Decision on tires for KMC KM561 slides 20x8.5
Discussion in 'Wheels & Tires' started by ARES, May 14, 2018.
  1. May 14, 2018 at 2:38 AM
    ARES
    ARES [OP] ARES Fabrications
    God Bless America
    2018 Tundra TRD Cement
    Ok tundra brothers I have finally decided on a set of rims for my cement girl. Have issues with tire size. The rims im getting are KMC KM561 slides black 20x8.5 with a 38 offset. The tires im debating are as follows.
    Toyo at2 275x55rx20
    Or
    BFG K02 285x55rx20
    What I do not understand is why the tire prices from 275 to 285 width jump over $120 per tire? The price seems to be the same from 285 to 305. Im not wanting anything super aggresive thats why I have chosen rims as close to stock. I am open to suggestions so help me decide.
    Toyo does make a 285x55rx20 but they are special order.
    Thanks
  2. May 14, 2018 at 5:34 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I wish I could tell you but it’s the reason I went with 275. I couldn’t believe the price difference.
  3. May 14, 2018 at 6:13 AM
    ARES
    God Bless America
    Im in the same boat. I know the 285 will have a more aggressive look but the 275 are a better bargain. Its like 275 was the cut off and 285 and up price is dramatically increased and about the same
    BTBAKER[QUOTED] likes this.
  4. May 14, 2018 at 11:21 AM
    ARES
    God Bless America
    What do you guys think about the tire size to choose or are there other good options then what I have listed
  5. May 14, 2018 at 11:34 AM
    275's are in higher demand for most tire brands than the 285's. Same with 295's and 305's but the price difference not a lot of difference. 35X12.5x18 can get pricey too. Supply and demand.
  6. May 14, 2018 at 3:14 PM
    ARES
    God Bless America
    Can anyone give me some insight with the tire size I can go with without rubbing? 285, 295 ?
  7. May 14, 2018 at 4:17 PM
    I basically have an OME 3" lift in the front. 295's. No rubbing on cab mount but you will need to move plastic fender liner forward in front of the tire.
  8. May 15, 2018 at 5:35 AM
    ARES
    God Bless America
    Ok thanks bud. You have any photos of your setup
  9. May 15, 2018 at 6:00 AM
  10. May 15, 2018 at 6:35 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    Is your truck stock height? Do you plan on lifting/leveling if it is not already? That will also play into your tire size. Why not look at the KO2's in the stock 275/55/20 size? Those are about $100 cheaper per tire than the 285/55/20 if you like that tire more.
    There are tons of different options out there, just need more info about what you want/like, etc. Falken AT3W's look pretty aggressive for an AT, and have gotten awesome reviews, with a very reasonable price. Cooper AT3's as well.
