Deciding on 18's
Discussion in 'Wheels & Tires' started by Woody741, Aug 11, 2021.
  1. Aug 11, 2021 at 6:18 AM
    Woody741
    Woody741 [OP] New Member
    I have a 2020 that I just leveled the front with Fox 2.0s. Currently have the TSS 20s but was given the TRD off-road wheels. I’m wanting make the switch to 18s but am torn between 305/65, 285/70, and 295/70. I don’t want to mess with any rubbing but I don’t want it to look too small either. Thoughts? Pics? Anything helps....thanks
  2. Aug 11, 2021 at 6:24 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    lots of pictures of different set up and tires in the suspension and wheel/tire forums here....thousands to look at.
    285/70-18 has limited tire choices, Ridge Grapplers being the only viable choice unless you want a mud tire. But is a good size and will work with what you have.
    295-70 are popular as is 285/75-18, both can work for you. 295s are a bit wider, so you may need wheel spacers or higher offset wheels so you dont hit the UCA.
  3. Aug 11, 2021 at 6:32 AM
    Woody741
    Man I know - I feel like I’ve researched and researched and researched on this site. Everyday I come up with a different decision lol
  4. Aug 11, 2021 at 12:31 PM
    JonS
    JonS New Member
    Jon
    2020 tundra trd sport
    Me too! The more research the more I get confused. I think im going to try fitting 305/70r18 over a 35x12.5 tire. The 305/70r18 should be just slightly wider and taller than a 295/70r18 but smaller than a 35x12.5
