Decked or keep what I got?
Discussion in '2.5 Gen Tundras (2014-2021)' started by kevine0001, May 26, 2023.
  1. May 26, 2023 at 3:23 PM
    kevine0001
    kevine0001 [OP] New Member
    Kevin
    So when I got my truck (2017, purchased in 2019), it was late summer and I was getting ready for some fishing trips and hunting season. I had a drawer that I had built in my old Land Cruiser. Didn't have enough time to build "drawers" so I built a cubby system to hold camping and recovery gear that permanently lives in my truck. I built it specifically to hold gear on the sides, be a platform on top, and if I slide that middle board to one side, my 150 qt cooler fits perfectly in the open section. I don't need to strap it down or anything. And I don't have to lift it as high when it's full.
    I'm considering getting the bed Line-X'd. I'll be removing the shell, old drop in liner, etc. Now I'm thinking about getting a Decked. I know the cons, which is loss of vertical space, certainly with a shell like mine. My box has worked for me since 2019.
    Anyone have any solid reasons for me to use the box as firewood and drop $1500 on a Decked?
    WVI and Blue Thunder like this.
  2. May 26, 2023 at 3:34 PM
    chrisf111
    chrisf111 New Member
    Custom made solution that already fits you cooler? I see no reason to upgrade. If you carry a cooler often and are not keeping the topper a decked setup will force the cooler to sit above the edge of the bed. This is what stopped me from going decked. I carry a yeti and it's crucial it can fit in the back under a bed cover.
    Beach Toy likes this.
  3. May 26, 2023 at 3:38 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I’ll just put back the shell after, add some wood and make 2 drawers.
    I use furniture slide tape for my drawers and it work great
  4. May 26, 2023 at 3:41 PM
    Rigger
    Rigger New Member
    2014 Tundra Crewmax
    Decked has them drawers, which will be an improvement over what you have. But if you don't need the drawers, put the $1500 into the stock market and watch it reduce in value to $1,000 very quickly. No seriously, why fix what ain't broke?
    kevine0001[OP] and Cthulhu like this.
  5. May 26, 2023 at 5:49 PM
    SD Surfer
    Bruce
    So Cal
    If it ain't broke, why spend $1,500 to fix it?
    kevine0001[OP] likes this.
  6. May 26, 2023 at 6:25 PM
    2mchfun
    Keep what you have and send me $1000 for saving you $500.
  7. May 31, 2023 at 2:17 PM
    kevine0001
    Kevin
    Gotta love the voice of reason. Thanks all for the input. I will be removing the drop in bed liner and getting Line X. Just gotta find some friends to help me remove the shell.
    Winning8, FrenchToasty and 2mchfun like this.
  8. May 31, 2023 at 3:14 PM
    SD Surfer
    Bruce
    So Cal
    I'm trying to remember the last time anyone ever referred to me as being part of "The voice of reason"... o_O:rolleyes:
