Decked with ARE CX
Discussion in '3rd Gen Tundras (2022+)' started by JJK, Oct 26, 2023.
  1. Oct 26, 2023 at 5:16 PM
    JJK
    JJK [OP] New Member
    2023 TUNDRA Platinum Crew Max Short Bed Hybrid - I Force Max
    Toyo AT II Tires Softopper Cap Decked Bed Storage System Weathertech Mats
    Just installed a new decked system on my Tundra. I’m unsure if I like but that’s another thread…
    Is the decked system + ARE CX (with sportsman windows and Yakima rack too much everyday weight for my new 2023 Tundra I Force Max.
    how much sag should I expect?
    is this going to kill my brake and rear suspension life?
    trying to decide if I dump my decked system to lighten up
    Pro feedback???
  2. Oct 27, 2023 at 12:29 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
  3. Oct 27, 2023 at 3:45 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Shell and decked system are fine. Depends on what you load in there and if it’s loaded all the time.
    JJK[OP], JMGmanAZ and PermaFrostTRD like this.
  4. Oct 27, 2023 at 4:49 AM
    JJK
    JJK [OP] New Member
    Thanks Bprose
  5. Oct 30, 2023 at 8:03 AM
    Alex21DC
    Alex21DC New Member
    2021 Gray DC SR5 TRD-OR
    You should be fine, but here's my 2 cents. My truck is a 2021 double cab.
    I built a drawer system out of plywood first and it weighed more than the DECKED system. I kept it pretty loaded and had an ARE topper. I had maybe an inch or two of sag compared to completely empty, but it drove better than empty (less rigid) and noticed no big difference in braking.
    I've since upgraded to the actual DECKED system, and I love it. Instead of traditional drawer slides which age poorly and function worse as the weight goes up, the wheels in the DECKED system roll smooth no matter how much I have it loaded up. And I can powerwash the whole thing without unloading my drawers since the polymer is waterproof and my plywood drawers were not.
    All that being said, I did eventually upgrade to heavy duty Deaver springs to improve the performance when off-road, which I do pretty often.
  6. Oct 30, 2023 at 8:06 AM
    OP has a whole different rear suspension. Has a 23 with coils. Not sure the info from a 2.5 is any help.
  7. Oct 30, 2023 at 8:18 AM
    Gonna need a few more years at least. Wife may get a Seqouia before I let loose of either of my current Tundras.
  8. Oct 30, 2023 at 8:23 AM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    If I logged it correctly the decked system alone is 230lbs and the CX series are 175lbs. Truck is plenty capable.
  9. Oct 30, 2023 at 9:06 AM
    JJK
    JJK [OP] New Member
    Thanks for the feedback everyone. Much appreciated!
  10. Oct 30, 2023 at 1:18 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    running a normal leer cap and a loaded decked system, worst case scenario you need some airbags or HD rear springs
