Define “stiff”. (I mean ride)
Discussion in 'Suspension' started by Mannishboy, Dec 27, 2018.
  1. Dec 27, 2018 at 10:23 AM
    Mannishboy
    Mannishboy [OP] New Member
    Indianapolis, IN
    2015 DC 4x4 Limited, Blue Ribbon Metallic.
    TRD exhaust, TRD cai, TRD rear sway bar, TRD shift knob, Sequoia front sway bar, bed extender, bed step, Weathertech floor mats and window vents, spray in bed liner, Morimoto fogs, Access tonneau bed cover.
    I am replacing my oem non trd shocks with Bilstein 5100’s. I thought about just the front, but decided on all four corners.
    This is my asphalt only DD. I want to level, but I can’t decide what setting to use. Middle or top? I’ve read and heard that top setting compresses the spring more, thereby giving the truck a stiffer ride. Anyone out there that has gone to top setting and loves it on asphalt?
    I have factory 20’s with new Michelin defenders, trd rear sway bar and the sequoia front bar, and I don’t tow anything (yet).
  2. Dec 27, 2018 at 11:31 AM
    yosh2000
    yosh2000 New Member
    Denver
    '17 MGM CM Tundra
    Set it up top. Stock shocks are soft, you'll dig the planted ride with the stiffer setup. Especially with all the way bar work there
  3. Dec 27, 2018 at 1:11 PM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Welcome from Ct
  4. Dec 27, 2018 at 1:32 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    my last tundra had 5100s on top setting, definitely stiffer but much more controlled than the black shocks. it handles hard bumps better, but you do feel everything
