Determining the right regear
Discussion in '1st Gen Tundras (2000-2006)' started by Desrat, Sep 25, 2020.
  1. Sep 25, 2020 at 12:08 PM
    Desrat
    Desrat [OP] New Member
    AZ
    06 Double Cab RWD V8
    Wondering how people decide which regear to go with. I currently have a 3.91, and there are a few options (~4.5, 4.9, 5.2) I see commonly available.
    I will be going from the stock tire size to 33s, and that increases my circumference by 7%. Thus, I would want to increase my gear ratio by the same, to recover "factory gearing" (ie so that my RPMS at 70mph will be the same, both before and after the tires+regear):
    1.07 x 3.91 = 4.2
    So 4.2? That's lower than anything I see available. I guess the other part of the equation is that adding extra weight in the form of larger heavier tires calls for a higher gear ratio, and maybe that's what pushes it from needing a 4.2 to, let's say, 4.5. Total speculation on my part there.
    Thoughts?
    831Tun likes this.
  2. Sep 25, 2020 at 1:57 PM
    Professional Hand Model
    Hand Protectors
    Not a pro. Flamers will get flamed back for simply stating my opinion. :D
    Thoughts?
    If you regear it seems the 4.56 is a great ratio for the 33” tires. Some have had remorse going bigger ratio (she said).
    With that said, your highway MPG will suck more than it sucks now. :rofl:
    Disclaimer: I am on 285/75/r16 on stock 3.91 gears since 2004. This is the equivalent of close to 33”. Low end could use some help, but is the cost worth it? Maybe it is for a 2WD?
    Those are my thoughts.
    potoghi, YardBird and Darkness like this.
  3. Sep 25, 2020 at 2:54 PM
    Desrat
    AZ
    Lol, from now on instead of "thoughts" I'll have to ask "facts?"
    I think I've read you say that you've had that size tire for ~10 yrs, but do you recall what kind of a hit your mpg took when you switched to 33s?
    I am pretty sure that, counter to what you said about MPGs getting worse, regearing to compensate for bigger tires will increase your mpg by returning you to the efficient part of your power band at cruise. Now of course I don't mean that the MPGs will be better compared to stock tire size and stock gearing, but rather that it will be more efficient than 10% taller tires with stock gearing.
  4. Sep 25, 2020 at 3:17 PM
    Hand Protectors
    The truck did take a hit in the MPG when going to bigger tires in City Driving. Highway stayed the same. Right now I’m in the 14-18 range still at almost 20 years old on 33”. I calculate the MPG every fill up. Not bad.
    Your RPM’s will be affected with the re-gearing and will effect your MPG at higher gears/speeds. Its all a trade off. Like I said, most really like the balance of 4.56 ratio at the 33” tire. Some have gone higher ratio usually in non-daily drivers and off road type purpose trucks. Slow and crawling type driving.
    Its an easy job for 2wd. Go for it.
    Desrat[OP] likes this.
  5. Sep 25, 2020 at 5:11 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Gear calculators are almost garbage in my opinion. They account only for diameter and not for weight.
    If you want the closest possible match for your speedo 4.30 is almost perfect. Its expensive, more than any other gear set last I checked.
    If you want real return and a little extra torque then go 4.56
    I've had 4.56 since 2010, your mpg won't suffer like people think, it might even get better.
    revtune and Desrat[OP] like this.
  6. Sep 25, 2020 at 5:20 PM
    Desrat
    AZ
    Yeah, I'm thinking it's 4.2 to match exactly to the factory final drive ratio, but the practical solution will be the 4.56, as inevitably the extra weight of the bigger tires and future add ons (winch, heavier bumpers) will eat up the difference.
  7. Sep 25, 2020 at 5:26 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Actually, looks like JustDiffs has Toyota 4.30 for a reasonable price now. They used to be over $600 back when i was looking for gears.
    https://www.justdifferentials.com/Toyota-8-4-s/2021.htm
    I would still go 4.56 though. Call the guys at JustDiffs and they'll give you sound advice, a lot of them are Toyota guys. Go with Nitro gears and a new bearing kit, pay a little extra for a solid collar too. I have over 100k miles on mine and thats the setup I got.
    If you want an LSD or locker, no better time to get that while you're at it. Doesn't add labor.
    bmf4069, 2006Tundra, YardBird and 2 others like this.
  8. Sep 25, 2020 at 5:37 PM
    Desrat
    AZ
    Right on, I'll check them out. I have also been thinking about slapping in an ARB. Good to know it's worked well for you
    YardBird likes this.
  9. Sep 26, 2020 at 5:19 AM
    Hand Protectors
    Survey says: 4.56!
    revtune likes this.
  10. Sep 26, 2020 at 5:24 AM
    BROGAN
    BROGAN FNG
    Logan
    East TX
    2015 TRD Pro CM Inferno Fast
    Just ceck out build thread in sig
    You'll need onboard air if you're going to do that, just fyi.
