Deeper reaching lug nut or replacing threaded studs?
Discussion in 'Wheels & Tires' started by 54Chev, Jun 8, 2021.
  1. Jun 8, 2021 at 2:35 PM
    54Chev
    54Chev [OP] New Member
    10 Tundra
    None
    Have 2010 Tundra purchased new. Equipped with styled steel wheels. About 1.5 years ago the paint finish on two wheels has flaked off. Missing paint about 1.5 inches by 2.5 to 3" in size on each wheel. Have located four TRD OFF ROAD package wheels and appear to be correct wheel for the 10 Tundra (Part no. from one wheel 050808-1 over C#). Stock lug nuts with styled wheels will not reach threaded lug nut stud. Question: Anyone had experience with using a deeper reaching lug nut, or, replacing threaded studs? I will check with Toyota to determine if TRD package equipped with different size lug studs(?). TRD equipped Tundra's equipped differently? Thank you in advance for your help.
  2. Jun 8, 2021 at 3:22 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    If I recall the steel wheels and the stock OR package wheels or Sport package wheels use different lug types. You just need to purchase the correct lug nuts for the wheels. Sparksparts or Mcgeorgetoyota parts can fix you up.
    Bob likes this.
