Diagnosing my possessed Tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by 808dakine, Apr 2, 2017.
  1. Apr 2, 2017 at 12:15 AM
    808dakine
    808dakine [OP] New Member
    Aloha from Maui, HI.
    Just recently broke down due to a electrical issue in a remote area. Hit some sort of pot hole and it rattled something and the truck completely shut off. Immediately after shutting off, while I was in 2wd, the 4lo, 4hi, VSC and traction lights all appeared and was flashing. (No CEL).
    Needless to say, I had to get a tow back to my home. After a visual inspection of the engine bay, fuse blocks, I found the EFI no1 Fuse was blown, So i replaced that and tried to start the truck.
    Before I could even turn the key to Ignition, it started in the Acc position.
    The starter engaged and stayed on even after the truck had a successful ignition. After turning the key to OFF, the starter was still engaging thus resulting in pulling the battery terminals off.
    Since then I have check the starter relay to see if it was functioning properly. It is. So after thinking about it, I think I have narrowed it down to a malfunctioning solenoid/starter or the key ignition relay or switch.
    Has anyone had this kind of issue and how has it been rectified?
    aperezsh and Backslider like this.
  2. Apr 2, 2017 at 12:19 AM
    808dakine
    Vehicle specs:
    2007 Crew max 4.7L
    56k
    No engine upgrades
    Remote start: unknown if previous owner had Viper alarm or Remote start
    Repairs/Maintence with in 2 years:
    ~Replaced Alternator within 1 year, less then 3k miles(Avg 6-7k/year)
    ~New battery within 1 year, less then 3k miles(Avg 6-7k/year)
  3. Apr 2, 2017 at 12:35 AM
    Sounds like a wheel/abs sensor based off of the description of the dash lights
    Patriot and BlueFalconActual like this.
  4. Apr 2, 2017 at 12:43 AM
    808dakine
    Well after I replaced the EFI fuse, all the dash lights went away. Sorry I forgot to mention that but Ill check that out tomorrow morning.
  5. Apr 8, 2017 at 1:30 AM
    808dakine
    Ok so i got it back from the shop and the NSS(Neutral saftey switch) was at fault. I started up the truck, no problem. Ideling around 500rpm. Put it in reverse, no problem. Shifted into drive and it took about 4 seconds to engage. Though that was odd, so i drove it back into the driveway and it died. The EFI fuse blew again but this time the A/T Temp light was on. I have no idea what is going on. I live in Hawaii so its mostly in the 80's all year round.
  6. Apr 8, 2017 at 5:17 AM
    khunk
    khunk Tundra Fan
    Marty
    Leland, NC
    2017 CM Limited 4x4
    Maybe your Truck has a touch of Island Fever.........:notsure:
    Law323 and GNTundra like this.
  7. Apr 8, 2017 at 11:00 AM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Welcome from Kansas. I will be in Maui by end of this month! Sorry I am no help with the problem.
  8. Apr 8, 2017 at 12:18 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado. Did you take any rocks from Volcanoes National Park? I believe if you do back luck rains down on you from Pele. Probably not much help, but all I got.
  9. Apr 8, 2017 at 12:19 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Nice day for an exorcism.....
    zcarpenter92, mdavis, joonbug and 2 others like this.
  10. Apr 8, 2017 at 1:17 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I think it's supposed to be little island idols, that's how bad luck follows you.
    Law323 likes this.
  11. Apr 8, 2017 at 2:15 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    You live on Maui, AND drive a tundra........you're living the dream. :D
    Sorry I can't be any help, hope you get it all worked out, electrical issues are so frustrating.
  12. Apr 8, 2017 at 4:20 PM
    808dakine
    Haha no, I know better then that. Lived maui for long time
    TXMiamiFan[QUOTED] likes this.
  13. Apr 8, 2017 at 5:03 PM
    808dakine
    Have you been to HI before? Lifted truck scene is huge out here.
    Ill keep everyone updated.
    GNTundra and Law323 like this.
  14. Apr 8, 2017 at 6:49 PM
    Tacogrande
    Jeremy
  15. Apr 8, 2017 at 7:38 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Cat3ILS, Patriot and GNTundra like this.
  16. Apr 8, 2017 at 7:57 PM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    I am betting the remote start has something to do with this. I know when I had my remote started installed it was routed through the same wires as the EFI. Perhaps something is shorted and causing excessive amperage to the EFI fuse, try disconnecting the remote start and replacing the EFI relay. I had a fuel pump relay go bad on my 4runner once and had similar issues to what you are describing.
    Also I did not see your post referenced in the Toyota Mechanic thread (referenced above)!
    Tundraplatinum and GNTundra like this.
  17. Apr 9, 2017 at 4:05 AM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    I can't guess what the issue might be OP, but that is a dam good looking Tundra!
    I am sure you will get it resolved. Lots of knowledge on here. :thumbsup:
  18. Jun 15, 2017 at 11:45 PM
    808dakine
    Well finally after 2 shops and 3 months later, the tundra came back. Was the ecm. Toyota replaced for free seeing as it was still under a extended manufacturer warrenty. Whoopie
  19. Jun 16, 2017 at 6:26 AM
    Wow. What was the cause for the ECM to crap out?
  20. Jun 16, 2017 at 6:35 AM
    Primo
    Primo White Tundra
    Primo
    San Antonio, Texas
    2016 SR Double Cab
    Level kit and TRD Pro Grill Installed.
    Actually a short of any kind, with enough juice (like crossing positive with negative ports) will short out the ECM. Luckily, it was still under warrantee. Cool beans.
    T-Rex266 likes this.
  21. Jun 22, 2017 at 5:02 AM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    Did they remove the remote start? I had an accident in my Crosstour and the exam went, they removed the remote start at the same time.
  22. Jun 22, 2017 at 5:03 AM
    DalTee
    DalTee New Member
    Dal
    ****ECM stupid spellcheck!
  23. Jul 4, 2017 at 4:51 PM
    808dakine
    No idea what went wrong with the ECM. Took the truck on the road to hana back side. No problems except puncturing a tire.. lol. my fault, dam lava rock.
    https://www.youtube.com/watch?v=_Nr6wbcynCw
    Sucks, now I gotta buy a new nitto trail grappler.. lol Shops here are quoting me at 600-700$ for 1. FML
    19453027_10155509865316942_3083549399487_d55c397d801680e9fbda2af2627040f1196538ec.jpg
    So I took the paint of my stocks which the previous owner painted and it doesn't look half bad. Might be considering getting rid of my Fuel Mavricks and nittos for some Chrome 20x12's.19702647_10155553855861942_4555103117466_e7ec6b7fb03ab7d4c0a651d381447a7e9cd9953f.jpg 19780362_10155553577391942_4025067633633_5de6ed695978b30e72d7bc1cb58358526914a6c9.jpg