  11. Sep 26, 2020 at 6:53 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    On board air is good to have if you're planning to drive through deserts. Its a very slippery slope but its fun.
  12. Sep 26, 2020 at 9:25 AM
    Desrat
    AZ
    I've been using a dewalt battery powered unit to air back up after I go out, but it takes around 10 mins to get all 4 tires from 20->~30 psi. A proper setup with a tank would be nice...
  13. Sep 26, 2020 at 9:39 AM
    BROGAN
    BROGAN FNG
    Logan
    East TX
    Sorry, to more clear. The ARB locker is an air actuated locker, you must run an air line to the diff and have an ARB onboard compressor. Like you said though, when offroading especially when it comes to tires, redundancy is best. I run a CO2 powertank for ease and speed but I have my compressor as a backup or should I run out of CO2 on a long trip.
  14. Sep 26, 2020 at 9:52 AM
    Desrat
    AZ
    Yup, I know. I've heard some people manage without even using a tank to actuate the locker, if they have a sufficient length of pressurized line running from the compressor to the locker to act as a mini-tank.
    I imagine, though, that you'd probably want a tank if you're also running it to fill up your tires?
  15. Sep 26, 2020 at 10:10 AM
    BROGAN
    BROGAN FNG
    Logan
    East TX
    I personally don't run a tank connected to the compressor at the moment. Never had issues with the locker. Every now and then the compressor motor will run for just a few seconds but haven't had any failures yet.
  16. Sep 26, 2020 at 10:21 AM
    Desrat
    AZ
    Do you use that to air up tires too?
  17. Sep 26, 2020 at 12:12 PM
    Casper421
    In the woods
    06 DC
    An arb single or dual compressor will activate lockers and air up tires. No need for a tank unless you want to run air tools.
  18. Sep 26, 2020 at 12:18 PM
    BROGAN
    BROGAN FNG
    Logan
    East TX
    Its my backup. I run a Powertank mounted in the bed for routine air up after airing down. It takes about 15-20 seconds a tire. Whereas the compressor takes 2-3 min x 4 tires. I dont have a multi-tire simultaneous set up yet.
    Desrat[QUOTED][OP] likes this.
  19. Sep 26, 2020 at 3:43 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    You mean you don't use air tools when you're out in the wilderness? o_O
  20. Sep 26, 2020 at 3:52 PM
    Casper421
    In the woods
    06 DC
    18v son, so I can charge it with my solar panel.
    mtntop and Tundra2 like this.
  21. Sep 27, 2020 at 5:11 PM
    evilrb
    evilrb New Member
    Jeremy
    See this is where I get confused so maybe you guys can help me.
    As you guys know from my other threads, I am going TRD supercharger and the Kazuma LSD.
    So I've been looking at gears, and like you guys said in this thread, that most guys like bigger gears for crawling.
    But in my case, I drive from OC to San Diego weekly as well as all over SoCal for work and family stuff.
    200+ miles on the freeway in one trip usually.
    So I'm looking at more of freeway speed and MPG.
    I have the 4.10 rear gear fro mmy Sequoia rear end and thinking about just getting a Sequoia front diff and dropping that matching gear in.
    I'm 3.9 and 4x4 BTW.
    So what do you guys think?
    I have to remove the axles and everything anyway to install the LSD so just buying gears is what I'm looking at.
    I'm running 285/70/17, basically a 33" tire, and plan on keeping close to this setup.
    cost effective+ quality+ money+ power+ MPG = 4.10 ??
    Best Bang for the buck option.
    Thanks guys!
  22. Sep 27, 2020 at 5:17 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    For 33s I’ve been torn between 4.10 or 4.30. 4.10 would be cheapest since well.. I have a used gear set that ratio. Just hoping a TRD LSD pops up eventually and I’ll build my spare pig
    evilrb likes this.
  23. Sep 27, 2020 at 5:28 PM
    evilrb
    evilrb New Member
    Jeremy
    If I find another one I'll send you the link.
    There have been a few of the LSD's poop up randomly lately.
    So just to clarify what do you think I should do?
    OH yeah, and you were right about the sequoia backing plates.
    Trying to figure out my options on that one too...
    Thanks for your help on that!
  24. Sep 27, 2020 at 6:09 PM
    empty_lord
    05 rollover special
    I think 4.10s would be the cheaper choice and should be “enough” for 33s. But 4.30s will feel even quicker. At the cost of minimal mpg possibly
  25. Sep 27, 2020 at 6:10 PM
    empty_lord
    05 rollover special
    Big thing with 4.10s is the easily available used front diffs so you don’t need to drop coin on new gears for the front diffs
    (there some super rare 4.56 gear taco front diffs if you wanted that aggressive of a ratio.)
    evilrb likes this.
  26. Sep 27, 2020 at 7:05 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Your speculation is correct as per a discussion I had with Matt, MCM Fab.
