combust gasoline...there's just a lot of fucking nit whits out there that have done stupid shit and some fear monger has exploited their dumb ass.
    food for thought, but i think you're fine.
  10. Jun 6, 2018 at 8:12 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    If the gas cans are anything like what the military uses my concern would be the slight spillage from hitting bumps and the smell of fuel under the cover.
  11. Jun 6, 2018 at 8:23 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Just don’t fill more than 4 gallons. When I fill my 5 gallon can with more than 4 gallons, the heat and bumps from wheeling cause it to overflow and spill onto the bed. And I also purge it once or twice a day when it gets really hot or cold.
    dcsleeper408, 4x4_Angel and speckmon like this.
  12. Jun 6, 2018 at 8:25 AM
    speckmon
    Thornton, CO
    boom. see, there is common sense on this forum.
    joonbug[QUOTED] likes this.
  13. Jun 6, 2018 at 9:11 AM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Wavian are the best cans out there imo. I have 8 of them. I have a cabinet that I can carry 5 in... has individual dividers .
    jewsNbrews and speckmon like this.
  14. Jun 6, 2018 at 10:34 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    If you bleed fumes or spill, everything you put in your bed will smell like gasoline. For this reason alone, if I did not need the extra 5 gal. I would not do it. That said, I haul gas and diesel inside my shell pretty often.
  15. Jun 6, 2018 at 11:37 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    If you're just going to camp then taking out of the bed you should be fine
